  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 70.9k Views 36 Watching
  • fisherF fisher
    Very nice project. Do you have a plan to sell assembled piece of the boards?
    Soldering such small SMD is out of my skills
    KoreshK
    KoreshK
    Koresh
    @fisher Thanks. I'm looking for good PCBA service.
    fisherF 1 Reply Last reply
    • KoreshK Koresh
      fisherF
      fisherF
      fisher
      @Koresh I'm looking forward. What do you think, what will be the price of a assembled piece?
      KoreshK 1 Reply Last reply
      • fisherF fisher
        KoreshK
        KoreshK
        Koresh
        wrote on last edited by Koresh
        #50
        @fisher The production of the first small batch is underway (manual mounting). So I wil have 20 boards for test next week. I will provide price estimate in a week.
        • KoreshK Koresh
          GertSandersG
          GertSandersG
          GertSanders
          @Koresh post pictures please :-)
          • flozscF
            flozscF
            flozsc
            Hi @Koresh,
            Sorry if this is a dumb question but I'm new to this. What's the minimum voltage to power this board? Is it the 1.9V from the NRF?
            I'm thinking of building a node with this using a LiPo battery with a protected TP4056 charging module.
            If me idea isn't impossible I'd be highly interested to buy some assembled units of this PCB. :)
            • flozscF flozsc
              Hi @Koresh,
              KoreshK
              KoreshK
              Koresh
              @flozsc
              Hi. Minimum operating voltage depends on clock frequency. Boards contain standard 16MHz crystal oscillator to full pro mini compatibility. If you use default bootloader and 16Mhz clock frequency, the board will work with a voltage above 2.7v (on the verge of stability). But you can use internal oscillator (custom arduino boards settings, for example 8MHz or 1MHz for lowerst operating voltage) with some limitations (like slower serial). In this case operating voltage should be above 2--2.1v (do not forget a little dropout of LDO regulator).
              • flozscF
                flozscF
                flozsc
                @Koresh Thanks for your quick reply.
                Sleeping sometimes helps. ;-) After thinking over it again, I think I'll prepend a step-up converter to 5V behind the battery as most sensors at least require 3.3V or even 5V... :)
                Looking forward to your update on the 20 test boards!
                • Y
                  Y
                  yury
                  So far betatests for two modules soldered manually two weeks ago are good. I was using two analog inputs and 5 digital outputs. Radio is rock stable also.0_1457364082654_1745f59fdda935cd02a9fcf4f5f741a256b98564f4610991d6c502bc6aec6aa6.jpg
                  • fifipil909F
                    fifipil909F
                    fifipil909
                    Impressive !!
                    did you reflow the board, or did you REALLY manually solder the nrf24l chip with an iron ???
                    • fifipil909F fifipil909
                      Impressive !!
                      KoreshK
                      KoreshK
                      Koresh
                      @fifipil909 Thanks.
                      I've soldered these boards using simple soldering iron and hot air fan (lukey 702).
                      • KoreshK
                        KoreshK
                        Koresh
                        #58
                        First small batch is completed :)
                        R 1 Reply Last reply
                          excellent :laughing:
                            Slorf
                            Nice !!!
                            I am still waiting for some parts to arrive from china :-(
                            Alex
                            • ahmedadelhosniA
                              ahmedadelhosniA
                              ahmedadelhosni
                              Wow ! I really like the color and design.
                              Waiting for alpha testing of the nrf chip.
                              Is soldering it more difficult than soldering the atmega as they are not the same package type ?
                              Y 1 Reply Last reply
                              • KoreshK Koresh
                                R
                                R
                                robosensor
                                wrote on last edited by robosensor
                                #62
                                @Koresh what about price for assembled boards?
                                • R robosensor
                                  KoreshK
                                  KoreshK
                                  Koresh
                                  @robosensor So far 9-10$ for each board. Small batch and not mass production soldering... Negotiating smd services for PCBA. Hope to reduce costs by $2 final. Will see what happens.
                                    Y
                                    Y
                                    yury
                                    wrote on last edited by yury
                                    #64
                                    3 steps process:
                                    1. tin-plating the board contacts
                                    2. tin-plating the chip contacts
                                    3. apply flux-gel and place chip on the board and heat it with soldering Heat Blower - pre-heat-wait-heat-wait . Like standard soldering profile http://www.renesas.eu/products/lead/specific_info/rt/heatproof/index.jsp .
                                    also need to have a good ayes ))) the flux-gel should be the one you do not have to remove after.
                                    • Sander TeunissenS
                                      Sander TeunissenS
                                      Sander Teunissen
                                      You make some... I'll buy some... great work!
                                      • Y
                                        Y
                                        yury
                                        Alfa testing:
                                        Checking radios as various nodes. Currently working as 2 relay nodes, DHT 22 temperature node and gateway.
                                        All is good . Range 1-2 meters less than NRF24 with big antenna in apartment surrounding.
                                        Digital pins cheeked like in the video: https://youtu.be/00fy9amZnt4
                                        Analog pins tested with generic arduino light sensor. So radios and pins are OK.
                                        • Sander TeunissenS Sander Teunissen
                                          Y
                                          Y
                                          yury
                                          #67
                                          So far still negotiating\finding reliable PCBA. First batch of 17 boards Koresh and me we were not impressed.
