  3. Removing pro mini led bricked the board
atmega328pbattery poweredpower ledpro mini
15 Posts 8 Posters 9.1k Views 7 Watching
  • T Offline
    T Offline
    tripy
    following the "General Tips for Battery Operation", I tried to remove the power led in 2 of my pro mini 3.3V.
    One by removing the led (using a small screwdriver as lever) and another by cutting the mark leading to it.
    In both cases, this resulted in a board that didn't react anymore to my FTDI programmer.
    Both boards where able to be uploaded a simple DHT mysensors sketch prior to the operation.
    Evidently, they where not the boards linked from the mysensors pages, I had them from a previous project.
    If anyone wonder, this is where I got them: http://www.aliexpress.com/item/Free-Shipping-new-version-5pcs-lot-QFN-Pro-Mini-328-Mini-ATMEGA328-ATMEGA328P-MU-3-3V/32264277091.html
    They are obviously clones, and maybe this one doesn't support it, but I still am trying to find a way to get rid of this led.
    This got me thinking that I have a few ATmega328P-PU in a drawer.
    I'm pretty sure I did burn a bootloader on those, and they seem to be a perfect candidate to have 3.3V low power nodes in my network.
    Although, I barely see any occurrences of this solution on the web site or in the forums.
    Is there a reason for that, apart being maybe considered too advanced/complicated?
    I remember having issue in the past with DHT22 and those on breadboard, giving unreliable results, but I think it was linked to non stabilized power getting below 3V.
    I currently am wondering if I should continue with the pro mini boards, or switch to a simpler "boarduino" setup.
    And if anyone had a similar issue with removing the led, and could revive the board, I' all hears too.
    Tripy.
    • S Offline
      I have boards looking similar.
      I just use my solder iron and de-solder the led and voltage reg.
      When i tried to cut it ended with me destroying something because same result as you.
      • T Offline
        T Offline
        tripy
        Thanks for the reply.
        I still have 2 units left, so I'll try one this evening.
        • S Offline
          @tripy Good luck!
          • ? Offline
            ? Offline
            A Former User
            I've the same model, and I used the same method as @sundberg84 (de-soldering led and reg).
            It works fine.
            I've never tested to cut the tracks.
            • B Offline
              B Offline
              bjacobse
              I use similar clones with success.
              BUT do NOT cut the wires, un-solder or just wipe off the electrical component. The PCB is routing a wire below the voltage regulator so cutting the wires with a knife will kill it. The cutting trick is ONLY valid on genuine Arduino Pro MIni boards
              • mfalkviddM Offline
                I have also tried to cut the tracks which bricked my board. I now remove the led instead, which has worked for 10+ Arduino clones.
                • C Offline
                  C Offline
                  carlierd
                  I usually desolder the regulator as it's not too difficult but now I did not desolder the LED. I prefer desolder the resistor before the LED. It's really easier !
                  At the beginning I was used to desolder the LED and damaged one card ...
                  David.
                  • T Offline
                    T Offline
                    tripy
                    wrote on last edited by tripy
                    Thank you all for chippin in.
                    I just desoldered the led on one of my last units, and it still boots afterward.
                    My sight and big fingers are sadly the biggest obstacle in this operation, but now at least I know it can be done.
                    I was able to take a macro shot, and effectively, I can see a track underneath the led.0_1456860485400_IMG_20160301_202411.jpg
                    I think I'll let the voltage stabilizer untouched, and continue to feed stabilized 3.3V through the VCC pin.
                    The led was my biggest concern for running the node on battery.
                    Thanks again everyone!
                    • C Offline
                      C Offline
                      carlierd
                      My advice: leave the LED and remove the resistor ! Really easier !
                      T Igor KatkovI 2 Replies Last reply
                      • C carlierd
                        T Offline
                        T Offline
                        tripy
                        @carlierd Is the resistore the element marqued 102 above the led? And I don't see how this is easier.
                        My biggest issue was to put my pliers between the led and the adjacent element and not have the magnifying glass move too much while applying the iron tip on the side of the led.
                        • C Offline
                          C Offline
                          carlierd
                          Yes it is the resistor.
                          I don't why it's easier but it is ;) Probably because heat propagation is better.
                          • C carlierd
                            T Offline
                            T Offline
                            tripy
                            @carlierd Ok, I have a couple more in the mail, I'll try this for the next batch. Thanks.
                            • C carlierd
                              Igor KatkovI Offline
                              Igor Katkov
                              I think @carlierd means that resistor '102' (1kOmh) is serially connected with led. It's also on the side so removing it much easier - you just heat one side and push then another side and push away. In the reference design I think this 102 is actually R11.
                              Correct me if I'm wrong.
                              • Thomas NordquistT Offline
                                Thomas Nordquist
                                I decided to fix the broken trace I so naively destroyed while breaking the power LED out with a screwdriver. The image from @tripy really helped to figure out which trace I actually broke. It helped a lot to desolder the voltage regulator as well, leaving me with pads I can solder to. I left the regulator out after the repair since I am running the thing from 5V USB.
                                With the regulator out of the way the correct pad was easily identified.
                                Maybe someone else finds this useful, definitly saved my kitchen lighting project today :blush:
