  3. MyController.org
  4. beta testers required for MyController 0.0.3-alpha1 release
Scheduled Pinned Locked Moved MyController.org
mycontroller.org
55 Posts 10 Posters 19.8k Views 9 Watching
  • J
    J
    jkandasa
    Hello every one thank you for your support and feedback on beta test. In another couple of days I'm going to release 0.0.3-alpha1 to public. Kindly report your issues, if you face any. I will try to fix it before release.
    Also update your locale. https://www.transifex.com/mycontrollerorg/multi-locale/dashboard/
    Demo server updated till commit #523. demo.mycontroller.org
    • A
      anarro
      wrote on last edited by anarro
      #26
      After update (and stop/start) I show this:
      Pd.
      I copied all files and folders..
      sorry, excuse my ignorance..
      Antoni.
      J 1 Reply Last reply
      • A anarro
        Pd.
        Antoni.
        J
        J
        jkandasa
        Pd.
        Antoni.
        you have to extract bindle zip file. call mycontroller/bin/start.sh . If you were using old version of MyController.org server. stop it first.
        Refresh your browser.(clear cache).
        A 1 Reply Last reply
        • J jkandasa
          Pd.
          Antoni.
          anarro
          #28
          @jkandasa, I deleted the cache and work fine!!, now let's testing..
          Pd.
          For the next release, how do we do the updates?... first we need save the file "./conf/mycontroller.property", and data base file (which)?
          thanks you!!
          Antoni.
          • A anarro
            Pd.
            thanks you!!
            Antoni.
            J
            J
            jkandasa
            Pd.
            thanks you!!
            Antoni.
            Note: MyController.org going to support upgrade and restore from 0.0.3-alpha1 version.
            You can take a backup via GUI and keep safe backup file. Extract new release on different location, point out backup up file and do restore. that's it.
            • J jkandasa
              Pd.
              thanks you!!
              Antoni.
              anarro
              #30
              @jkandasa, This version is awesome !!, his work is spectacular.
              Antoni.
              • A
                anarro
                When I click on "Backup" option its show this:
                Thank you,
                Antoni.
                • A anarro
                  Thank you,
                  Antoni.
                  J
                  J
                  jkandasa
                  wrote on last edited by jkandasa
                  #32
                  Thank you,
                  Antoni.
                  Yes, you will face this issue, when MyController.org server unable to access given backup location.
                  A 2 Replies Last reply
                  • J jkandasa
                    Thank you,
                    Antoni.
                    anarro
                    • J jkandasa
                      Thank you,
                      Antoni.
                      anarro
                      @jkandasa said:
                      Thank you,
                      Antoni.
                      Yes, where this option is set ?, as I fix it?
                      • A anarro
                        @jkandasa said:
                        Thank you,
                        Antoni.
                        J
                        J
                        jkandasa
                        @anarro said:
                        @jkandasa said:
                        Thank you,
                        Antoni.
                        • A
                          anarro
                          Hi Sr!,
                          I think it would require a button to return to the previous window in the backups, it is possible?, you think the same?
                          Antoni.
                          • A anarro
                            Hi Sr!,
                            Antoni.
                            J
                            J
                            jkandasa
                            @anarro said:
                            Hi Sr!,
                            Antoni.
                            hi, If you click on backup menu on top. it will take you!
                            • J jkandasa
                              @anarro said:
                              Hi Sr!,
                              Antoni.
                              anarro
                              @jkandasa,
                              Yes, I had seen, but.. I think it was more intuitive (personal opinion.)
                              • A anarro
                                @jkandasa,
                                J
                                J
                                jkandasa
                                @anarro said:
                                @jkandasa,
                                Thank you for the feedback. Ok I will add Back button.
                                • hoegaarden_bierH
                                  hoegaarden_bierH
                                  hoegaarden_bier
                                  Some typos in English language when adding a widget:
                                  Do a search on ' grpahica' => 'graphical'
                                  • hoegaarden_bierH hoegaarden_bier
                                    J
                                    J
                                    jkandasa
                                    Thank you! I will fix this typo.
                                    hoegaarden_bierH 1 Reply Last reply
                                    • hoegaarden_bierH
                                      hoegaarden_bierH
                                      hoegaarden_bier
                                      I noticed that when graphing data in dashboard (mixed sensors graph) for sensors that send data at different intervals (eg 1=5min;2=1min) that the graph and the interactive guide line is showing something what I think is the epoch time and the marker dots do not align (only at start of graph).
                                      Turning off the checkbox ( Use intractive guide line) resolves the issue.
                                      • J jkandasa
                                        hoegaarden_bierH
                                        hoegaarden_bierH
                                        hoegaarden_bier
                                        @jkandasa
                                        Also here "Use intractive guide line" => "Use interactive guide line
                                        • hoegaarden_bierH
                                          hoegaarden_bierH
                                          hoegaarden_bier
                                          When sensor does not have a 'name' (resources-Sensor-sensor details) ,
                                          it shows as eg. 'null-Humidity' in the dashboard (mixed sensors graph).
                                          Maybe just show '-Humidity' ignore the null.
