  3. Mixing sensors in two houses
9 Posts 4 Posters 2.1k Views 2 Watching
  • ahmedadelhosniA Offline
    ahmedadelhosni
    Hello @Anticimex
    You have mentioned in the tutorial the example of the motion sensor. Your advice was that signing is not important in that case as it is more dangerous to put a signed node outside which can be stolen. Further more this stolen node can be re programmed as a 'Gateway' to send signed messages to your secured sensor nodes.
    My understanding is correct till now ?
    If yes. Then consider this situatiom with me please. If it happens that two different houses uses the mysensors library as it is becoming more popular now :) thus when I start up my node it will automatically appear in Domoticz for example, or the sensor ID is assigned as Static in the SW - for example - 5. The other house by coincedence has a motion sensor / door sensor with same sensor node ID 5. In this case I guess that there is no way to differentiate between the coming values except by using signing to know which sensor node belongs to the Gateway of each house.
    This is a rare use case but this may happen. Correct ?
    How could this be solved without using signing ?
    AnticimexA 1 Reply Last reply
      Hello @Anticimex
      AnticimexA Offline
      AnticimexA Offline
      Anticimex
      @ahmedadelhosni your question addresses an issue when not using signing, so I suggest you place it under a different thread, as this thread discusses usecases and a when actually using signing :)
      • mfalkviddM Offline
        Forked from http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors
          ahmedadelhosni
          No ideas guys ?
          • hekH Offline
            hekH Offline
            Yes, you'll have a clash if using the same frequency and radio-id on both networks. Not much to about it atm other than changing it.
            ahmedadelhosniA 2 Replies Last reply
              ahmedadelhosni
              @hek yeah right. It can be solved by changing freq.
                ahmedadelhosni
                @hek Hi again, Do I have also to change the MY_RF24_BASE_RADIO_ID ?
                • hekH Offline
                  hekH Offline
                  No, but you should probably move the frequency a few channels to avoid interference/leakage.
                    ahmedadelhosni
                    @hek Great. Thanks for your fast response.
                    11.8k
                    113.2k
