Add a second distance sensor to the same arduino?
  • Hi, how do I add a second distance sensor to the original sketch using the developer-branch ?
     * Version 1.0 - Henrik EKblad
     * This sketch provides an example how to implement a distance sensor using HC-SR04
     * http://www.mysensors.org/build/distance
    // Enable debug prints
    #include <NewPing.h>
    #define CHILD_ID 1
    #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage msg(CHILD_ID, V_DISTANCE);
    int lastDist;
    boolean metric = true;
      sendSketchInfo("Distance Sensor", "1.0");
      present(CHILD_ID, S_DISTANCE);
      int dist = metric?sonar.ping_cm():sonar.ping_in();
      Serial.print("Ping: ");
      Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      Serial.println(metric?" cm":" in");
      if (dist != lastDist) {
          send(msg.set(dist));
          lastDist = dist;
      sleep(SLEEP_TIME);
  • @Cliff-Karlsson
    It should be something like this
    Define new child id and pins for the new sensor
    #define SONAR_A_CHILD_ID 1
    #define SONAR_B_CHILD_ID 2
    #define SONAR_A_TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define SONAR_A_ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define SONAR_B_TRIGGER_PIN  8  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define SONAR_B_ECHO_PIN     7  // Arduino pin tied to echo pin on the ultrasonic sensor.
    Then instantiate 2 sonars
    NewPing sonar_A(SONAR_A_TRIGGER_PIN, SONAR_A_ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    NewPing sonar_B(SONAR_B_TRIGGER_PIN, SONAR_B_ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    Now instantiate 2 messages and 2 lastDistance variables
    MyMessage SONAR_A_msg(SONAR_A_CHILD_ID, V_DISTANCE);
    int SONAR_A_lastDist;
    MyMessage SONAR_B_msg(SONAR_B_CHILD_ID, V_DISTANCE);
    int SONAR_B_lastDist;
    Presenting the sensors
      present(SONAR_A_CHILD_ID, S_DISTANCE);
      present(SONAR_B_CHILD_ID, S_DISTANCE);
    Finally the loop section
      int SONAR_A_dist = metric?sonar_A.ping_cm():sonar_A.ping_in();
      Serial.print("Ping Sonar A: ");
      Serial.print(SONAR_A_dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      if (SONAR_A_dist != SONAR_A_lastDist) {
          send(SONAR_A_msg.set(SONAR_A_dist));
          SONAR_A_lastDist = SONAR_A_dist;
    int SONAR_B_dist = metric?sonar_B.ping_cm():sonar_B.ping_in();
      Serial.print("Ping Sonar B: ");
      Serial.print(SONAR_B_dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      if (SONAR_B_dist != SONAR_B_lastDist) {
          send(SONAR_B_msg.set(SONAR_B_dist));
          SONAR_B_lastDist = SONAR_B_dist;
      sleep(SLEEP_TIME);
    Other considerations:
    • Since sonar uses sound it might be a good idea to put some wait between the pings
    I did not test this but it did compile 😄
      wait(1000);
      sleep(SLEEP_TIME);
  • Thanks for the help, last question witch complicates the whole thing some more.
    If I want to also have two PIRs connected to the same arduino and want to use both PIRs as interrupts so that the sensor sleeps until one of the PIRs is activated.
    When the sensor wakes up after PIR movement PIRs should be put to sleep for 1min and the distance sensors would start.
    This is the Motion sketch:
     * Version 1.0 - Henrik Ekblad
    // #define MY_DEBUG
    // Initialize motion message
      present(CHILD_ID, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
      sleep(INTERRUPT,CHANGE, SLEEP_TIME);
  • @Cliff-Karlsson
    The "trick" is this line
    You can use something like this
    int8_t sleep(uint8_t interrupt1, uint8_t mode1, uint8_t interrupt2, uint8_t mode2, unsigned long ms=0);
    Take a look in the MySensors API page under "sleeping" http://www.mysensors.org/download/sensor_api_15
    Ok so if PIRs are connected to PIN 10 and PIN 11 I would use:
    int8_t sleep(uint8_t 10, uint8_t CHANGE, uint8_t 11, uint8_t CHANGE, unsigned long ms=0);
  • Ok I got the two distance sensors to work and now I am trying to also add a motion sensor. First question, I read in the motion sensor sketch that only pin 2 and 3 generates interrupts and my radio is connected to pin 2 already. But I also recall reading something about pin 2 on the radio is not used so that means that I can use pin 2 and 3 for the PIRs, right?
    This is what I have come up with for now but I know there is some errors in it and I have not quite figured out the sleep part yet.
    And in the loop do I use ?
    if(tripped){"do distance stuff"}
    This is what I have go so far I added some white lines to the right of the parts that I added to the working distance sketch:
    #define MY_BAUD_RATE 115200
    #define MOTION_A_CHILD_ID 3 -------------------------
    #define MOTION_A_TRIGGER_PIN  2 ----------------------------
    unsigned long SLEEP_TIME = 200; // Sleep time between reads (in milliseconds)
    unsigned long MOTION_SLEEP_TIME = 5000; // Sleep time between reports (in milliseconds) ------------------
    #define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway) ----------------------
    MyMessage msg(MOTION_A, V_TRIPPED); ----------------------------
      pinMode(MOTION_A_TRIGGER_PIN, INPUT);      // sets the motion sensor digital pin as input ----------------------
      sendSketchInfo("Distance+Motion Sensor", "1.0");
      present(MOTION_A_TRIGGER_PIN, S_MOTION); ----------------------
      boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH; ------
      Serial.println(tripped); -----
      send(msg.set(tripped?"1":"0"));  // Send tripped value to gw  -----
      sleep(INTERRUPT,CHANGE, SLEEP_TIME); -----
      wait(1000);
      sleep(SLEEP_TIME);
    @Cliff-Karlsson You can only use pin2 and pin3 as interrupt pins. You don't need to connect the NRF24L01+ to pin 2. So you can use both. I'm doing this with my doorbell works perfect.
    Notice. If you're node also receives messages from the gateway, you wont be able to put the node to sleep. MySensors currently doesn't support wake up on message arrival. That's why pin2 can be used for connecting sensors.
    I hope this makes sense 😉
    @Cliff-Karlsson I'm not sure if you're aware of this. But in your setup, you need to start the MySensors communication. Like the gw.begin() and the presentation of the child's.
    I don't see this in your code:
    No offence. Just trying to help you.
  • Absolutley none offence taken, I really suck at coding and my main methods are copy/paste and click on verify to check if it worked.
    I am using the developer branch that does not use the gw. stuff if that is what you mean?
    This is what I have tried for now but ofcourse it does not work.
    unsigned long MOTION_SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    MyMessage msg(MOTION_A_msg, V_TRIPPED);
     if(tripped)  {
      wait(1000);
      sleep(SLEEP_TIME);
    else{
      sleep(INTERRUPT,CHANGE, MOTION_SLEEP_TIME);
    Error: 'MOTION_A_msg' was not declared in this scope
    @Cliff-Karlsson I'm sorry I haven't played with the development branch. I'm just using 1.5.4. But the part abount interrupts and pin2 and 3 stays the same. It's just how the Arduino works.
    @Cliff-Karlsson I think you want this:
    MyMessage msg(MOTION_A_CHILD_ID, V_TRIPPED);
    instead of
  • Thanks, sorry fore code-spamming but it feels like I am starting to get close to the first step witch is a succesful verify.
    The whole sketch verifies ok until it gets to the last "sleep" then I get this error:
    "expected constructor, destructor, or type conversion before '(' token"
    MyMessage MOTION_A_msg(MOTION_A_CHILD_ID, V_TRIPPED);
      boolean tripped = digitalRead(MOTION_A_TRIGGER_PIN) == HIGH;
      send(MOTION_A_msg.set(tripped?"1":"0"));  // Send tripped value to gw
     if(tripped)  {
      wait(1000);
      sleep(SLEEP_TIME);
    //else{
    @Cliff-Karlsson To me that's what this community is about. I'll have a loop. But no promise, as said before I haven't played with the development branch yet. But I do understand the compiler error
    And if unclear I am trying to achieve in the end is:
    When PIR senses motion, activate both distance sensors for 30 seconds and deactivate PIR.
    After 30 seconds deactivate distance sensors and activate PIR again.
    @Cliff-Karlsson Is it giving the error on the first or the second sleep?
    I have to compliment @Hek and the other guys. They've made MySensors easier to program. The branch looks really great. Love it.
    @Cliff-Karlsson I think I found it.
    it's in this part
        sleep(SLEEP_TIME);
                } // <--------- this ends the loop() method
    //else{
      sleep(INTERRUPT,CHANGE, MOTION_SLEEP_TIME); // <---- so this is not in the method
    } // <-------- int this is also outside of the loop method
    Change it to:
        sleep(SLEEP_TIME);
     //           }  // comment brace
    //else{
  • After commenting the bracket I get : 'DIGITAL_INPUT_SENSOR' was not declared in this scope
    @Cliff-Karlsson I'm sorry would love help you further. But it's getting late over here and my better half wants me to turn off the laptop.
  • 34
23
11.6k
