  3. Arduino and NRF24 Mesh Code
9 Posts 3 Posters 7.9k Views 3 Watching
  • سیدعظیم عباسس
    سیدعظیم عباسس
    سیدعظیم عباس
    wrote on last edited by سیدعظیم عباس
    I have seen this NRF24 mesh tutorial of MySensor Library on the link link text but could not find any sample code of it's implementation. Is there any sample code that implements sensor and gateway code.Please help , thanks in advance.
    • سیدعظیم عباسس سیدعظیم عباس
      @سیدعظیم-عباس there are lots of examples on https://www.mysensors.org/build/
      Which type of sensor do you want to build?
      • سیدعظیم عباسس
        سیدعظیم عباسس
        سیدعظیم عباس
        I have 4 arduino uno's with nrf24 and i want to make 3 uno's as a sensor nodes and one as a gateway node.I want to make networking mesh of these 3 sensor nodes and 1 gateway node.
        • rollercontainerR
          rollercontainerR
          rollercontainer
          The gateway is always Node 0 and that "target" is coded as default. If you want to go from Node 2 (S) to Node 1 (R) and then to the Gateway (GW) as stated on your painting above, you have to init Node 2 with "target" Node 1 insted of 0 and tell Node 1, that it is a repeater. This is done by create repeating node.
          • سیدعظیم عباسس
            سیدعظیم عباسس
            سیدعظیم عباس
            #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
            #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
            #define RELAY_ON 1
            #define RELAY_OFF 0
            Bounce debouncer = Bounce();
            int oldValue=0;
            bool state;
              gw.sendSketchInfo("Relay & Button", "1.0");
             // Setup the button
              pinMode(BUTTON_PIN,INPUT);
              // Activate internal pull-up
              debouncer.attach(BUTTON_PIN);
              debouncer.interval(5);
              gw.present(CHILD_ID, S_LIGHT);
              pinMode(RELAY_PIN, OUTPUT);
              state = gw.loadState(CHILD_ID);
            *  Example on how to asynchronously check for new messages from gw
              debouncer.update();
              // Get the update value
              int value = debouncer.read();
              if (value != oldValue && value==0) {
                  gw.send(msg.set(state?false:true), true); // Send new state and request ack back
              oldValue = value;
              if (message.isAck()) {
                 // Change relay state
                 state = message.getBool();
                 // Store state in eeprom
                 gw.saveState(CHILD_ID, state);
            Thanks for your reply , I have shared the sample code of MySensor Library above according to this code you mean that all the gateway nodes will have child_id 0 and sensor node will have child_id 1.
            • rollercontainerR
              rollercontainerR
              rollercontainer
              There is always only one gateway. This has to be NodeID 0. NodeID of the for all other nodes are free of choice or assigned automaticly.
              ChildIDs are for the children of the nodes: the sensors themself. They are presented to the gateway.
              • سیدعظیم عباسس
                سیدعظیم عباسس
                سیدعظیم عباس
                For example , I am controlling switches of 4 rooms(each room can be consider as a node) , having 6 buttons each when I call MyMessage msg(CHILD_ID,V_LIGHT); and than gw.send how i can assure which button of that node or room i wont to turn.
                Also if i am assign child_id as 0,1,2..... in neighbor their can also be nodes having CHILD_ID same.
                • rollercontainerR
                  rollercontainerR
                  rollercontainer
                  The NodeId + SensorId are the adress of that switches, so the same Childs on different nodes are allowed:
                  • Livingroom Node 10, ChildIds 1,2,3,4,5,6
                  • Kitchen: Node 20, ChildIDs 1,2,3,4,5,6
                  you have to present every single one of them. You can use a loop for that like:
                      gw.present(sensor, S_LIGHT);
                  • سیدعظیم عباسس
                    سیدعظیم عباسس
                    سیدعظیم عباس
                     * Version 1.0 - Henrik Ekblad
                     * Example sketch showing how to control physical relays.
                     * This example will remember relay state after power failure.
                     * http://www.mysensors.org/build/relay
                    #include <MySigningNone.h>
                    #include <MyTransportNRF24.h>
                    #include <MyTransportRFM69.h>
                    #include <MyHwATMega328.h>
                    MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                    //MyTransportRFM69 radio;
                    // Message signing driver (none default)
                    //MySigningNone signer;
                    // Select AtMega328 hardware profile
                    MyHwATMega328 hw;
                    MySensor gw(radio, hw);
                      gw.sendSketchInfo("Relay", "1.0");
                      // Fetch relay status
                        pinMode(pin, OUTPUT);
                        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                      if (message.type==V_LIGHT) {
                    above i have shared a sample code of RelayActuator can i treat it as one sensor node controlling one relay switch from pin 3.Please guide me i am new to mysensor library.
