beta testers required for MyController 0.0.3-alpha1 release
+1 I want to beta test, (and if you want.. colaborate to translate at lenguage Spanish..)
Good job!
Good job!
Thank you! Spanish already available. Kindly send request to https://www.transifex.com/mycontrollerorg/gui-angularjs/language/es_AR/
@Tag said:
gui is looking great!,
Thank you for the report and allocated time to test MyController.
have been playing with the software and found the following:
in resources/nodes, all my nodes (mysensors 15,x) are shown as "down" while they are sending data...is this a setup issue?
MyConttroller was looking
I_HEARTBEAT_RESPONSE. From your question I understand that we should make up when we receive any message from node. I will work on it.and for the weather forcast only N/A is shown and not the value from the sensor.....
These are all the weather station mapping icons from https://erikflowers.github.io/weather-icons/
{ id:"sunny", value:"day-sunny", },{ id:"cloudy", value:"day-cloudy", },{ id:"thunderstorm", value:"day-thunderstorm", },{ id:"stable", value:"na", },{ id:"unstable", value:"na", },{ id:"na", value:"na", }we have to update this mapping based on our community members feedback.
rest looks great! really like the dashboard feature!
Thank you!
Hello every one thank you for your support and feedback on beta test. In another couple of days I'm going to release 0.0.3-alpha1 to public. Kindly report your issues, if you face any. I will try to fix it before release.
Also update your locale. https://www.transifex.com/mycontrollerorg/multi-locale/dashboard/
Demo server updated till commit #523. demo.mycontroller.org
After update (and stop/start) I show this:
Pd.
I copied all files and folders..sorry, excuse my ignorance..
Pd.
Antoni.you have to extract bindle zip file. call
mycontroller/bin/start.sh. If you were using old version of MyController.org server. stop it first.
Refresh your browser.(clear cache). -
Pd.
@jkandasa, I deleted the cache and work fine!!, now let's testing..
Pd.
For the next release, how do we do the updates?... first we need save the file "./conf/mycontroller.property", and data base file (which)?thanks you!!
Pd.
Antoni.Note: MyController.org going to support upgrade and restore from 0.0.3-alpha1 version.
You can take a backup via GUI and keep safe backup file. Extract new release on different location, point out backup up file and do restore. that's it. -
Pd.
@anarro said:
When I click on "Backup" option its show this:
Thank you,
Antoni.Yes, you will face this issue, when MyController.org server unable to access given backup location.
Thank you,
Thank you,
@jkandasa said:
Thank you,
Yes, where this option is set ?, as I fix it?
@anarro said:
@jkandasa said:
Thank you,
Hi Sr!,
I think it would require a button to return to the previous window in the backups, it is possible?, you think the same?
Antoni.
@anarro said:
Hi Sr!,
Antoni.
hi, If you click on backup menu on top. it will take you!
Some typos in English language when adding a widget:
Do a search on ' grpahica' => 'graphical' -
Do a search on ' grpahica' => 'graphical'Thank you! I will fix this typo.
I noticed that when graphing data in dashboard (mixed sensors graph) for sensors that send data at different intervals (eg 1=5min;2=1min) that the graph and the interactive guide line is showing something what I think is the epoch time and the marker dots do not align (only at start of graph).
Turning off the checkbox ( Use intractive guide line) resolves the issue.
