  3. RFSensor
RFSensor
cryptopressurehumiditycr2450mysensorstemperaturecontest2016lightcr2032
17 Posts 7 Posters 8.1k Views 6 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/29/RFSensor
    • jbjallingJ
      jbjallingJ
      jbjalling
      Hi all,
      I will upload the projectfiles soon. I'm still waiting for the PCB's to arrive, and I want to make sure that it works (at least to some degree) before I release the files - hope its OK.
      BR Jonas
      • jbjallingJ jbjalling
        Hi all,
        BR Jonas
        GertSandersG
        GertSandersG
        GertSanders
        @jbjalling You could upload the schematic already and add the rest later.
        • jbjallingJ
          jbjallingJ
          jbjalling
          Great idea. I'll upload it tomorrow.
          BR Jonas
          • jenbakerJ
            jenbakerJ
            jenbaker
            hi
            i am new in this field.
            hope to learn from each other here.
            could i embed it into these any rfid reader ?
            waiting for help.
            jbjallingJ 1 Reply Last reply
            • jenbakerJ jenbaker
              hi
              waiting for help.
              jbjallingJ
              jbjallingJ
              jbjalling
              @jenbaker Hi,
              well, it could be possible to embed it in a RFID reader, but it isn't really the purpose of the device.
              It is intended to be a stand-alone environment sensor.
              BR Jonas
              jenbakerJ 1 Reply Last reply
                @jenbaker Hi,
                BR Jonas
                jenbakerJ
                jenbakerJ
                jenbaker
                @jbjalling
                hi great.
                thanks.
                • alexsh1A
                  alexsh1A
                  alexsh1
                  hi
                  any update on schematic please?
                  Alex
                  • jbjallingJ
                    jbjallingJ
                    jbjalling
                    I have uploaded the Rev. 1.0 schematic. I'm currently making some small changes, to be able to use the RF69 module as well as the nRF24L01+.
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      I see that you use ADC7 to power the BPM180. This will not work, ADC7 is an analog sensing pin only and can not be used as digital output (same for ADC6). Better to use PD4, which is still available in your v1 schematic.
                      • GertSandersG
                        GertSandersG
                        GertSanders
                        @jbjalling I do not really understand why you need 2 FETs to switch the nrf power line. How do you see this work ?
                        • jbjallingJ
                          jbjallingJ
                          jbjalling
                          Yep, thanks. Found out the hard way :-/ I'm not sure if I really want to power the sensors from the micro. I have to turn on every sensor to be able to use the I2C bus, so I cant turn them on selectively, as I had hoped.
                          BR Jonas
                          • jbjallingJ
                            jbjallingJ
                            jbjalling
                            I use the N-fet to drive the P-fet, which powers the radio module - again, I'm not sure if its worth it, but when the power comes from a coincell, every nA counts.
                            /Jonas
                              nice work. for UV, I prefer VEML6070, a lot more precise ;) but not same price and not ambiant light
                              I agree with @GertSanders too, you just need one pfet for powering off radio..
                              • scalzS scalz
                                jbjallingJ
                                jbjallingJ
                                jbjalling
                                @scalz Yes, the Vishay one is more precies indeed, but my main reason for putting the Silabs one on the board, was to detect the ambient light level.
                                Reg. the mosfet, yes I could have used a single fet. I think the reason why I did it like this, was that in a previous project, I was controlling higher voltages, hence the need for the n-fet.
                                Anyway, I'm not sure if I will keep it or if I will just let the radio be powered on, all the time, in the next rev.
                                BR Jonas
                                • jbjallingJ
                                  jbjallingJ
                                  jbjalling
                                  I have updated the schematic to rev. 1.1.
                                  The following has been changed:
                                  • Si1133 has been replaced by Si1145
                                  • The mosfets are removed from the radio power path
                                  • Radio pins shuffled around a bit
                                  • FTDI connector removed from PCB and instead I made a programming jig
                                  • All I2C sensors are powered from the same pin of the uC, as well as the I2C pull-ups (haven't decided which pin yet, still routing the PCB)
                                  Comments are more than welcome.
                                  BR Jonas
                                  • MiKaM
                                    MiKaM
                                    MiKa
                                    possible to share pcb files?
                                    THX
                                    MiKa
                                    12.5k
