  3. Battery based atmega328p sensor (no SMD)
mysensorsatmega328batterynrf24l01
46 Posts 6 Posters 22.5k Views 8 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    @GertSanders What are you planning to use for SJ4 and SJ5? Soldering or switches? I was thinking about the following:
    http://www.aliexpress.com/item/50pcs-lot-Micro-Switch-Button-On-Off-Switch-Tact-Push-Button-Switch/32386813536.html?spm=2114.10010108.1000013.1.Za0nJ0
    • alexsh1A alexsh1
      GertSandersG
      GertSandersG
      GertSanders
      @alexsh1
      SJ4 and SJ5 are solderingpads. I find that I do not change the function of the node once it is set up. No point in using switched, when the switch action only happens once.
      • alexsh1A
        alexsh1A
        alexsh1
        @GertSanders i know you have not done testing but can you give up heads up when you share it on oshpark - very keen to test it myself. Dank je
        GertSandersG 2 Replies Last reply
        • alexsh1A alexsh1
          GertSandersG
          GertSandersG
          GertSanders
          #36
          @alexsh1
          Some pins moved again. I have not yet ordered this, I normally sleep on it for a few days, then check again, and if I feel OK that no more details need to move, I will trigger an order and share. I'll let you know when that happens.
          I'm still wondering whether I should put soms test-pads in place, to allow ISP programming of a bootloader after the mcu is put in place. It would require some round test-pads on the bottom. I will think about this tomorrow after I have slept on it.
          UPDATE: found a small error in my schematic: C10 is not needed. So rerouting will be needed, I want this location for something else.
          • alexsh1A alexsh1
            GertSandersG
            GertSandersG
            GertSanders
            @alexsh1
            board is ordered and shared from OSHPark: https://oshpark.com/shared_projects/2uuSjIIQ
            alexsh1A 1 Reply Last reply
            • GertSandersG GertSanders
              @alexsh1
              alexsh1A
              alexsh1A
              alexsh1
              @GertSanders said:
              @alexsh1
              Thanks for this! Can you please share the BOM file?
              I placed my order already!
              • alexsh1A alexsh1
                @GertSanders said:
                @alexsh1
                GertSandersG
                GertSandersG
                GertSanders
                @alexsh1
                I will add it on OpenHardware.io
                • alexsh1A alexsh1
                  BTW, for projects now I'd favour AA sized 3.2V LiFePo4 (1 battery) or AA-sized 1.6V NiZN (2xbatteries) or AA-sized 1.5V Lithium rechargeable (2xbatteries)
                  This is concerning 3.3V power supply obviously.
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @alexsh1
                  In what capacity do you get the AA size LiFeP4 batteries ?
                    @alexsh1
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @GertSanders said:
                    @alexsh1
                    @GertSanders
                    OK, I have a couple of 14500 LiFeP4 3.2V each. They are only 600mA. They are not my favourite though. I also have (1) lithium rechargeable AA 1500mA 1.5V (charging 5V from USB) and (2) NiZn AA 1.6V 2200mA - these are my favourite so far.
                    The problem for me is that my new charging device has not arrived yet from China and I cannot charge NiZn. I have discharged a few and did not a chance to charge them
                    • G
                      G
                      gloob
                      Is there a case/housing available instead of printing an own one?
                      • G gloob
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @gloob
                        No, this board was not made for a specific housing. It just fits the dual AA(A) battery holders.
                        • G
                          G
                          gloob
                          Thanks for your feedback. Do you have a link for a AA battery holder? I could only find AAA holders with pins.
                          • G gloob
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @gloob have you tried to use google? There are plenty of 2xAA holders on eBay as well.
                            http://uk.farnell.com/keystone/2462/battery-holder/dp/1702630
                            • G
                              G
                              gloob
                              When you read the data sheet correctly you can see, that the distance between the pins is different for a AA and AAA battery holder. That`s why I was asking if somebody can recommend a holder that fits.
