  3. Battery based atmega328p sensor (no SMD)
mysensorsatmega328batterynrf24l01
46 Posts 6 Posters 22.5k Views 8 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    @scalz I suggest we move this discussion to http://forum.mysensors.org/topic/3309/powering-nodes-3-3v-with-18650-26650/2
    6 x 1.5V LR14 on Amazon are £7 meantime 26650 3.7V 5000mAh is £9. Obviously one needs 2 for a project so its it £2.2 vs £9, but I am looking at it from a different angle. 26650 is a universal buy for me as well as an investment - I can power a project with, say, a motor or solenoid or connect a solar panel to charge the battery.
    This is just my 2 cents
    • GertSandersG
      GertSandersG
      GertSanders
      • alexsh1A
        alexsh1A
        alexsh1
        @GertSanders I really like this board - you are getting better and better! :)
        You have now EEPROM? And the LED now on D5? You really like changing LED pin. :)
        Somebody was asking for PIR on the slim node.
        Well, another teaser from me using previous version of your board (AA battery compartment and I am altering STL file to have it also for AAA battery case).
        • alexsh1A
          alexsh1A
          alexsh1
          @GertSanders What are you planning to use for SJ4 and SJ5? Soldering or switches? I was thinking about the following:
          http://www.aliexpress.com/item/50pcs-lot-Micro-Switch-Button-On-Off-Switch-Tact-Push-Button-Switch/32386813536.html?spm=2114.10010108.1000013.1.Za0nJ0
          • alexsh1A alexsh1
            GertSandersG
            GertSandersG
            GertSanders
            @alexsh1
            SJ4 and SJ5 are solderingpads. I find that I do not change the function of the node once it is set up. No point in using switched, when the switch action only happens once.
            • alexsh1A
              alexsh1A
              alexsh1
              @GertSanders i know you have not done testing but can you give up heads up when you share it on oshpark - very keen to test it myself. Dank je
              GertSandersG 2 Replies Last reply
              • alexsh1A alexsh1
                GertSandersG
                GertSandersG
                GertSanders
                #36
                @alexsh1
                Some pins moved again. I have not yet ordered this, I normally sleep on it for a few days, then check again, and if I feel OK that no more details need to move, I will trigger an order and share. I'll let you know when that happens.
                I'm still wondering whether I should put soms test-pads in place, to allow ISP programming of a bootloader after the mcu is put in place. It would require some round test-pads on the bottom. I will think about this tomorrow after I have slept on it.
                UPDATE: found a small error in my schematic: C10 is not needed. So rerouting will be needed, I want this location for something else.
                • alexsh1A alexsh1
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @alexsh1
                  board is ordered and shared from OSHPark: https://oshpark.com/shared_projects/2uuSjIIQ
                  alexsh1A 1 Reply Last reply
                  • GertSandersG GertSanders
                    @alexsh1
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @GertSanders said:
                    @alexsh1
                    Thanks for this! Can you please share the BOM file?
                    I placed my order already!
                    • alexsh1A alexsh1
                      @GertSanders said:
                      @alexsh1
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @alexsh1
                      I will add it on OpenHardware.io
                      • alexsh1A alexsh1
                        BTW, for projects now I'd favour AA sized 3.2V LiFePo4 (1 battery) or AA-sized 1.6V NiZN (2xbatteries) or AA-sized 1.5V Lithium rechargeable (2xbatteries)
                        This is concerning 3.3V power supply obviously.
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @alexsh1
                        In what capacity do you get the AA size LiFeP4 batteries ?
                          @alexsh1
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @GertSanders said:
                          @alexsh1
                          @GertSanders
                          OK, I have a couple of 14500 LiFeP4 3.2V each. They are only 600mA. They are not my favourite though. I also have (1) lithium rechargeable AA 1500mA 1.5V (charging 5V from USB) and (2) NiZn AA 1.6V 2200mA - these are my favourite so far.
                          The problem for me is that my new charging device has not arrived yet from China and I cannot charge NiZn. I have discharged a few and did not a chance to charge them
                          • G
                            G
                            gloob
                            Is there a case/housing available instead of printing an own one?
                            • G gloob
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @gloob
                              No, this board was not made for a specific housing. It just fits the dual AA(A) battery holders.
                              • G
                                G
                                gloob
                                Thanks for your feedback. Do you have a link for a AA battery holder? I could only find AAA holders with pins.
                                • G gloob
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @gloob have you tried to use google? There are plenty of 2xAA holders on eBay as well.
                                  http://uk.farnell.com/keystone/2462/battery-holder/dp/1702630
                                  • G
                                    G
                                    gloob
                                    When you read the data sheet correctly you can see, that the distance between the pins is different for a AA and AAA battery holder. That`s why I was asking if somebody can recommend a holder that fits.
