  3. 💬 Stamp size MySensor node
atmega328atsha204acoincellmysensor
50 Posts 13 Posters 17.7k Views 11 Watching
    nice, your tqfp seems well soldered ;)
    • carlierdC
      carlierdC
      carlierd
      Very good ! So small !
      I really need to learn how solder SMD part ! More and more design are using small components.
      • sundberg84S
        sundberg84S
        Well done! Nice!
        • macieiksM
          macieiksM
          macieiks
          I have a question about the dimensions. Could you tell me what is the exact measure when fully assembled with nrf24 and with / without goldpins? I have tiny, transparent boxes and curious if I can fit them inside :D
          RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
          RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
          RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
          • macieiksM macieiks
            GertSandersG
            GertSandersG
            GertSanders
            @macieiks
            The pcb itself is 21 mm wide and 23 mm long.
            With the radio the longest side becomes 30 mm long and 21 mm wide.
            Without any pins mounted, the board is just under 5 mm think.
            If the dual row angled headers are mounted, the longest side (30 mm with radio) becomes 39 mm.
            You will need to add the length of the contacts + wire to that for a complete length.
            You can also turn the dual row angled header inwards (towards the radio), then the maximum length is still 30 mm.
            • GertSandersG GertSanders
              @macieiks
              @GertSanders What is the difference between the v1 version of your stamp size mysensor node that's on OSH PARK and the V2 version that's on your website that you linked to in your OP ( https://www.openhardware.io/view/76/Stamp-size-MySensor-node )?
                GertSandersG
                GertSandersG
                GertSanders
                None. The plan was to enhance it, so I copied my version 1 to version 2. But then I decided to publish it in Openhardware anyway.
                This board is a proof of concept for me.
                My next version will have a 8Mhz crystal. The addional powerconsumption is negligable bit the accuracy of timing is much better (and constant, even with dropping voltage).
                So the board on OSH Park is identical to the one on Openhardware.io
                  Thanks! I ordered it yesterday from OSH PARK, so good to hear.
                  Have you found something where you really do need the 8mhz crystal oscillator, or were you adding it as a "just in case"?
                    GertSandersG
                    GertSandersG
                    GertSanders
                    I have a use case where I need the clock to be acurate. For realy low power nodes like the ones with reed switches, I also prefer the internal oscillator.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @GertSanders
                      Goedenavond Gert,
                      What's your boards.txt file is saying please? I uploaded the bootloader (optiboot_atmega328_08M_038400_D8) and all went OK until I upload my first sketch.
                      After that I am getting:
                      avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x32
                      avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0f
                      avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfb
                      avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x32
                      avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0f
                      avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x73
                      avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xff
                      avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x32
                      avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0f
                      avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfb
                      I have to upload the bootloader again in order to upload the sketch - something is clearly not working. This is my extract from boards.txt:
                      BlueBoard.menu.mhz.8Mhz= 8Mhz - internal oscillator D8 LED for atmega328-tqfp
                      BlueBoard.menu.mhz.8Mhz.bootloader.low_fuses=0xE2
                      BlueBoard.menu.mhz.8Mhz.bootloader.high_fuses=0xDE
                      BlueBoard.menu.mhz.8Mhz.build.f_cpu=8000000L
                      BlueBoard.menu.mhz.8Mhz.upload.speed=38400
                      BlueBoard.menu.mhz.8Mhz.bootloader.file=myoptiboot/optiboot_atmega328_08M_038400_D8.hex
                      • alexsh1A alexsh1
                        @GertSanders
                        Goedenavond Gert,
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @alexsh1
                        Here is my extract for this type:
                        32PinBoard.name=atmega328p based - 32 pin TQFP
                        32PinBoard.upload.tool=arduino:avrdude
                        32PinBoard.upload.protocol=arduino
                        32PinBoard.upload.maximum_size=32256
                        32PinBoard.upload.maximum_data_size=2048
                        32PinBoard.bootloader.tool=arduino:avrdude
                        32PinBoard.bootloader.unlock_bits=0x3F
                        32PinBoard.bootloader.lock_bits=0x0F
                        32PinBoard.build.core=arduino:arduino
                        32PinBoard.build.mcu=atmega328p
                        32PinBoard.build.board=AVR_GERTSANDERS32PinBoard
                        32PinBoard.build.variant=32PinBoard
                        32PinBoard.menu.bod.4v3=4V3
                        32PinBoard.menu.bod.4v3.bootloader.extended_fuses=0x04
                        32PinBoard.menu.bod.2v7=2V7
                        32PinBoard.menu.bod.2v7.bootloader.extended_fuses=0x05
                        32PinBoard.menu.bod.1v8=1V8
                        32PinBoard.menu.bod.1v8.bootloader.extended_fuses=0x06
                        32PinBoard.menu.bod.off=Disabled
                        32PinBoard.menu.bod.off.bootloader.extended_fuses=0x07
                        32PinBoard.menu.mhz.8Mi-38K4-D8= 8Mhz - internal - 38K4 - D8
                        32PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.low_fuses=0xE2
                        32PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.high_fuses=0xDE
                        32PinBoard.menu.mhz.8Mi-38K4-D8.build.f_cpu=8000000L
                        32PinBoard.menu.mhz.8Mi-38K4-D8.upload.speed=38400
                        32PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.file=myoptiboot/optiboot_atmega328_08M_038400_D8.hex
                        alexsh1A 1 Reply Last reply
                          @alexsh1
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @GertSanders OK, the issue is in pins_arduino.h in 32PinBoard folder. The standard file is just not good. I'll have to find the right one for tqfp chip.
                          EDIT: copied the "eightanaloginputs" variant in the variant folder, but still can only upload the first sketch after the bootloader, all other uploads are giving me "avrdude: stk500_getsync() attempt x of 10: not in sync:"
                          • alexsh1A alexsh1
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @GertSanders Gert, what pins_arduino.h are you using for this board please? Can you post it here?
                            GertSandersG 2 Replies Last reply
                            • alexsh1A alexsh1
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @alexsh1
                              Here is the pins_arduino.h file for the 32pin TQFP package
                              0_1465854245099_pins_arduino.h
                              • alexsh1A alexsh1
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @alexsh1
                                And here is a ZIP file with my complete atmega328p definitions
                                0_1465854396475_atmega328p.zip
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @GertSanders Many thanks for your help. This is probably my bad luck, but I have mixed up C1 and R1 mounting them vertically (not horizontally). What a stupid mistake really given that I have checked it a few times. Anyway, now everything is working.
                                  FYG, I looked at your pins_arduino.h - this is a standard one and it is not correct. I corrected the following entries:
                                  static const uint8_t SS   = 14;
                                  static const uint8_t MOSI = 15;
                                  static const uint8_t MISO = 16;
                                  static const uint8_t SCK  = 17;
                                  static const uint8_t SDA = 27;
                                  static const uint8_t SCL = 28;
                                  #define LED_BUILTIN 8
                                  static const uint8_t A0 = 23;
                                  static const uint8_t A1 = 24;
                                  static const uint8_t A2 = 25;
                                  static const uint8_t A3 = 26;
                                  static const uint8_t A4 = 27;
                                  static const uint8_t A5 = 28;
                                  static const uint8_t A6 = 19;
                                  static const uint8_t A7 = 22;
                                  • alexsh1A alexsh1
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    @alexsh1
                                    OK, I will check also on my side :-) Thanks for the feedback.
                                      @alexsh1
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @GertSanders No worries! And signing works flawlessly on this node as well with ATSHA204A by the way :)
                                      • alexsh1A
                                        alexsh1A
                                        alexsh1
                                        • alexsh1A alexsh1
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @alexsh1
                                          Double plus good !
                                          As I have no signing capability on my raspberry-turned-gateway I'm glad the hard work to simplify signing was done so well by @tbowmo and @Anticimex. Even without testing it I could assume it would work.
                                          AnticimexA 1 Reply Last reply
