716 Posts 111 Posters 702.4k Views 93 Watching
  • Ɓ
    Ɓ
    Ɓukasz Rybak
    I've received boards from dirtypcb, it looks pretty good! Very nice design!
    Just have a few questions:
    1. May I use 78L33 voltage regulator instead of LE33ACZ?
    2. Do you know what is the RAW input tollerance of Pro Mini 3.3V (ebay one, not genuine one)?
      I'm thinking of attach temperature sensor to my PIRs in my home and feed it parasitically from PIR (~13VDC). Do you think is it possible?
    • sundberg84S
      sundberg84S
      #65
      Hi Lukasz!
      1. 78L33 is a 3.3v regulator so yes, but is different pins depending on which version you have so you need to check where you put the pins. From left Vout, Gnd and Vin should be connected to the PCB. Compare it with LE33 pinouts.
      2. In theory it should be 12v BUT its a fact that manu clones cant handle that. I would not go above 9v.
      Ɓ 1 Reply Last reply
      • sundberg84S sundberg84
        Hi Lukasz!
        Ɓ
        Ɓ
        Ɓukasz Rybak
        @sundberg84
        1. Ok I will check pinouts
        2. I understand. So what is the best way in your opinion to feed node parasitically in safe manner? Use voltage regulator to step down voltage to safe 3.3v? Should I expect any significant heat? I'm aware of heat becouse it can trigger false alarm of my PIR
        • sundberg84S
          sundberg84S
          I would go with a voltage regulator from your 13v to 5 or 3.3v depending on which arduino you buy. I would connect this to PWR on the pcb and avoid using arduino internal voltage regulator (avoid use of two voltage regulators).
          • Ɓ
            Ɓ
            Ɓukasz Rybak
            Thanks sundberg84, I will give a try.
            One last question. I didn't find any note in BOM list. May I use ceramic caps instead of electrolitic ones?
            I 'm not able to find electrolitic 0.1uF caps at my local store.
            • sundberg84S
              sundberg84S
              #69
              Yes, you can replace it with a ceramic. There are alot to read about the differences on the net.
              • Dombo71D
                Dombo71D
                Dombo71
                Ger..
                Like to order your stuff...
                Only what are the specs of all your Resistor and Capacitor..
                Or perhaps you can make the bom complete..
                Cannot wait...
                • sundberg84S
                  sundberg84S
                  #71
                  @Dombo71 - Hi!
                  The BOM is complete, all capacitors needed and its values are found in the BOM tab.
                  Since caps are so cheap and common i wont specify any link since you can find theme anywhere.
                  • L
                    L
                    lxz
                    Anyone from the Netherlands who ordered a pack of the rev.8 boards? How long did it take to be delivered?
                    The status update on dirtypcbs.com says Shipped on 27 Jan 2016 and I can't wait until I receive them! :)
                    AWIA GertSandersG 2 Replies Last reply
                    • L lxz
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      #73
                      @lxz I can take around 2 months... ;-(, but in most cases within 5 weeks after shipping.
                      • D
                        DutchMurk
                        By heart it took about 10-12 days. "maar pin me er niet op vast"
                        • L lxz
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @lxz Chinese New Year Holiday is just over, there seems to be quite a backlog for items ordered in january. It depends on some luck, to Antwerpen took around 6 weeks.
                          • L
                            L
                            lxz
                            Thanks for the replies, guess I have to wait some more then :)
                            • gentrfamG
                              gentrfamG
                              gentrfam
                              I love this PCB. It makes things so much easier. I am having a little problem with the battery version though. I think I've got it wired up right. I've got the jumper. I've got the booster. But, when I plug in a battery (I've tried a 3.7 volt battery, outputting 3.3v - the one from the solar weather station project, and 2 or 4 AA batteries), I get a "Radio Init Fail" message in the serial monitor. Also, the LED at the back, the one near the reset button, does not light brightly. It initially flashes brightly, then nothing.
                              I've wired it up two different times for the battery setup, and with neither am I getting the live radio.
                              I am able to get a good radio with the 5v setup.
                              • sundberg84S
                                sundberg84S
                                #78
                                Hi!
                                @gentrfam
                                It looks correctly wired. The radio (when bat jumper is selected) is feed directly from the battery, so you need to keep within the specs of the radio (0,9v- 3.6v).
                                First thing I would do is measure volt over radio. Also measure volt over the arduino. Working backwards can give you a clue where it fails if its a power problem.
                                My wild guess is that either its not a genuine/working NRF radio, or you have a cold/bad solder point on arduino and/or radio.
                                I always check my radio before soldering them... a while back I counted that I have ordered 33 radios from Ebay and 3 of them was broken so far. So i have a Easy board just for radiocheck loaded with timeaware sketch.
                                gentrfamG 1 Reply Last reply
                                  Hi!
                                  @gentrfam
                                  gentrfamG
                                  gentrfamG
                                  gentrfam
                                  @sundberg84 Thank you. I checked, and out of the solar-powered battery, I'm actually just out of the radio spec - 3.7-4.0v. I'm going to try with a new radio, and a smaller battery to see if I fried this radio.
                                  In the meantime, I tried to run the battery through an LE33 regulator on a breadboard. (Eventually, I'd like to run the solar-battery through the measuring circuitry on the PCB.) Any idea why the LE33 would be outputting 0.6v?
                                  Thanks for your help. I'm afraid I'm a complete and total noob on this.
                                  • sundberg84S
                                    sundberg84S
                                    #80
                                    No, check incoming voltage to the LE33 - is this correct?
                                    Is the caps oriented (ground) correcly? (if you have any).
                                    Broken?
                                    • fisherF
                                      fisherF
                                      fisher
                                      I already received PCB, soldered everything and I'm stuck with reliable radio quality. It works good only when I keep touching antenna on nrf board with my finger. Once I release my finger I've got st=fail.
                                      I've soldered two boards already, tried with two different radios and have same results
                                      I use nrf24L01+ with internal antenna and 5v pro mini, voltage regulator and caps (100nF, 10uF and 4,7uF) as well.
                                      Do you have any ideas what can be wrong?
                                      S 1 Reply Last reply
                                      • barduinoB
                                        barduinoB
                                        barduino
                                        I can't wait to get mine, I bet on version 8 :smile: .Fear {display:none;} despite being a noob with electronics.
                                        Although I do have a question, for a 5v pro mini...
                                        Suppose I power this using a 9v battery, assuming connection to the RAW, that means not BAT or REG jumpers ?
                                        And I also wont be able to use the voltage divider to read the voltage.
                                        However It looks like that if there is no jumper in BAT or REG the voltage divider circuit is independent. Would it be possible to re-wire the voltage divider circuit to measure the RAW 9v from the battery?
                                        Does anyone know what happens to the internal voltage regulator when the battery gets week? Would the vcc library get any idea of what is happening to the current internally?
                                        • fisherF fisher
                                          sven
                                          Hello!
                                          @fisher
                                          Please have a look here: http://forum.mysensors.org/topic/2989/nrf24l01-range-of-only-few-meters/7
                                          It solves my problems.
