  3. Security
Security
89 Posts 20 Posters 69.0k Views 7 Watching
  • daulagariD daulagari
    @Zeph
    The block sizes are not that bad!
    Not sure what I was drinking yesterday evening but I mixed up bit with bytes! ;-)
    1. If the payload itself is encrypted, why do you need a HMAC?
    No, if the payload itself is encrypted with a block cipher you do not necessarily need an HMAC. (the bits-bytes confusion made me thing we could not use block ciphers without needing more than one packet)
    1. Why is a longer counter needed to avoid playback with a stream cipher than with a block cipher? (One of the options for a stream cipher is using the AES in one of the block chaining modes that create a stream cipher).
    A stream cipher is a cipher where plaintext bits are combined with a cipher bit stream by a xor. That means that if you want to flip a particular bit of the (encrypted) message you just have to invert that bit, see Bit-flipping attack.
    AES in block chaining mode is not a stream cipher as I see it unless you want to use it as random bit stream generator and use that for a stream cipher. Not a good idea.
    Yes, to counter act probe attacks, you probably should add some kind of rate limit, but still for a somewhat larger network you can still probe the nodes one by one and have a decent probe rate.
    But, let's first calculate what is needed to make a system such that it would say take on three years before "the key is found" and only then think about preventing that even further.
    You have in mind only the hub handling multiple algorithms
    Indeed.
    Embedding an algorithm id in the header bytes then becomes neither sufficient (doesn't tell the hub what to use for sending) nor necessary (the hub has that same way to know which to use when receiving).
    Yes, you are right, maybe not needed in the header but I still would like to have a node communicate to the hub what kind (if any) crypto is wants to use. A better place for that might be the presentation.
    I think for "less" secure things XXTEA/XTEA is a good idea. Anybody knows which is better?
    For more secure things I think AES is the way to go.
    Z
    Z
    Zeph
    wrote on last edited by Zeph
    #51
    I was referrring to CFB or OFB chaining modes (http://en.wikipedia.org/wiki/Cipher_block_chaining)
    That makes more sense. Still not sure it's needed, but the cost is smaller.
    I guess the idea is that they have the appropriate pre-shared keys for the algorithm, but don't have a pre-shared algorithm id? Or are you thinking that the same keys are used for every algorithm?
    The hub does indeed need more power for this. Initializing each algorithm for a given key takes some time and space, as well as carrying the code for all of them. But this is making more sense as we explore it.
    • daulagariD
      daulagariD
      daulagari
      I was referring to CFB or OFB chaining modes
      In your earlier reply you were referring to this as "stream cipher" so I thought you thought of Cipher feedback (CFB) or Output feedback (OFB) which are not good choices. CFB or OFB chaining is fine.
      On indicating the cipher in the presentation, yes, this adds a small cost but I do not see why we should have a presentation at all ;-)
      If we want to keep things limited in space and processing time, yes then a pre-shared key (PSK) is the only option. The other options is using certificates, public-key cryptosystems and things like Diffie–Hellman but like said that will not fit.
      I see no problem using the same PSK as input for all nodes and the hub but I think the key (or IV) for every node should be different and maybe different for every packet. That is not difficult just use the node Id and the sequence counter.
      Actually the whole plaintext header should be input to the key or IV as we want to be sure those contents are no changed.
      Remaining discussion points I see:
      • XXTEA or XTEA or some other choice for "less secure"
      • Do we still need a random number field? I think not, can be combined with the sequence counter
      • What size should the sequence counter be
      • How does the receiving side after decoding decide the content is valid
      Z 1 Reply Last reply
        Z
        Z
        Zeph
        Good point.
        Does the repeating node change anything in the header?
        Well, what I had suggested is that the 32 bits added at the end of a packet would need to decode to a sequence number in the range N+1 to N+m. If not, it's invalid.
        hekH 1 Reply Last reply
        • Z Zeph
          Good point.
          Yep, it changes the "last" field.
            Z
            Z
            Zeph
            So if there is an authentication hash of some sort which includes the header, it might omit that byte, so that repeating nodes can pass the encrypted portion "as is" without needing to decrypt and encrypt again just to change that field.
            • Z Zeph
              @Zeph
              Wouldn't it be easier to skip encryption of header al together. It shouldn't contain much sensitive information.
              Repeater nodes needs "sender", "destination" and "last" field to be able to route messages to the right direction (and update its routing tables).
              I have put "type" and "sensor" field in the end of the header if we would want to encrypt this.
              • Z
                Z
                Zeph
                #57
                @hek
                Yes, I was suggesting not encrypting the header, it would be plaintext.
                But a few pasts back @daulagari made a good point:
                And that made some sense - the header would be in plaintext but any changes would be detectable to make spoofing harder (ie: the header part would authenticated but not encrypted). If you changed any part of the header, the packet would not authenticate.
                I was following up on that with the idea that MOST of the header could be authenticated, but the "last" byte would change in transit so it should not be part of the authentication. The receipient could validate that the rest of the header had not changed tho.
                • Z Zeph
                  @hek
                  @Zeph
                  Ahh.. yes. Now I'm following. Would probably make sense to move the "last" field first in header then to simplify authentication caclulation then.
                  • DammeD
                    DammeD
                    Damme
                    Code Contributor
                    I've orderd these nRF24LE1 and if we are getting encryption I think it would be wise to be compatible with the embedded encryption: http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24LE1
                    I dont know if its a waste of money but I got 2 for 3€ a piece.
                    • DammeD Damme
                      Z
                      Z
                      Zeph
                      @Damme
                      Keep us informed of your progress!
                      I haven't wanted to set up toolchain and libraries for an 8051 (with which I'm not familiar), so I've not looked into that chip. And I haven't looked into what its AES acceleration feature consists of.
                      If it's just a speedup for software AES faster and with less 8051 code and RAM space, then it might still be possible to make use of AES in a chaining mode that makes it a stream cipher. If it's more directly tied into encrypting packets directly as a block cipher, it could be harder to use given the discussion above.
                      On another forum somebody considering that chip was nudged by Nordic's application engineers to use the nRF51822 instead, as their suggested replacement for the nRF24LE1. It has much better resources for not much more cost (at the chip level). And there is an Arduino derived development environment (RFDuino), as well as an mBed system that might (or might not) be adaptable. I'm more interested in facing the learning curve for ARM than for 8051. (Most developers use the nRF51822 in BLE mode, but it is also supposed to be able to emulate ESB for compatibility with the nRF24L01+)
                      Good luck!
                      DammeD 1 Reply Last reply
                      • Z Zeph
                        @Damme
                        Good luck!
                        DammeD
                        DammeD
                        Damme
                        Code Contributor
                        @Zeph Damn you! :facepunch: now I orderd 2 nRF51822 also :innocent:
                        thanks for the heads up :)
                          I received a nrf8001 BLE development kit from Nordic a week ago. Thought I should play a bit with the BLE part for presence sensing agains my phone (once the new site and 1.4 is launched).
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            I'm going for this approach. I will use this as authentication chip. I see noo benefit of encrypting the payload. Verifying it to originate from a trusted source on the other hand is essential (for locks etc.). The major problem I see at the moment is the limitation of the payload size due to RF24. The messages are going to have to be split up, thus in some respect reducing the efficiency of the authentication mechanism, but an attacker really need to be stubborn to exploit that.
                            • Z
                              Z
                              Zeph
                              #64
                              I'm rethinking this thread a bit. A key problem that complicated our discussion was the short packet length. My goal was to add no more than 4 bytes to the packet contents, which implies some compromises.
                              The new approach I'm considering is having an optional second packet with authentication & replay resistance resistance for the first packet.
                              A given sensactuator node could be programmed to require this second packet or not, depending on what it controls. If it's required, then the node must receive both the command packet and the authentication packet (within some time period) before it would take actions.
                              In this way, the regular packets could be unchanged and we would not need to reserve extra space.in the command packet. Meanwhile the authentication packet could have room for more information - eg: rolling code, nonce, hash of the payload of the other packet, as well as the plaintext normal routing headers.
                                sfam
                                wrote on last edited by sfam
                                #65
                                How abour SipHash? Output is only 8 bytes and:
                                It adds about 1200 bytes to the code size and uses about 42 bytes of RAM.
                                • daulagariD
                                  daulagariD
                                  daulagari
                                  Only 8 bytes (64 bits) output is not a plus. MD5 is 128 bits and already considered insecure (partly because of design flaws). Based in this I think 64 bits will be for sure insecure.
                                  See also the rest of this thread, just a message digest is very likely not the best solution.
                                  S 1 Reply Last reply
                                    sfam
                                    Of course not by itself... the idea was to use it to implement some kind of HMAC and combine it with a stream cipher or a vernam cipher.
                                    • daulagariD
                                      daulagariD
                                      daulagari
                                      See also the earlier discussion, I think a cipher alone can provide authentication without addition MAC.
                                      If you can decode the encrypted message successfully you know that the party you received the message from knows the key and I think that is as good as you can get authentication.
                                      • AnticimexA
                                        AnticimexA
                                        Anticimex
                                        That is a possibility but I believe a benefit of skipping encryption and rely on signature allows a client to ignore the security part (if so desired) which potentially allows for the protocol to implement security by default, i. e. signing all messages. Depending on where the ambition level lies this could increase the amount of traffic (passing nonce back and forth and such) but have not gotten the impression that congestion is an issue.
                                        • daulagariD
                                          daulagariD
                                          daulagari
                                          Yes, if you see no problem with the added data needed for the HMAC, I agree this is no problem but if you combine encryption and a hash the hash is overkill.
                                          So I think you plan is to add say 8 bytes to the message content as HMAC?
                                          From the My "hybrid" gateway thread I understand you plan to use the ATSHA204 that has SHA1 (20 bytes). That would be a good option and you do not have to send all 20 bytes, less bytes would mean less secure but 20 bytes is I think currently overkill for sensor data.
