  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 71.1k Views 36 Watching
    Slorf
    @Koresh
    I have both versions ( SMD and THD ) crystals on order with aliexpress now :-)
    As for the LDO regulators, I will wait for the PCB's to arrive before making assumptions ;-)
    Now I have to wait some weeks before everything arrives ........and then my first smd soldering experience !
    Alex
      Slorf
      @Koresh
      I got as reply from dirtypcb's, they changed it to 1.6 mm :-)
      Alex
      • fisherF
        fisherF
        fisher
        Very nice project. Do you have a plan to sell assembled piece of the boards?
        Soldering such small SMD is out of my skills
        KoreshK 1 Reply Last reply
        • fisherF fisher
          KoreshK
          KoreshK
          Koresh
          @fisher Thanks. I'm looking for good PCBA service.
          fisherF 1 Reply Last reply
          • KoreshK Koresh
            fisherF
            fisherF
            fisher
            @Koresh I'm looking forward. What do you think, what will be the price of a assembled piece?
            • fisherF fisher
              KoreshK
              KoreshK
              Koresh
              wrote on last edited by Koresh
              #50
              @fisher The production of the first small batch is underway (manual mounting). So I wil have 20 boards for test next week. I will provide price estimate in a week.
              • KoreshK Koresh
                GertSandersG
                GertSandersG
                GertSanders
                @Koresh post pictures please :-)
                • flozscF
                  flozscF
                  flozsc
                  Hi @Koresh,
                  Sorry if this is a dumb question but I'm new to this. What's the minimum voltage to power this board? Is it the 1.9V from the NRF?
                  I'm thinking of building a node with this using a LiPo battery with a protected TP4056 charging module.
                  If me idea isn't impossible I'd be highly interested to buy some assembled units of this PCB. :)
                  • flozscF flozsc
                    Hi @Koresh,
                    KoreshK
                    KoreshK
                    Koresh
                    @flozsc
                    Hi. Minimum operating voltage depends on clock frequency. Boards contain standard 16MHz crystal oscillator to full pro mini compatibility. If you use default bootloader and 16Mhz clock frequency, the board will work with a voltage above 2.7v (on the verge of stability). But you can use internal oscillator (custom arduino boards settings, for example 8MHz or 1MHz for lowerst operating voltage) with some limitations (like slower serial). In this case operating voltage should be above 2--2.1v (do not forget a little dropout of LDO regulator).
                    • flozscF
                      flozscF
                      flozsc
                      @Koresh Thanks for your quick reply.
                      Sleeping sometimes helps. ;-) After thinking over it again, I think I'll prepend a step-up converter to 5V behind the battery as most sensors at least require 3.3V or even 5V... :)
                      Looking forward to your update on the 20 test boards!
                      • Y
                        Y
                        yury
                        So far betatests for two modules soldered manually two weeks ago are good. I was using two analog inputs and 5 digital outputs. Radio is rock stable also.0_1457364082654_1745f59fdda935cd02a9fcf4f5f741a256b98564f4610991d6c502bc6aec6aa6.jpg
                        • fifipil909F
                          fifipil909F
                          fifipil909
                          Impressive !!
                          did you reflow the board, or did you REALLY manually solder the nrf24l chip with an iron ???
                          • fifipil909F fifipil909
                            Impressive !!
                            KoreshK
                            KoreshK
                            Koresh
                            @fifipil909 Thanks.
                            I've soldered these boards using simple soldering iron and hot air fan (lukey 702).
                            • KoreshK
                              KoreshK
                              Koresh
                              #58
                              First small batch is completed :)
                              R 1 Reply Last reply
                                excellent :laughing:
                                  Slorf
                                  Nice !!!
                                  I am still waiting for some parts to arrive from china :-(
                                  Alex
                                  • ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    Wow ! I really like the color and design.
                                    Waiting for alpha testing of the nrf chip.
                                    Is soldering it more difficult than soldering the atmega as they are not the same package type ?
                                    Y 1 Reply Last reply
                                    • KoreshK Koresh
                                      R
                                      R
                                      robosensor
                                      wrote on last edited by robosensor
                                      #62
                                      @Koresh what about price for assembled boards?
                                      • R robosensor
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        @robosensor So far 9-10$ for each board. Small batch and not mass production soldering... Negotiating smd services for PCBA. Hope to reduce costs by $2 final. Will see what happens.
                                          Y
                                          Y
                                          yury
                                          wrote on last edited by yury
                                          #64
                                          3 steps process:
                                          1. tin-plating the board contacts
                                          2. tin-plating the chip contacts
                                          3. apply flux-gel and place chip on the board and heat it with soldering Heat Blower - pre-heat-wait-heat-wait . Like standard soldering profile http://www.renesas.eu/products/lead/specific_info/rt/heatproof/index.jsp .
                                          also need to have a good ayes ))) the flux-gel should be the one you do not have to remove after.
