  3. Homini Complete Room Sensor Module?
ceilingmotionsensorsgas sensorlight sensorhominihumidityceiling mountsmoke detectortemperaturemodulecomplete roomlight
81 Posts 7 Posters 41.2k Views 14 Watching
  • D Dwalt
    @Samuel235 said:
    Motion Detection
    Would you guys rather the motion detection be connected via a transistor so we can send messages to the node to enable and disable the motion side of the module rather than having motion being detected at all times?.
    If not to save power, would not a software solution be easier and less complicated solution?
    Samuel235
    @Dwalt said:
    @Samuel235 said:
    Motion Detection
    You're correct in this scenario, however i've since decided to brong the power consumption as low as i can physically for two reasons; to bring the running costs of the module down as low as possible snd to allow me to adapt this board for use with batteries if ever it needed to.
    D 1 Reply Last reply
    • S Samuel235
      @Dwalt said:
      @Samuel235 said:
      Motion Detection
      Dwalt
      @Samuel235
      I was under the assumption you intended this module to be always 'listening' to allow a controller to set it to night mode or 'disarm'. If so, battery power will be tricky. In addition, PIRs require a period of stabilization when powered on, often up to 30 seconds to calibrate sensor field of view background.
      S 1 Reply Last reply
      • D Dwalt
        @Samuel235
        Samuel235
        @Dwalt, you're right with the intention is to be listening all the time, and then therefor it would mean that sleeping the node for battery power is not going to work. However, i was planning to do this as a backup solution and then for incase i needed the feature. If this was needed to go to battery power it was able to switch off the motionI probably wont ever have a need for it, but its there if needed.
        To go a step futher i could find a PIR Control IC, i remember reading somewhere that a fee controllers allow a PIR Sensor to be active when not even powered up. I might be wrong here but either way i understand your information regarding a warm up time on the motion module.
        Thank you.
        • S Offline
          Samuel235
          #39
          UPDATE
          So then guys. I feel I have the sensing side of the board all designed out, I will include a schematic here for you to see. Just due to my inexperience of electronics still, i'm sure there will be a few faults/things you guys would like me to change around. Please point anything of any concern out to my attention and i will amend accordingly.
          Sensors
          Light: OPT3001
          Motion: HC-SR501 Module
          Temperature & Humidity: SHT21
          Carbon Monoxide: TGS5042
          Smoke1: Custom Photoelectric Circuit
          Smoke2: MQ-2.
          The smoke sensors can both be fitted or one or the other. They will differ in applications, what area the module is being used in. They both detect different types of smoke/fires. I will included more detailed information on this for the release of the product.
          Powering
          I'm still yet to design the powering side of this, it will be 240VAC converted to 5VDC then regulated as and when needed. I Will include some way to externally power this module while we're programming it since it will draw more than i'm comfortable providing through a PC USB Socket. So there will be no VCC lines coming onto the board from the USB programmers, this way we can't cause any damage to your PC USB sockets/serial lines. I'm yet to work out the overall typical power consumption, which i do plan on calculating today so i can get the powering converters specified for the current needed.
          Prototyping
          If there is any pins left, currently have 5 pins (3 Analog and 2 Digital) left over, however i'm very tempted to have status LEDs on this module so therefor that will be 3 gone and will only leave possibly 2 empty analog pins. These will have VIAs located so we can use them for prototyping.
          By no means is this schematic anywhere near completion, there may be floating connections or missing components. Please point them out if so.
          Excuse the unfinished power circuit at the top of the schematic, this is where i've got to so far before i ran out of time. Currently just placed the varistor and the AC/DC Converter. Will keep updating as and when time allows.
          • S Offline
            Samuel235
            • S Offline
              Samuel235
              Updated the schematic in the post above. Please read the notes in bold above the image. Thanks.
              • S Offline
                Samuel235
                Could i get some opinions regarding atmels signing IC's that we use for mysensor signing. Would you guys like this module to use that feature?
                I may need some external flash for OTA firmware updates but i'm not sure if i want to include this on Rev1, maybe this is a Rev2 upgrade.
                I doubt i will need any extra eeprom external from the amount built into the 328p mcu, we shall see about that when the software is made.
                Lastly, is there any additional features that you guys would like to see implimented onto this module that you feel is missing? Any errors so far with the schematic you can see?
                • S Offline
                  Samuel235
                  Another little bit of progress. I'm really struggling with time at the moment, had another 15 minutes to get some schematics done today. The power circuitry is coming along now, just the external programming power to sort out.
                  • S Offline
                    Samuel235
                    And the first of many to arrive is the Figaro Carbon Monoxide sensor.
                    • S Offline
                      Samuel235
                      There is a topic (here) being discussed regarding the use of IR LEDs and receivers to determine the circuit needed before i get some hardware. I will be ordering parts before the end of this week so if there is no suggestions i will be purchasing materials to trial and test the best setup for this.
                      Another subject to be discussed is powering while programming. I do propose to have the module fully powered up while programming and debugging to allow the monitoring of the sensor readings to allow debugging methods to be carried out with the best precision possible. However, this means that we need to have some sort of external connector on board to provide power while we're plugged into our programming systems. There would be two ways to go around this, one will allow full powered up mode for the board and the other will just allow power to the MCU and Radio while programming.
                      1. Add external connector (I'm feeling maybe a USB Mini-B simply due to its popularity). This would then power up the board completely while programming is completed, allowing full debug viewing through serial monitor.
                      2. Add a jumper on the power line of the MCU and Radio module to allow the programmer to provide enough power for the MCU and Radio while programming. This would mean that the only debugging we can do through the serial monitor would be MCU and Radio related.
                      Any input would be greatly appreciated.
                      • S Offline
                        Samuel235
                        The remaining parts have been ordered to get the prototyping under way. Plan of attack will be:
                        1. Prototype each circuit on breadboards separately to make sure each is working as intended and giving the correct results.
                        2. Combine all of the circuitry apart from the powering options onto breadboard as one working module, get some software written up with the help of a few guides, tutorials and a fellow member of our community being interested in joining me on this module.
                        3. Generate PCB designs and have them manufactured.
                        4. Test the AC/DC conversion circuitry for a few weeks while the PCB is on order.
                        5. Receive the PCBs and populate with the breadboarded circuit.
                        6. Fashion some sort of enclosure, hoping to have purchased a 3d printer by then.
                        Does anyone have any experience with a prusa I3 3d printer?
                        • S Offline
                          Samuel235
                          Infrared smoke detection circuitry has changed now. It is now going to running as a single IR LED coming from the MCU pin since we do not need any sort of frequency for a newly implemented photo transistor rather than the IR receiver. However, I may have it coming through the 555 time to just turn the LED on for 1 second every 10 seconds or so to stop excessive power draw for no reason. If it detects smoke 10 seconds later than it was first present inside of the chamber, that is fine for the needs of a smoke detector. In my opinion. If you feel otherwise please state so!
                          I have chosen to do this outside of software to save having to do multitasking in software. This way all that the MCU needs to know is if the photo transistor has detected any smoke, which we can monitor on every loop of the MCU.
                          I'm still not sure whether to go down the 555 timer route for the siren to sound or to use some soft of PWM function on the MCU. The way i'm thinking is that if we go down the timer route it releaves the MCU of another job and therefor it doesn't have to stall in the loop while its powering the buzzer. However, I personally feel that if the module detects smoke, the last thing that we will be worried about is if its taking readings from the other sensors. But then that would be a cool feature to be able to look back at the measurements on.
                          • S Offline
                            Samuel235
                            #48
                            I would like to separate the 3v3 to the MCU and the radio from the rest of the components, this way i can safely power the MCU and Radio with the programmer when uploading software with just the programmer attached. But i want it so if it is powered externally i would like the board to use that power.
                            I'm proposing the use of diode(s) on the power lines in between the MCU and radio to stop the flow going out to the rest of the circuit. I'm hoping that by using the diode(s) to stop the 3v3 from the programming feeding to the whole 3v3 circuit it will not draw enough current to damage the programmer and the PC. By using this diode i believe that the MCU and Radio will draw the strongest voltage of whatever is connected, if nothing is connected other than the FTDI or ISP programmer then it will only power on the MCU and Radio. A quick hand drawn sketch below:
                            Do you feel i'm going about this the correct way rather than separating the MCU and radio with a hardware jumper? One less thing to care about while programming in my opinion.
                            • S Offline
                              Samuel235
                              And the prototyping begins! Pretty much all of the breadboard versions of parts have arrived and i will be prototyping each circuit individually then wrapping it all together. A few mods need to be done to the light sensor to make it breadboard friendly but its doable!
                              • S Samuel235
                                Dwalt
                                @Samuel235 Did you source a breakout version of the OPT3001? It is hard to find.
                                S 2 Replies Last reply
                                • D Dwalt
                                  Samuel235
                                  @Dwalt, unfortunately no mate, i will need to solder leads to the pads for prototyping needs 😞
                                  • D Dwalt
                                    Samuel235
                                    @Dwalt, this is the one i was looking at but then decided to just solder leads to the sensor itself instead. If i were to get some breakout boards made and maybe solder the sensors on myself, i wonder what the demand would be like, just thinking if its worth doing to help us out.
                                    • S Offline
                                      #53
                                      @Samuel235
                                      wow, soldering leads on opt3001!
                                      That won't be easy I think, I hope you have very very thin wire and iron! and still not sure...it's a small 2mmx2mm, and delicate, I think you can easily skip this step, it's a simple i2c sensors, no surprise...or maybe you will waste some money if no good tools. I prefer to design evalboards than soldering leads on tiny dfn (doable sometimes but very tricky), it's easier to breadboard and reusable ;)
                                      @dwalt
                                      One thing I could do is to release some evalboards I have designed. As it's small, it's cheap at oshpark...I have already made one for opt3001, and have some for others sensors, boosters, buck, buckboost..but I'm little busy actually!
                                      But if I do this you would still have to solder it on pcb, or I should look at the new pcba service...
                                      • S scalz
                                        @Samuel235
                                        @dwalt
                                        Samuel235
                                        @scalz It seems you have beat me to it with creating a breadboard friendly breakout board for them. If you're confident in the use of this sensor could you double check my schematic and let me know if i have connected it correctly please?
                                        I might get a breakout board for breadboard friendly use designed if you're too busy yourself. Not sure how much call there is for them though.
                                        • S Offline
                                          @Samuel235 it's few months I did this. like I said I make breakout boards for testing, so I have a small collection now!
                                          This was a breakout with opt3001 and si7021, regulator onboard (with smd jumper to power directly with 3.3v), and few pullups. Same pinout as common chinese sensor boards + interrupt pin for ambiant light:
                                          I will upload at openhardware asap ;) that's lot of things to upload lol!
