  3. MyController.org
  4. beta testers required for MyController 0.0.3-alpha1 release
Scheduled Pinned Locked Moved MyController.org
mycontroller.org
55 Posts 10 Posters 19.8k Views 9 Watching
  • A anarro
    @jkandasa, I deleted the cache and work fine!!, now let's testing..
    Pd.
    For the next release, how do we do the updates?... first we need save the file "./conf/mycontroller.property", and data base file (which)?
    thanks you!!
    Antoni.
    J
    J
    jkandasa
    Pd.
    thanks you!!
    Antoni.
    Note: MyController.org going to support upgrade and restore from 0.0.3-alpha1 version.
    You can take a backup via GUI and keep safe backup file. Extract new release on different location, point out backup up file and do restore. that's it.
    A 1 Reply Last reply
    • J jkandasa
      Pd.
      thanks you!!
      Antoni.
      anarro
      wrote on last edited by anarro
      #30
      @jkandasa, This version is awesome !!, his work is spectacular.
      Antoni.
      • A
        anarro
        When I click on "Backup" option its show this:
        Thank you,
        Antoni.
        J 1 Reply Last reply
        • A anarro
          Thank you,
          Antoni.
          J
          J
          jkandasa
          wrote on last edited by jkandasa
          #32
          Thank you,
          Antoni.
          Yes, you will face this issue, when MyController.org server unable to access given backup location.
          A 2 Replies Last reply
          • J jkandasa
            Thank you,
            Antoni.
            anarro
            • J jkandasa
              Thank you,
              Antoni.
              anarro
              @jkandasa said:
              Thank you,
              Antoni.
              Yes, where this option is set ?, as I fix it?
              • A anarro
                @jkandasa said:
                Thank you,
                Antoni.
                J
                J
                jkandasa
                @anarro said:
                @jkandasa said:
                Thank you,
                Antoni.
                • A
                  anarro
                  Hi Sr!,
                  I think it would require a button to return to the previous window in the backups, it is possible?, you think the same?
                  Antoni.
                  • A anarro
                    Hi Sr!,
                    Antoni.
                    J
                    J
                    jkandasa
                    @anarro said:
                    Hi Sr!,
                    Antoni.
                    hi, If you click on backup menu on top. it will take you!
                    • J jkandasa
                      @anarro said:
                      Hi Sr!,
                      Antoni.
                      anarro
                      @jkandasa,
                      Yes, I had seen, but.. I think it was more intuitive (personal opinion.)
                      • A anarro
                        @jkandasa,
                        J
                        J
                        jkandasa
                        @anarro said:
                        @jkandasa,
                        Thank you for the feedback. Ok I will add Back button.
                        • hoegaarden_bierH
                          hoegaarden_bierH
                          hoegaarden_bier
                          Some typos in English language when adding a widget:
                          Do a search on ' grpahica' => 'graphical'
                          • hoegaarden_bierH hoegaarden_bier
                            J
                            J
                            jkandasa
                            Thank you! I will fix this typo.
                            hoegaarden_bierH 1 Reply Last reply
                            • hoegaarden_bierH
                              hoegaarden_bierH
                              hoegaarden_bier
                              I noticed that when graphing data in dashboard (mixed sensors graph) for sensors that send data at different intervals (eg 1=5min;2=1min) that the graph and the interactive guide line is showing something what I think is the epoch time and the marker dots do not align (only at start of graph).
                              Turning off the checkbox ( Use intractive guide line) resolves the issue.
                              • J jkandasa
                                hoegaarden_bierH
                                hoegaarden_bierH
                                hoegaarden_bier
                                @jkandasa
                                Also here "Use intractive guide line" => "Use interactive guide line
                                • hoegaarden_bierH
                                  hoegaarden_bierH
                                  hoegaarden_bier
                                  When sensor does not have a 'name' (resources-Sensor-sensor details) ,
                                  it shows as eg. 'null-Humidity' in the dashboard (mixed sensors graph).
                                  Maybe just show '-Humidity' ignore the null.
                                    J
                                    J
                                    jkandasa
                                    Yes, It's known issue with nvd3 chart plugin. For that only I gave an option to disable interactive guide
                                    • J jkandasa
                                      J
                                      J
                                      jkandasa
                                      @hoegaarden_bier Thank you for your support!!
                                      • hoegaarden_bierH
                                        hoegaarden_bierH
                                        hoegaarden_bier
                                        When trying to uploading a Firmware , I create a version + type , then try to upload a firmware file (eg. BLINK.ino sketch ), I get an error
                                        2016-03-01 21:43:32,002 ERROR [Acme.Utils.ThreadPool(8)-PooledThread: Acme.Serve.Serve$ServeConnection@5f12cf] [org.mycontroller.standalone.api.jaxrs.exception.mappers.ApplicationExceptionMapper:41] ApplicationException,
                                        org.jboss.resteasy.spi.ApplicationException: java.lang.StringIndexOutOfBoundsException: String index out of range: 1
                                        	at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:152) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:295) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:249) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:236) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:395) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:202) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:221) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.jboss.resteasy.plugins.server.tjws.TJWSServletDispatcher.service(TJWSServletDispatcher.java:40) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at Acme.Serve.Serve$ServeConnection.runServlet(Serve.java:2328) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at Acme.Serve.Serve$ServeConnection.parseRequest(Serve.java:2282) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at Acme.Serve.Serve$ServeConnection.run(Serve.java:2054) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at Acme.Utils$ThreadPool$PooledThread.run(Utils.java:1402) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at java.lang.Thread.run(Thread.java:744) [na:1.8.0]
                                        Caused by: java.lang.StringIndexOutOfBoundsException: String index out of range: 1
                                        	at java.lang.String.substring(String.java:1950) ~[na:1.8.0]
                                        	at org.mycontroller.standalone.mysensors.firmware.FirmwareUtils.getFirmware(FirmwareUtils.java:75) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.mycontroller.standalone.mysensors.firmware.FirmwareUtils.updateFirmwareFromHexString(FirmwareUtils.java:50) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.mycontroller.standalone.mysensors.firmware.FirmwareUtils.createFirmware(FirmwareUtils.java:161) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at org.mycontroller.standalone.api.jaxrs.FirmwareHandler.createFirmware(FirmwareHandler.java:211) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0]
                                        	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0]
                                        	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0]
                                        	at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0]
                                        	at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:139) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                        	... 15 common frames omitted
                                        This is the way it should work not?
                                          J
                                          J
                                          jkandasa
                                          #48
                                          You should upload .hex file.
