  3. Is it possible to use ESP8266's OTA capabilities?
20 Posts 6 Posters 12.0k Views 10 Watching
  • AndurilA Offline
    AndurilA Offline
    Anduril
    Hey there,
    I just found out about the possibility to upload a new sketch to the ESP by using an OTA network port in the IDE. But therefore you have to configure your sketch to allow incoming connections for upload and have enough free space to store the new firmware before reboot.
    Is it possible to combine one of the multiple upload scenarios with the wifi gateway sketch? Has anyone tried to do this?
    That would make the ESP even more powerful, for example when changing to a new version of dev branch or when you have locally attached sensors on it.
    • AndurilA Offline
      AndurilA Offline
      Anduril
      Today I found an example in dev branch named GatewayESP8266OTA... does this mean it is already implemented? Or at least it's been worked on? Could please someone explain how to use?
      • AndurilA Anduril
        T Offline
        T Offline
        tekka
        @Anduril yes, I've added the esp8266 OTA example, works nicely for sketch updates.
        Read here for instructions.
        AndurilA 1 Reply Last reply
        • T tekka
          AndurilA Offline
          AndurilA Offline
          Anduril
          @tekka thanks a lot for that info. I already tried that some time ago and gave up.
          I flashed the OTA gateway and it works fine. Only when trying to ota upload I get problems. The Arduino IDE says [ERROR]: No response from device and in the serial console I see the following:
          0;255;3;0;9;read: 1-1-0 s=1,c=1,t=1,pt=7,l=5,sg=0:39.1
          sleep disable
          Error[1]: Begin Failed
          0;255;3;0;9;read: 1-1-0 s=2,c=1,t=0,pt=7,l=5,sg=0:23.8
          Do you know whats happening there?
          • AndurilA Offline
            AndurilA Offline
            Anduril
            @tekka did you used password protection for OTA update or any other security feature? Did you change anything in the sketch except SSID and password for wifi?
            • AndurilA Anduril
              T Offline
              T Offline
              tekka
              wrote on last edited by tekka
              @Anduril No, I simply followed these instructions:
              https://github.com/esp8266/Arduino/blob/master/doc/ota_updates/readme.md and used this sketch for testing:
              https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/GatewayESP8266OTA
              • AndurilA Offline
                AndurilA Offline
                Anduril
                @tekka do you have and NodeMCU Devkit 0.9 or 1.0? I have a 1.0 and get the error. But I use it with fixed IP on the gateway sketch, maybe that's a problem. It uploads ok via serial. But when uploading via wifi (changed static ip for testing) it stuck. Maybe I will try it with dhcp enabled.
                • AndurilA Anduril
                  T Offline
                  T Offline
                  tekka
                  @Anduril I'm using a NodeMCU 1.0 (MySensors 2.0.0beta and ESP8266 lib 2.1.0) with fixed IP. Both, OTA and serial FW updates work flawlessly...
                  • AndurilA Offline
                    AndurilA Offline
                    Anduril
                    @tekka thanks for that info, I'm also using MySensors 2 beta but ESP lib 2.0 (as far as I know, corrently at work). I will check that later and test with updated ESP library.
                    • AndurilA Offline
                      AndurilA Offline
                      Anduril
                      @tekka did you changed any of the standard settings for ESP flashing? I simply updated ESP8266 library and reflashed, but I get an reboot loop. In the serial monitor I see:
                      0‚~?–4“Ò¶£ÿOAaû0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
                      scandone
                      state: 0 -> 2 (b0)
                      state: 2 -> 3 (0)
                      state: 3 -> 5 (10)
                      add 0
                      aid 2
                      cnt
                      connected with mDjEKlujYacByG5JtxlY, channel 1
                      ip:192.168.38.19,mask:255.255.255.0,gw:192.168.38.1
                      .IP: 192.168.38.19
                      ¥üÊæ” ×Åü1¤ñþ0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
                      scandone
                      state: 0 -> 2 (b0)
                      When going back to 2.0.0 it works without problems. Here my settings for flashing:
                      • AndurilA Anduril
                        scandone
                        state: 0 -> 2 (b0)
                        state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        aid 2
                        cnt
                        .IP: 192.168.38.19
                        scandone
                        state: 0 -> 2 (b0)
                        T Offline
                        T Offline
                        tekka
                        @Anduril I'm using the NodeMCU 1.0 (ESP-12E Module) settings / ESP 2.1.0 lib / and the latest MySensors dev (including PR#419 - there was indeed a rebooting issue before #419)...
                        • AndurilA Offline
                          AndurilA Offline
                          Anduril
                          thanks a lot, working with newest dev build and ESP8266 lib version 2.1.0 as you said.
                          • AndurilA Anduril
                            T Offline
                            T Offline
                            tekka
                            @Anduril excellent! Have fun :)
                            • R Offline
                              R Offline
                              Rasenheizung
                              wrote on last edited by Rasenheizung
                              I'm trying to use the serial monitor but I'm always ask entering a password? Although I didn't used one?
                              Reflashing sketch via OTA worked without any issues.
                              Edit: Tried to use a real OTA password and it's still not working although I'm using the correct. ESP8266 Tools 2.2.0
                              • AndurilA Offline
                                AndurilA Offline
                                Anduril
                                to my last knowledge this feature is implemented but not working. If you want to see the serial monitor you have to connect physically.
                                N 1 Reply Last reply
                                • AndurilA Anduril
                                  N Offline
                                  N Offline
                                  @Anduril
                                  Regarding the bootloops: how you structure your code seems to have an effect. If you have busy-waits in your code, you're more likely to encounter the WDT timeout. I restructured my code to be more interrupt driven and to complete more frequent cycles through the main loop(). After doing that, the WDT timeouts stopped.
                                  That said, I don't know whether your bootloop is caused by a WDT timeout or something else. At least in my case, the debug messages being printed in the serial window specifically mentioned WDT being involved.
                                  • Mark SwiftM Offline
                                    Mark SwiftM Offline
                                    Mark Swift
                                    I presume debugging via network is not supported, I read some posts on Github but couldn't be sure if it was implemented?
                                    • Mark SwiftM Mark Swift
                                      N Offline
                                      N Offline
                                      @Mark-Swift
                                      By debugging, do you mean looking at the serial console output over the network, or something else?
                                      Mark SwiftM 1 Reply Last reply
                                      • N NeverDie
                                        @Mark-Swift
                                        Mark SwiftM Offline
                                        Mark SwiftM Offline
                                        Mark Swift
                                        @NeverDie said:
                                        @Mark-Swift
                                        Yes, serial monitor via network within IDE...
                                        • mfalkviddM Offline
                                          I haven't tried it yet but this plugin for serial monitor over network looks nice https://github.com/esp8266/Arduino/issues/1360
                                          12.2k
