  3. INA219 DC Current Sensor
ina219
23 Posts 14 Posters 20.6k Views 8 Watching
  • H Offline
    H Offline
    HighSierraJoe
    wrote on last edited by HighSierraJoe
    I am new to the MySensors.org community but I have been having a blast building all types of wireless sensors since a first discovered this site a few weeks ago and would love be be able to contribute to this community!
    The INA219 Current Sensor Breakout Board by Adafruit is a great little sensor for measuring current and voltages, up to 3.2 amps and 26 volts quite accurately! https://www.adafruit.com/products/904. It uses i2c to send its data and there is a nice library to go along with it. With a simple modification you can change the shunt resistor out to lower values measure higher currents or in my case I remove it completely so I can measure the current across a 500 amp shunt. Im using this sensor to monitor my camping trailer's battery voltage and current draw while it is parked. I also use it to monitor my auxiliary battery backup system that keeps my security camera server and wifi router running in case of a power failure. Ive been using an arduino web server running ajax script so I can monitor my battery systems remotely in real time.
    It is most important for me to monitor my trailer batteries since I have spent hundreds of dollars on AGM batteries and would like to be alerted if for some reason the breaker to the trickle charger tripped or the charger malfunctioned and something was left on in the trailer that could draw the batteries down to dead! AGM batteries can only go dead just a few time before there no good.
    I have wired the INA219 sensor into a sensor node, but since unfortunately there is no sensor type to associate with this particular sensor I have chosen to use the most related S_POWER sensor type and Power Meter device in my Vera3 and use the 2 variables (V_WATT, V_KWH) to send the voltage and current data over. I have even modified the JSON file in Vera3 so that the device label can read volts and current instead of the original watts and KWH. And also added in a couple of new notifications so that i can be alerted if the voltage drops below 12.6 volts or if current draw goes below 0.
    It has been working for the time being, but this is quite a hack job and it would be great if there was a better and nicer way! It looks to me like this idea requires a whole new device to be added to the MySensors plugin and the corresponding variables added to sensors.h? Can someone help point me in the right direction with this? Maybe there are others out there that would be as interested in this project as I am! :)
    D 1 Reply Last reply
    • R Offline
      R Offline
      RJ_Make
      I have been thinking about building an AC current sensor, so I will stayed tuned...
      RJ_Make
      • H HighSierraJoe
        Damme
        Code Contributor
        Lots of info about ac measuring at http://openenergymonitor.org/emon/
        • hekH Offline
          hekH Offline
          wrote on last edited by hek
          A couple of new variables for this would make sense. V_VOLTAGE and V_CURRENT perhaps?
          They will show up under the Advanced tab for the time being. If you need to display it on the main device you'll have te hack the existing power device
          I've ordered parts for a non invasive Power Meter Sensor. Hope to create some instructions for this as webb when the things arrive. But this would fit on the same instruction page among with this type of sensors.
          E 1 Reply Last reply
          • R Offline
            R Offline
            RJ_Make
            No way to get this working in 1.4 with displayed values before release? ;-)
            RJ_Make
              E Offline
              E Offline
              epierre
              @hek I have it too... keep us posted so we can share the exoerience !
              z-wave - Vera -> Domoticz
              • hekH Offline
                hekH Offline
                Yes @epierre,
                I bought a couple of these split core currect transformers and a 10 pack of female connectors.
                Planned on following these instructions:
                http://www.homautomation.org/2013/09/17/current-monitoring-with-non-invasive-sensor-and-arduino/
                http://openenergymonitor.org/emon/buildingblocks/ct-sensors-interface
                • H Offline
                  H Offline
                  HighSierraJoe
                  Thanks for the replies!
                  @hek
                  I added the 2 new variables as you suggested. I already hacked the power device so the values are being displayed in the proper amps and volts, but having a hard time getting notifications to work properly! So with that being said you have my vote as well to include this in 1.4 as its own device showing DC volts and amps or even converted to watts is acceptable.
                  These split core CT's look pretty nice. They could make a cheap replacement to other energy monitors like TED5000 and would take up less room in your panel if you can tie multiple CT pairs into one wireless sensor node.
                  • A Offline
                    A Offline
                    a-lurker
                    wrote on last edited by a-lurker
                    On the current transformers (CT). Need a little caution with these. If they are energized with no burden resistor and do not have any protective measures in place like zeners, then the output Voltage can be very high. For example if the transformer is one turn to 2000 turns, like Hek's example transformer and we assume the open circuit resistance is 10 MOhms (it's probably higher) and the primary current flow is just one 1 Amp, then the output Voltage can reach 5000 Volts. (1/2000)*10,000,000=5000. The Voltage produced is ultimately moderated by core saturation. I've seen these things produce nice sparks. However Hek's transformer uses a protective measure to avoid this: two zeners in series across the secondary. The linked article under "6. Operation without an external burden."
                    http://openenergymonitor.org/emon/buildingblocks/report-yhdc-sct-013-000-current-transformer
                    indicates the Voltage is clamped to +/-22V by the zeners. This is still enough to fry your Arduino ADC, if the required burden resistor is accidentally incorrectly connected. Likewise probably best not to unplug & plug in the CT, while its got power going through the primary. It may be more prudent to hardwire the CT to the Arduino.
                    • hekH Offline
                      hekH Offline
                      @a-lurker
                      So, are you suggesting adding some more protection besides the capacitors and burden resistors in the examples?
                      • D Offline
                        Damme
                        Code Contributor
                        I have a couple of those CT too but havn't had time to learn what is needed to do a correct readout. I'll follow this and would like to follow your progress.. :) Mine has internal burden resistor and some protecive diods I think.
                        • A Offline
                          A Offline
                          a-lurker
                          @hek - just suggesting that you ensure the CT you purchase has some protective measure, such as Zener clamps to limit the Voltage when the secondary is not connected to anything. The ones you linked to look fine.
                          • ? Offline
                            ? Offline
                            A Former User
                            Very interesting, I would like to follow!
                            • jeylitesJ Offline
                              jeylitesJ Offline
                              jeylites
                              Has anyone made any progress implementing the AC current sensor or is there a My Sensor plugin?
                              N 1 Reply Last reply
                              • jeylitesJ jeylites
                                N Offline
                                N Offline
                                niccodemi
                                +1 I would be also interested in AC current sensor.
                                • M Offline
                                  M Offline
                                  Mrlynx
                                  I have some ACS712 current sensors on order.
                                  They are easy to use as they give a voltage that corresponds to the current flowing through it.
                                  I am planning to use them to measure current in my LED pwm-dimmer.
                                  I am going to power them with old laptop charger ~18V and limit current depending on length of led-strip.
                                  http://www.sa2avr.se
                                  • N Offline
                                    N Offline
                                    NotYetRated
                                    Just ordered a 100A sensor, going to look to tackle this sometime early January. Will post details if no one else has by then.
                                    • M Offline
                                      M Offline
                                      mainali
                                      I am using ACS712 current sensor with the relay actuator code to sense if someone has manually switched on the light from the physical switch mounted on the walls. If I can help ping me.
                                      chatainsimC 1 Reply Last reply
                                      • M mainali
                                        chatainsimC Offline
                                        chatainsimC Offline
                                        chatainsim
                                        Hello @mainali
                                        Can you provide more details regarding the ACS712 current sensor ?
                                        Maybe a drawing on ho to connect to the arduino nand the sketch ?
                                        • M Offline
                                          M Offline
                                          mainali
                                          wrote on last edited by mainali
                                          I am using a two way switch to control my device. The idea is to control the state from arduino as well as physical switch parallely.
                                          Physical switch ON, Arduino can switch it OFF
                                          Arduino switches it ON, Physical switch whatever be the state on push should switch it OFF.
                                          I have used the Relay actuator example code from mysensor and little more code which I found in arduino forum.
                                          I am not able to use the plugin to embed the code, anyways the following is the code.
                                          // Example sketch showing how to control physical relays.
                                          // This example will remember relay state even after power failure.
                                          #define RELAY_1 2 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                          #define RELAY_2 3
                                          #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                                          #define RELAY_ON 1 // GPIO value to write to turn on attached relay
                                          #define CHILD_ID 1
                                          #define CURRENT_SENSOR A0 // Analog input pin that sensor is attached to
                                          MyMessage msg(CHILD_ID, V_TRIPPED); //Using this as the message to report the physical switch on status
                                          float amplitude_current; //amplitude current
                                          float effective_value;
                                          bool switch_1_on;
                                          int count = 0;
                                          gw.begin(incomingMessage, 21, true);
                                          gw.sendSketchInfo("Relay with current sensor", "1.0");
                                          pins_init();
                                          // Fetch relay status
                                          gw.present(sensor, S_LIGHT);
                                          pinMode(pin, OUTPUT);
                                          digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                                          int sensor_max;
                                          sensor_max = getMaxValue();
                                          Serial.print("sensor_max = ");
                                          Serial.println(sensor_max);
                                          //the VCC on the Grove interface of the sensor is 5v
                                          amplitude_current=(float)(sensor_max-512)/10245/1851000000;
                                          effective_value=amplitude_current/1.414;
                                          //minimum_current=1/10245/1851000000/1.414=18.7(mA)
                                          //Only for sinusoidal alternating current
                                          Serial.println("The amplitude of the current is(in mA)");
                                          Serial.println(amplitude_current,1);//Only one number after the decimal point
                                          Serial.println("The effective value of the current is(in mA)");
                                          Serial.println(effective_value,1);
                                              if (count == 0 && amplitude_current > 30) {
                                                 switch_1_on = true;
                                                Serial.println("physical switch on");
                                                gw.send(msg.set(switch_1_on?"1":"0"));
                                                count = 1 ;
                                              else {
                                                count = 0 ;
                                          if (message.type == V_FAN) {
                                          Serial.println("Message arrived for FAN");
                                          for(int i=4 ; i<=7; i++) {
                                          digitalWrite(i,0);
                                          if (message.type==V_LIGHT) {
                                          // Change relay state
                                          // Store state in eeprom
                                          void pins_init()
                                          pinMode(CURRENT_SENSOR, INPUT);
                                          /Function: Sample for 1000ms and get the maximum value from the S pin/
                                          int getMaxValue()
                                          int sensorValue; //value read from the sensor
                                          int sensorMax = 0;
                                          uint32_t start_time = millis();
                                          while((millis()-start_time) < 1000)//sample for 1000ms
                                          sensorValue = analogRead(CURRENT_SENSOR);
                                          if (sensorValue > sensorMax)
                                          /record the maximum sensor value/
                                          sensorMax = sensorValue;
                                          return sensorMax;
                                          jeremushkaJ 1 Reply Last reply
