  3. 💬 Stamp size MySensor node
atmega328atsha204acoincellmysensor
50 Posts 13 Posters 17.7k Views 11 Watching
    Thanks! I ordered it yesterday from OSH PARK, so good to hear.
    Have you found something where you really do need the 8mhz crystal oscillator, or were you adding it as a "just in case"?
    GertSandersG
    GertSandersG
    GertSanders
    I have a use case where I need the clock to be acurate. For realy low power nodes like the ones with reed switches, I also prefer the internal oscillator.
    • alexsh1A
      alexsh1A
      alexsh1
      @GertSanders
      Goedenavond Gert,
      What's your boards.txt file is saying please? I uploaded the bootloader (optiboot_atmega328_08M_038400_D8) and all went OK until I upload my first sketch.
      After that I am getting:
      avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x32
      avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0f
      avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfb
      avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x32
      avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0f
      avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x73
      avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xff
      avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x32
      avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0f
      avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfb
      I have to upload the bootloader again in order to upload the sketch - something is clearly not working. This is my extract from boards.txt:
      BlueBoard.menu.mhz.8Mhz= 8Mhz - internal oscillator D8 LED for atmega328-tqfp
      BlueBoard.menu.mhz.8Mhz.bootloader.low_fuses=0xE2
      BlueBoard.menu.mhz.8Mhz.bootloader.high_fuses=0xDE
      BlueBoard.menu.mhz.8Mhz.build.f_cpu=8000000L
      BlueBoard.menu.mhz.8Mhz.upload.speed=38400
      BlueBoard.menu.mhz.8Mhz.bootloader.file=myoptiboot/optiboot_atmega328_08M_038400_D8.hex
      • alexsh1A alexsh1
        @GertSanders
        Goedenavond Gert,
        GertSandersG
        GertSandersG
        GertSanders
        @alexsh1
        Here is my extract for this type:
        32PinBoard.name=atmega328p based - 32 pin TQFP
        32PinBoard.upload.tool=arduino:avrdude
        32PinBoard.upload.protocol=arduino
        32PinBoard.upload.maximum_size=32256
        32PinBoard.upload.maximum_data_size=2048
        32PinBoard.bootloader.tool=arduino:avrdude
        32PinBoard.bootloader.unlock_bits=0x3F
        32PinBoard.bootloader.lock_bits=0x0F
        32PinBoard.build.core=arduino:arduino
        32PinBoard.build.mcu=atmega328p
        32PinBoard.build.board=AVR_GERTSANDERS32PinBoard
        32PinBoard.build.variant=32PinBoard
        32PinBoard.menu.bod.4v3=4V3
        32PinBoard.menu.bod.4v3.bootloader.extended_fuses=0x04
        32PinBoard.menu.bod.2v7=2V7
        32PinBoard.menu.bod.2v7.bootloader.extended_fuses=0x05
        32PinBoard.menu.bod.1v8=1V8
        32PinBoard.menu.bod.1v8.bootloader.extended_fuses=0x06
        32PinBoard.menu.bod.off=Disabled
        32PinBoard.menu.bod.off.bootloader.extended_fuses=0x07
        32PinBoard.menu.mhz.8Mi-38K4-D8= 8Mhz - internal - 38K4 - D8
        32PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.low_fuses=0xE2
        32PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.high_fuses=0xDE
        32PinBoard.menu.mhz.8Mi-38K4-D8.build.f_cpu=8000000L
        32PinBoard.menu.mhz.8Mi-38K4-D8.upload.speed=38400
        32PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.file=myoptiboot/optiboot_atmega328_08M_038400_D8.hex
        alexsh1A 1 Reply Last reply
        • GertSandersG GertSanders
          @alexsh1
          alexsh1A
          alexsh1A
          alexsh1
          @GertSanders OK, the issue is in pins_arduino.h in 32PinBoard folder. The standard file is just not good. I'll have to find the right one for tqfp chip.
          EDIT: copied the "eightanaloginputs" variant in the variant folder, but still can only upload the first sketch after the bootloader, all other uploads are giving me "avrdude: stk500_getsync() attempt x of 10: not in sync:"
          • alexsh1A alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            @GertSanders Gert, what pins_arduino.h are you using for this board please? Can you post it here?
            GertSandersG 2 Replies Last reply
            • alexsh1A alexsh1
              GertSandersG
              GertSandersG
              GertSanders
              @alexsh1
              Here is the pins_arduino.h file for the 32pin TQFP package
              0_1465854245099_pins_arduino.h
              • alexsh1A alexsh1
                GertSandersG
                GertSandersG
                GertSanders
                @alexsh1
                And here is a ZIP file with my complete atmega328p definitions
                0_1465854396475_atmega328p.zip
                  @alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @GertSanders Many thanks for your help. This is probably my bad luck, but I have mixed up C1 and R1 mounting them vertically (not horizontally). What a stupid mistake really given that I have checked it a few times. Anyway, now everything is working.
                  FYG, I looked at your pins_arduino.h - this is a standard one and it is not correct. I corrected the following entries:
                  static const uint8_t SS   = 14;
                  static const uint8_t MOSI = 15;
                  static const uint8_t MISO = 16;
                  static const uint8_t SCK  = 17;
                  static const uint8_t SDA = 27;
                  static const uint8_t SCL = 28;
                  #define LED_BUILTIN 8
                  static const uint8_t A0 = 23;
                  static const uint8_t A1 = 24;
                  static const uint8_t A2 = 25;
                  static const uint8_t A3 = 26;
                  static const uint8_t A4 = 27;
                  static const uint8_t A5 = 28;
                  static const uint8_t A6 = 19;
                  static const uint8_t A7 = 22;
                  • alexsh1A alexsh1
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @alexsh1
                    OK, I will check also on my side :-) Thanks for the feedback.
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @GertSanders No worries! And signing works flawlessly on this node as well with ATSHA204A by the way :)
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        • alexsh1A alexsh1
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @alexsh1
                          Double plus good !
                          As I have no signing capability on my raspberry-turned-gateway I'm glad the hard work to simplify signing was done so well by @tbowmo and @Anticimex. Even without testing it I could assume it would work.
                          AnticimexA 1 Reply Last reply
                            @alexsh1
                            Double plus good !
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @GertSanders You are welcome :) Btw, if you just patch in support to generate random data for a nonce, you can use the soft signing backend on rPi.
                            • AnticimexA Anticimex
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @Anticimex
                              Well that sounds simple, but I'm more a hardware contributer, this is beyond my capabilities :-), especially in unix arena. I manage software developers for a living, so I know how much I do not know.
                              • macieiksM
                                macieiksM
                                macieiks
                                Hello guys,
                                I am about to solder first PCB of this version. Just to be 100% sure, regarding C4 - what is the best value to use 1uF or 10uF, because I can see we can choose.
                                Regards,
                                Maciek
                                RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
                                RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
                                RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
                                • macieiksM macieiks
                                  Hello guys,
                                  Regards,
                                  Maciek
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @macieiks
                                  Better to use 10uF. The schematic needs to be updated (still shows 1uF, I use 10uF now).
                                  • macieiksM
                                    macieiksM
                                    macieiks
                                    @GertSanders
                                    Thank you for the update,
                                    Last part what I am missing is battery holder. I was trying to search it in many stores located in my country however I was not able to get it. Is there any internet shop when I can buy online? I have one workaround to soldier different CR battery holder and connect via wires.
                                      @GertSanders
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @macieiks I bought the battery holder on http://www.ebay.co.uk/
                                      AWIA 1 Reply Last reply
                                      • alexsh1A alexsh1
                                        AWIA
                                        AWIA
                                        AWI
                                        @alexsh1 The link directs me to ebay home page... (possibly a country issue) can you give the name of the item so I can search?
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #29
                                          @AWI I just put a link to an eBay. You put "Keystone 3013" in the search and hit search :-)
                                          http://www.ebay.co.uk/itm/KEYSTONE-3013-BATTERY-THM-RETAINER-16MM-/271911714571?hash=item3f4f337f0b:g:PsQAAOxyx-BSa7y-
