  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.0k Views 6 Watching
  • D drock1985
    @martinhjelmare
    Here is the info you requested:
    commit d07f8097a6186611371b8bc918fcb0d436bb39ba
    Author: MartinHjelmare <marhje52@kth.se>
    Date:   Sat Feb 27 04:55:38 2016 +0100
        Add mysensors tcp ethernet gateway
        * Replace CONF_PORT with CONF_DEVICE and ATTR_PORT with ATTR_DEVICE.
        * Add tcp_port in config.
        * Use fork pymysensors repo, temporarily.
        * Try to guess if tcp or serial gateway is configured, by validating
            device name as an ip address. If successful setup tcp gateway, if it
            fails, setup serial gateway.
        * Update device_state_attributes to show correct device, ethernet or
            serial.
    commit 278fdc0983a8528945e13cf912da82f3bc5fe14c
    Merge: 6dc49df 8ffa368
    Author: Daniel Høyer Iversen <daniel.h.iversen@ntnu.no>
    Date:   Fri Feb 26 10:49:10 2016 +0100
        Merge pull request #1385 from balloob/rfxtrx
        improve rfxtrx sensor
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    #25
    @drock1985
    Sorry, I forgot I've only updated the pymysensors project, so you checking the home-assistant git log is no use. Well, I think your're running the lastest version anyway, since you got it working just now. Everything should be ok.
    Let me know if you experience any problems.
    If everything seems ok for you after some time of testing, I don't see why we can't release this very soon. My limited testing after the lastest update, show no problems.
    • Dave DanD
      Dave DanD
      Dave Dan
      Hey @martinhjelmare,
      I finally got this working.
      I'm doing tests with a couple of multi-sensors (Temp, Hum, Light & motion). The discovery worked very well, no issue at all after following all the above steps.
      What I'm not seeing wotking are the updates. I always see the same values. I'm checking messages with MYSController and I see the GW is receiving the events and updates but I can't see new values showing in the portal.
      Still testing ...
      • Dave DanD Dave Dan
        Still testing ...
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @Dave-Dan
        Do you mean that the sensors are not showing the latest values in the gui?
        If the last value from a sensor is the same as the previous value, a state change won't happen. So the value will be reported as being as old as the previous value. Could this explain what you see?
        • Dave DanD
          Dave DanD
          Dave Dan
          actually, I just got it working ...
          yes, I was referrring to that. The way I have built the sensor is that everytime a movement is detected is sending all sensors statuses to the GW. This sensors are designed to be plugged (no battery powered) so no concern on power consumption.
          I restarted the server and now updates are working.
          What I'm seeing in the log is constantly this message:
          16-03-14 10:39:53 INFO (Thread-9) [mysensors.mysensors] Permission denied when writing to /home/pi/dev/home-assistant/path/mysensors3.json
          If I'm not wrong this is the persistence.
          Apart of this I now see updates coming in ...
          • martinhjelmareM
            martinhjelmareM
            martinhjelmare
            Good!
            The path to the persistence file must exist, not the file itself, but the directory tree above, and hass should have write permission to it.
            I usually put the file in the same directory as configuration.yml.
            • Dave DanD
              Dave DanD
              Dave Dan
              Ok, couple of things that I'm seeing now.
              1. Everytime I restart the server the MySensor nodes are no longer in the system. I have to restart them to get them in again. All of them are in the persistence file.
              2. Now i can only have 1 node added.
                While in the persistence file I see multiple nodes, once I add one of them I can't add anymore. No error if fired (at least not that I've seen).
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @Dave-Dan
                Can you attach the persistence file here and post your config, and I'll take a look?
                • Dave DanD
                  Dave DanD
                  Dave Dan
                  wrote on last edited by Dave Dan
                  #32
                  Sure!
                  Consistence file:
                  {"156": {"sketch_version": null, "children": {}, "battery_level": 0, "sketch_name": null, "type": 17, "sensor_id": 156}, "102": {"sketch_version": null, "children": {}, "battery_level": 0, "sketch_name": null, "type": 17, "sensor_id": 102}}
                  the Configuration is very light. Actually is the by default config and i just added this to test MySensors:
                  mysensors:
                    gateways:
                      - device: 192.168.1.X
                        persistence_file: '/home/pi/.homeassistant/MSPersistence.json'
                        tcp_port: 5003
                    debug: true
                    persistence: true
                    version: '1.5'
                  let me know if you need anything else.
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    In the persistence file I can see two issues.
                    Sketch name is null for both nodes.
                    Both nodes don't have any children.
                    Are you using a non default example sketch, if so can you post it?
                    • Dave DanD
                      Dave DanD
                      Dave Dan
                      hey Martin,
                      that's correct, those are the 2 items I saw that was little curious about.
                      The sketch I'm using, while custom, is a mix of different sketches that can be found in the MySensors page.
                      As you'll see below, each node (which are identical) have all the information (Sketch name, version, etc). And all of them have 4 childs:
                      - Ambient Humidity
                      - Ambient Temperature
                      - Ambient Light
                      - Movement (Motion Sensor Trip).
                      But I might have something wrong so ... happy to learn! :)
                      #define NODE_ID 102
                      #define SKETCH_NAME "dyaSensor (HTLM) v1.2"
                      #define SKETCH_VERSION "1.2"
                      #define CHILD_ID_HUM 0
                      #define CHILD_ID_TEMP 1
                      #define CHILD_ID_LIGHT 2
                      #define CHILD_ID_MOV 3
                      #defin TEMP_CORRECTION 2
                      unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                      int lastLightLevel;
                      boolean metric = true;
                      //Building Messages
                      MyMessage msgHum(CHILD_ID_HUM, V_HUM);            // Initialize humidity message
                      MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);         // Initialize temperature message
                      MyMessage msgLum(CHILD_ID_LIGHT, V_LIGHT_LEVEL);  // Initialize Light message
                      MyMessage msgMov(CHILD_ID_MOV, V_TRIPPED);        // Initialize motion message
                        gw.begin(NULL, NODE_ID, false);
                        Serial.println("Presenting Humidity Sensor");
                        gw.present(CHILD_ID_HUM, S_HUM, "Humidity Sensor");
                        Serial.println("Presenting Temperature Sensor");
                        gw.present(CHILD_ID_TEMP, S_TEMP, "Temperature Sensor");
                        Serial.println("Light Level Sensor");
                        gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "Light Level Sensor");
                        Serial.println("Presenting Motion Sensor");
                        gw.present(CHILD_ID_MOV, S_MOTION, "Motion Sensor");
                        // By calling process() you route messages in the background
                        float temperature = dht.getTemperature()-TEMP_CORRECTION;
                        if (isnan(temperature)) {
                          lastTemp = temperature;
                          if (!metric) {
                          Serial.print("- T: ");
                        if (isnan(humidity)) {
                            lastHum = humidity;
                            Serial.print("- H: ");
                            Serial.println(humidity);
                        int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                          lastLightLevel = lightLevel;
                          gw.send(msgLum.set(lightLevel));
                          Serial.print("- L: ");
                          Serial.println(lightLevel);
                        // Read digital motion value
                        gw.send(msgMov.set(tripped?"1":"0"));  // Send tripped value to gw
                        Serial.println(tripped?"- Movement Detected":"- No Movement Detected");
                        gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                        @drock1985
                        :thumbsup:
                        When you have time, can you run git log and tell me the top commit message, so I know which version you are using.
                        Regarding autostart, no I don't think you can use the normal instructions together with the virtualenv. You could write a script, that changes to the virtualenv and starts hass, and run that script at login or similar.
                        If you don't have another production install of home assistant on the computer, you can skip the virtualenv alltogether and just do:
                        pip3 install --user "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
                        or if you want to install as root:
                        sudo pip3 install "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
                        This way you should be able to autostart the usual way, per instructions on the web.
                        But then if you want to test an update from me, you have to make sure you uninstall everything correctly and manually remove ~/.homeassistant/lib before you install again.
                        Dave DanD
                        Dave DanD
                        Dave Dan
                        #35
                        Hey @martinhjelmare
                        Does the above reply to @drock1985 means that I can do a basic installation as per https://home-assistant.io/
                        pip3 install homeassistant
                        hass --open-ui
                        followed by
                        and will have a valid testing env without going into all the above steps of creating a virtualenv??
                        If so I'd rather more this avenue because I can clean up everything with a new installation, install the zip and have a new testing env in minutes :)
                        martinhjelmareM 2 Replies Last reply
                          Hey @martinhjelmare
                          hass --open-ui
                          followed by
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @Dave-Dan
                          I can't see any big issues with your sketch, just one small:
                          I guess this is a typo:
                          Since your sketch looks ok, I think something must have gone wrong with the communication between node and gateway. Have you been monitoring the comm, with a serial monitor, on the node side for example, to make sure all messages are sent ok?
                          Dave DanD 1 Reply Last reply
                            Hey @martinhjelmare
                            hass --open-ui
                            followed by
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @Dave-Dan
                            The zip file you install from my github account, is the mysensors tcp gateway branch of home-assistant. So you shouldn't install home-assistant first, if you're going to install my branch.
                            If you don't have any other version of home-assistant that you wish to keep, on the same computer, you can install my branch directly. You just have to make sure you uninstall it and remove ~/.homeassistant/lib before installing an update from me, if I commit some updates.
                            Yeah, setting up a dev machine can be a hassle the first time, and not so useful if you're not developing with it.
                              @Dave-Dan
                              Dave DanD
                              Dave DanD
                              Dave Dan
                              @martinhjelmare
                              thanks for the hint ... definetly a typo :$
                              Yes, I'm monitoring the GW with MYSController as my GW is ethernet and I see all messages showing with no issue. But, I'll be happy to review again. :)
                                @martinhjelmare
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @Dave-Dan
                                Yes, please start from the beginning:
                                Remove the persistence file
                                Start hass
                                Wait until you see that hass has (:smile:) connected to the gateway
                                Start a node
                                Start the next node
                                If you can post the serial log from that here, and also the log from hass, that would be great.
                                • D
                                  drock1985
                                  @martinhjelmare
                                  Haven't had any issues with the sensors I have on my Dev unit; so far so good.
                                  Are you thinking of releasing the ethernet GW code in this weeks update?
                                  My Projects
                                  2 Door Chime Sensor
                                  Washing Machine Monitor
                                  • Andrew SanjanwalaA
                                    Andrew SanjanwalaA
                                    Andrew Sanjanwala
                                    @martinhjelmare
                                    Though I'm eager to try, I can't actually launch the Ethernet Gateway branch in a Windows environment. The best error I can provide is the generic failed to create process on calling hass. Platform is Windows Home Server 2011 running Python 3.5.1. All previous and current release branches of home assistant launch without error.
                                    Any thoughts or other steps I can take to debug it further?
                                    • D drock1985
                                      @martinhjelmare
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @drock1985
                                      Good to hear. Have you tried connecting more than one node to the gateway at the same time?
                                      Unfortunately I don't think it will make this release, cause I won't have time until Sunday, and the release might be finished before that. I will add some updates this weekend that you are welcome to try. After that we should be ready for release.
                                      • Andrew SanjanwalaA Andrew Sanjanwala
                                        @martinhjelmare
                                        martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        @Andrew-Sanjanwala
                                        My experience with python on Windows is very limited. How do you normally start home assistant?
                                          Andrew SanjanwalaA
                                          Andrew Sanjanwala
                                          @martinhjelmare
                                          I typically launch either using hass or hass --open-ui from an administrative powershell session. No-go in either of these two cases.
