  3. NRF24L01+PA+LNA
NRF24L01+PA+LNA
32 Posts 7 Posters 13.3k Views 9 Watching
  • OitzuO Oitzu
    @noelgeorgi have a look here: http://blog.blackoise.de/2016/02/fixing-your-cheap-nrf24l01-palna-module/
    Tackles most of the nrf24l01 pa/lna module problems.
    In short: Power/Noise/Shielding.
    Addidtional caps don't help in any case.
    noelgeorgiN
    noelgeorgiN
    noelgeorgi
    @Oitzu Thank for your replies, but i have already read that blog earlier and my other PA+LNA modules connected to the nodes just work fine.
    • OitzuO
      OitzuO
      Oitzu
      @noelgeorgi: My experience with this: Power supplies differ. Even modules that seem to be the same can have different effective output. So maybe trying another supply is the way to go, yes.
      Just want to help. ;)
      B 1 Reply Last reply
      • OitzuO Oitzu
        B
        B
        bigjimjeedom
        @Oitzu ,
        just a question; i have a serial gateway on my JEEDOM box and i have a range problem in my stone house;
        so i replace my nrf24l01+ "classic" with a shielded NRF24L01+PA+LNA (as described in the web site you gave us) powered with a separate 3.3v regulator (the module as a little router antenna).
        it is working but he range is similar as with the classic version.
        So i wanted to know your setting in "config.h" ;
        mine are:
        #define RF24_PA_LEVEL RF24_PA_MAX
        #define RF24_PA_LEVEL_GW RF24_PA_LOW
        #define RF24_DATARATE RF24_250KBPS
        what are your settings for a good range ? (i need about 50m in my house)
        thanks for your help
        • OitzuO
          OitzuO
          Oitzu
          @bigjimjeedom you should receive the best results with:
          #define RF24_PA_LEVEL_GW RF24_PA_MAX
          As long as your power supply is clean and your module is shielded.
          • OitzuO Oitzu
            B
            B
            bigjimjeedom
            @Oitzu
            do you use thoses settings (max max) ? because some people says that it was not the good way with this module but maybe it is because of bad power supply ???
            i use this for supplying (with a 5v from USB):
            http://fr.aliexpress.com/item/New-Socket-Adapter-plate-Board-for-8Pin-NRF24L01-Wireless-Transceive-module-51/32230227557.html?spm=2114.30011508.3.2.TXAdlL&ws_ab_test=searchweb201556_1,searchweb201602_1_10036_10035_10034_10033_507_10032_10020_10001_10002_10017_10010_10005_10006_10011_10003_10021_10004_10022_10009_401_10008_10018_10019,searchweb201603_8&btsid=3092fef5-564c-43aa-98a5-0e834674bcd1
            • OitzuO
              OitzuO
              Oitzu
              @bigjimjeedom said:
              @Oitzu
              do you use thoses settings (max max)?
              Yes. I use the max/max settings. I also use as datarate RF24_2MBPS but RF24_250KBPS should be better for good range.
              Yes this is due to low power supply -> The module doesn't get enough current for the MAX setting.
              OR
              Bad power supply -> The module needs more current -> bad supplys tend to be noisier on higher current.
              OR
              Bad shielding -> The output from the module is that high that it feedbacks (without the shielding) back into the IC.
              Never used them, but on the datasheet they look okay.
              • OitzuO Oitzu
                @bigjimjeedom said:
                @Oitzu
                OR
                OR
                B
                B
                bigjimjeedom
                @Oitzu
                thanks a lot for your help !
                i try this tonight and i will tell you!
                • OitzuO
                  OitzuO
                  Oitzu
                  @bigjimjeedom i'm eager to hear your results. :)
                  • F
                    F
                    flopp
                    Other problem
                    I have cap 4,7uf
                    No shield
                    Power from seperate source
                    When I use it in my Ethernet gateway it starts up but can't receive anything.
                    When I put it on other Uno(repeater) it works fine.
                    When I have it on Uno(battery sensor sketch) it works fine.![alt text](image url)
                    What am I missing?
                    • OitzuO
                      OitzuO
                      Oitzu
                      Add shield try again. Even electronics near to the pa/lna module can induce enough noise that it stops working.
                      Different power supplys on the ethernet gateway and the uno?
                      F 1 Reply Last reply
                      • OitzuO Oitzu
                        F
                        F
                        flopp
                        @Oitzu
                        Ok will try with shield.
                        Yes, different computers both GW and REP is powered by USB.
                        • OitzuO
                          OitzuO
                          Oitzu
                          But same source the pa/lna module or also different?
                          • OitzuO Oitzu
                            F
                            F
                            flopp
                            @Oitzu
                            PA is getting from a second USB port(not same as GW) through a step-down to 3,3.
                            GND is connected together from both ports
                            OitzuO 1 Reply Last reply
                            • F flopp
                              @Oitzu
                              OitzuO
                              OitzuO
                              Oitzu
                              I suspect linear regulator? Then it should, normally, no problem.
                              • OitzuO Oitzu
                                F
                                F
                                flopp
                                I have no knowledge about that but I don't think so, because I can turn on a screw to change from ~1.5-4 V
                                • F flopp
                                  OitzuO
                                  OitzuO
                                  Oitzu
                                  Oh, sounds like a switching regulator to me, but can't be sure. Does it have any name? A switching regulator could produce some significant ripple in your supply, that maybe needs to be filtered out.
                                  Would try the shield first, and then see. :D
                                  • OitzuO Oitzu
                                    F
                                    F
                                    flopp
                                    Thank you @Oitzu I change to a different step-down and it started to work, even without shield. Now I use this http://www.ebay.com/itm/DC-5V-to-3-3V-DC-DC-Step-Down-Power-Supply-Buck-Module-AMS1117-LDO-800MA-/281058278731
                                    before it was this "s**t" http://www.aliexpress.com/store/product/RC-Airplane-Module-Mini-360-DC-Buck-Converter-Step-Down-Module-4-75V-23V-to/1686390_32266152653.html
                                    Left is GOOD right is BAD
                                    • OitzuO
                                      OitzuO
                                      Oitzu
                                      Just to note: That is a little bit to simple. The left is a linear regulator the right one a switching regulator.
                                      That are different technologies that both have there up and downsides. But for sensors a linear regulator often fits better, yes.
                                      Never the less i would recommend the shield for even better performance, especially if you want to crank up the pa_level for higher range.
                                      • Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        I gave up on trying to get the PA+LNB version working with my NodeMCU, reverted back to standard for now!
                                        BTW, I tried it with many different power supplies and with without shielding. Tried for almost a week.
                                        In the end I buckled and ordered a proper shielded version, awaiting its arrival...
                                          moskovskiy82
                                          Where did you get this one? And also share your experience after arriving of the item
