  3. Battery based atmega328p sensor (no SMD)
mysensorsatmega328batterynrf24l01
46 Posts 6 Posters 22.5k Views 8 Watching
    @alexsh1 : lr14 diam 25.5 and length 49.5. 26650 is 26x 67...so lr14 is smaller (but need a switch reg). I agree too, 26650 is a nice rechargeable one for hungry projects ;)
    • alexsh1A
      alexsh1A
      alexsh1
      #27
      @scalz You are right re size - perhaps I was comparing it with type D. However, in terms of capacity, would you get a proper 5,000 mAh (not Trustfire capacity lol) out of lr14? We are not comparing apples with apples here as 26650 is 3.7V (and not 1.5V)
      For super power demanding projects I use this one:
      http://www.gearbest.com/rc-model-accessories/pp_143333.html?currency=GBP&gclid=CNupk7T0pMsCFcO4GwodKFAO6g
      • alexsh1A
        alexsh1A
        alexsh1
        #28
        BTW, for projects now I'd favour AA sized 3.2V LiFePo4 (1 battery) or AA-sized 1.6V NiZN (2xbatteries) or AA-sized 1.5V Lithium rechargeable (2xbatteries)
        This is concerning 3.3V power supply obviously.
          #29
          @alexsh1 : cool :) not comparable, I know, lol..I just wanted to share other alternatives (26650 sized) as lr14 are very cheap in pack and can last very long time (with a booster 0.7v-1.5 to 3V) and you always have 3v during the whole life, can use every drop of power. but booster is not the best efficient for big hungry application. other 9v batt are nice too ;) and lipo can vent or good quality are expensive (good quality = true mAh, secure and low selfdischarge. but as you said it's rechargeable). And I am designing a lipo node too so.. :)
          sorry for ot ..
          • alexsh1A
            alexsh1A
            alexsh1
            @scalz I suggest we move this discussion to http://forum.mysensors.org/topic/3309/powering-nodes-3-3v-with-18650-26650/2
            6 x 1.5V LR14 on Amazon are £7 meantime 26650 3.7V 5000mAh is £9. Obviously one needs 2 for a project so its it £2.2 vs £9, but I am looking at it from a different angle. 26650 is a universal buy for me as well as an investment - I can power a project with, say, a motor or solenoid or connect a solar panel to charge the battery.
            This is just my 2 cents
            • GertSandersG
              GertSandersG
              GertSanders
              • alexsh1A
                alexsh1A
                alexsh1
                @GertSanders I really like this board - you are getting better and better! :)
                You have now EEPROM? And the LED now on D5? You really like changing LED pin. :)
                Somebody was asking for PIR on the slim node.
                Well, another teaser from me using previous version of your board (AA battery compartment and I am altering STL file to have it also for AAA battery case).
                • alexsh1A
                  alexsh1A
                  alexsh1
                  @GertSanders What are you planning to use for SJ4 and SJ5? Soldering or switches? I was thinking about the following:
                  http://www.aliexpress.com/item/50pcs-lot-Micro-Switch-Button-On-Off-Switch-Tact-Push-Button-Switch/32386813536.html?spm=2114.10010108.1000013.1.Za0nJ0
                  • alexsh1A alexsh1
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @alexsh1
                    SJ4 and SJ5 are solderingpads. I find that I do not change the function of the node once it is set up. No point in using switched, when the switch action only happens once.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @GertSanders i know you have not done testing but can you give up heads up when you share it on oshpark - very keen to test it myself. Dank je
                      GertSandersG 2 Replies Last reply
                      • alexsh1A alexsh1
                        GertSandersG
                        GertSandersG
                        GertSanders
                        #36
                        @alexsh1
                        Some pins moved again. I have not yet ordered this, I normally sleep on it for a few days, then check again, and if I feel OK that no more details need to move, I will trigger an order and share. I'll let you know when that happens.
                        I'm still wondering whether I should put soms test-pads in place, to allow ISP programming of a bootloader after the mcu is put in place. It would require some round test-pads on the bottom. I will think about this tomorrow after I have slept on it.
                        UPDATE: found a small error in my schematic: C10 is not needed. So rerouting will be needed, I want this location for something else.
                        • alexsh1A alexsh1
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @alexsh1
                          board is ordered and shared from OSHPark: https://oshpark.com/shared_projects/2uuSjIIQ
                          alexsh1A 1 Reply Last reply
                          • GertSandersG GertSanders
                            @alexsh1
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @GertSanders said:
                            @alexsh1
                            Thanks for this! Can you please share the BOM file?
                            I placed my order already!
                            • alexsh1A alexsh1
                              @GertSanders said:
                              @alexsh1
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @alexsh1
                              I will add it on OpenHardware.io
                              • alexsh1A alexsh1
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @alexsh1
                                In what capacity do you get the AA size LiFeP4 batteries ?
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @GertSanders said:
                                  @alexsh1
                                  @GertSanders
                                  OK, I have a couple of 14500 LiFeP4 3.2V each. They are only 600mA. They are not my favourite though. I also have (1) lithium rechargeable AA 1500mA 1.5V (charging 5V from USB) and (2) NiZn AA 1.6V 2200mA - these are my favourite so far.
                                  The problem for me is that my new charging device has not arrived yet from China and I cannot charge NiZn. I have discharged a few and did not a chance to charge them
                                  • G
                                    G
                                    gloob
                                    Is there a case/housing available instead of printing an own one?
                                    • G gloob
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      @gloob
                                      No, this board was not made for a specific housing. It just fits the dual AA(A) battery holders.
                                      • G
                                        G
                                        gloob
                                        Thanks for your feedback. Do you have a link for a AA battery holder? I could only find AAA holders with pins.
                                        • G gloob
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @gloob have you tried to use google? There are plenty of 2xAA holders on eBay as well.
                                          http://uk.farnell.com/keystone/2462/battery-holder/dp/1702630
