  3. 💬 Stamp size MySensor node
atmega328atsha204acoincellmysensor
50 Posts 13 Posters 17.2k Views 11 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/76/Stamp-size-MySensor-node
    • S Offline
      nice, your tqfp seems well soldered ;)
      • C Offline
        C Offline
        carlierd
        Very good ! So small !
        I really need to learn how solder SMD part ! More and more design are using small components.
        • S Offline
          Well done! Nice!
          • M Offline
            M Offline
            macieiks
            I have a question about the dimensions. Could you tell me what is the exact measure when fully assembled with nrf24 and with / without goldpins? I have tiny, transparent boxes and curious if I can fit them inside :D
            RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
            RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
            RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
            G 1 Reply Last reply
            • M macieiks
              G Offline
              G Offline
              GertSanders
              @macieiks
              The pcb itself is 21 mm wide and 23 mm long.
              With the radio the longest side becomes 30 mm long and 21 mm wide.
              Without any pins mounted, the board is just under 5 mm think.
              If the dual row angled headers are mounted, the longest side (30 mm with radio) becomes 39 mm.
              You will need to add the length of the contacts + wire to that for a complete length.
              You can also turn the dual row angled header inwards (towards the radio), then the maximum length is still 30 mm.
              N 1 Reply Last reply
              • G GertSanders
                @macieiks
                N Offline
                N Offline
                @GertSanders What is the difference between the v1 version of your stamp size mysensor node that's on OSH PARK and the V2 version that's on your website that you linked to in your OP ( https://www.openhardware.io/view/76/Stamp-size-MySensor-node )?
                • N NeverDie
                  G Offline
                  G Offline
                  GertSanders
                  None. The plan was to enhance it, so I copied my version 1 to version 2. But then I decided to publish it in Openhardware anyway.
                  This board is a proof of concept for me.
                  My next version will have a 8Mhz crystal. The addional powerconsumption is negligable bit the accuracy of timing is much better (and constant, even with dropping voltage).
                  So the board on OSH Park is identical to the one on Openhardware.io
                  • N Offline
                    N Offline
                    Thanks! I ordered it yesterday from OSH PARK, so good to hear.
                    Have you found something where you really do need the 8mhz crystal oscillator, or were you adding it as a "just in case"?
                    • N NeverDie
                      G Offline
                      G Offline
                      GertSanders
                      I have a use case where I need the clock to be acurate. For realy low power nodes like the ones with reed switches, I also prefer the internal oscillator.
                      • alexsh1A Offline
                        alexsh1A Offline
                        alexsh1
                        @GertSanders
                        Goedenavond Gert,
                        What's your boards.txt file is saying please? I uploaded the bootloader (optiboot_atmega328_08M_038400_D8) and all went OK until I upload my first sketch.
                        After that I am getting:
                        avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x32
                        avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0f
                        avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfb
                        avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x32
                        avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0f
                        avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x73
                        avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xff
                        avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x32
                        avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0f
                        avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfb
                        I have to upload the bootloader again in order to upload the sketch - something is clearly not working. This is my extract from boards.txt:
                        BlueBoard.menu.mhz.8Mhz= 8Mhz - internal oscillator D8 LED for atmega328-tqfp
                        BlueBoard.menu.mhz.8Mhz.bootloader.low_fuses=0xE2
                        BlueBoard.menu.mhz.8Mhz.bootloader.high_fuses=0xDE
                        BlueBoard.menu.mhz.8Mhz.build.f_cpu=8000000L
                        BlueBoard.menu.mhz.8Mhz.upload.speed=38400
                        BlueBoard.menu.mhz.8Mhz.bootloader.file=myoptiboot/optiboot_atmega328_08M_038400_D8.hex
                        • alexsh1A alexsh1
                          @GertSanders
                          Goedenavond Gert,
                          G Offline
                          G Offline
                          GertSanders
                          @alexsh1
                          Here is my extract for this type:
                          32PinBoard.name=atmega328p based - 32 pin TQFP
                          32PinBoard.upload.tool=arduino:avrdude
                          32PinBoard.upload.protocol=arduino
                          32PinBoard.upload.maximum_size=32256
                          32PinBoard.upload.maximum_data_size=2048
                          32PinBoard.bootloader.tool=arduino:avrdude
                          32PinBoard.bootloader.unlock_bits=0x3F
                          32PinBoard.bootloader.lock_bits=0x0F
                          32PinBoard.build.core=arduino:arduino
                          32PinBoard.build.mcu=atmega328p
                          32PinBoard.build.board=AVR_GERTSANDERS32PinBoard
                          32PinBoard.build.variant=32PinBoard
                          32PinBoard.menu.bod.4v3=4V3
                          32PinBoard.menu.bod.4v3.bootloader.extended_fuses=0x04
                          32PinBoard.menu.bod.2v7=2V7
                          32PinBoard.menu.bod.2v7.bootloader.extended_fuses=0x05
                          32PinBoard.menu.bod.1v8=1V8
                          32PinBoard.menu.bod.1v8.bootloader.extended_fuses=0x06
                          32PinBoard.menu.bod.off=Disabled
                          32PinBoard.menu.bod.off.bootloader.extended_fuses=0x07
                          32PinBoard.menu.mhz.8Mi-38K4-D8= 8Mhz - internal - 38K4 - D8
                          32PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.low_fuses=0xE2
                          32PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.high_fuses=0xDE
                          32PinBoard.menu.mhz.8Mi-38K4-D8.build.f_cpu=8000000L
                          32PinBoard.menu.mhz.8Mi-38K4-D8.upload.speed=38400
                          32PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.file=myoptiboot/optiboot_atmega328_08M_038400_D8.hex
                          alexsh1A 1 Reply Last reply
                          • G GertSanders
                            @alexsh1
                            alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            @GertSanders OK, the issue is in pins_arduino.h in 32PinBoard folder. The standard file is just not good. I'll have to find the right one for tqfp chip.
                            EDIT: copied the "eightanaloginputs" variant in the variant folder, but still can only upload the first sketch after the bootloader, all other uploads are giving me "avrdude: stk500_getsync() attempt x of 10: not in sync:"
                            • alexsh1A alexsh1
                              alexsh1A Offline
                              alexsh1A Offline
                              alexsh1
                              @GertSanders Gert, what pins_arduino.h are you using for this board please? Can you post it here?
                              G 2 Replies Last reply
                              • alexsh1A alexsh1
                                G Offline
                                G Offline
                                GertSanders
                                @alexsh1
                                Here is the pins_arduino.h file for the 32pin TQFP package
                                0_1465854245099_pins_arduino.h
                                • alexsh1A alexsh1
                                  G Offline
                                  G Offline
                                  GertSanders
                                  @alexsh1
                                  And here is a ZIP file with my complete atmega328p definitions
                                  0_1465854396475_atmega328p.zip
                                  • G GertSanders
                                    @alexsh1
                                    alexsh1A Offline
                                    alexsh1A Offline
                                    alexsh1
                                    @GertSanders Many thanks for your help. This is probably my bad luck, but I have mixed up C1 and R1 mounting them vertically (not horizontally). What a stupid mistake really given that I have checked it a few times. Anyway, now everything is working.
                                    FYG, I looked at your pins_arduino.h - this is a standard one and it is not correct. I corrected the following entries:
                                    static const uint8_t SS   = 14;
                                    static const uint8_t MOSI = 15;
                                    static const uint8_t MISO = 16;
                                    static const uint8_t SCK  = 17;
                                    static const uint8_t SDA = 27;
                                    static const uint8_t SCL = 28;
                                    #define LED_BUILTIN 8
                                    static const uint8_t A0 = 23;
                                    static const uint8_t A1 = 24;
                                    static const uint8_t A2 = 25;
                                    static const uint8_t A3 = 26;
                                    static const uint8_t A4 = 27;
                                    static const uint8_t A5 = 28;
                                    static const uint8_t A6 = 19;
                                    static const uint8_t A7 = 22;
                                    • alexsh1A alexsh1
                                      G Offline
                                      G Offline
                                      GertSanders
                                      @alexsh1
                                      OK, I will check also on my side :-) Thanks for the feedback.
                                      • G GertSanders
                                        @alexsh1
                                        alexsh1A Offline
                                        alexsh1A Offline
                                        alexsh1
                                        @GertSanders No worries! And signing works flawlessly on this node as well with ATSHA204A by the way :)
                                        • alexsh1A Offline
                                          alexsh1A Offline
                                          alexsh1
