  2. Bug Reports
  3. Radio fails to init on W5100
19 Posts 7 Posters 7.8k Views 5 Watching
  • ximinezX
    ximinezX
    ximinez
    I updated to dev branch yesterday, and on my W5100 gateway the radio now fails to initialize:
    0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0-beta)
    0;255;3;0;9;write register, reg=0, value=6
    0;255;3;0;9;write register, reg=3, value=3
    0;255;3;0;9;write register, reg=4, value=95
    0;255;3;0;9;write register, reg=5, value=76
    0;255;3;0;9;write register, reg=6, value=35
    0;255;3;0;9;read register, reg=6, value=255
    0;255;3;0;9;Sanity check failed: RF_SETUP register=255 instead of 35, check wiring, replace module or non-P version
    0;255;3;0;9;Radio init failed. Check wiring.
    I've tried three different (confirmed working on my sensebender micro) radios, I've quadruple-checked my wiring, and I haven't changed the pins. So something is funky after the RF24 refactor.
      You're aware that the 5100 gateway sketch enabled SoftSPI (which requires another radio wiring).?
      • ximinezX
        ximinezX
        ximinez
        Yes. When I say that I haven't changed the pins, I mean that I haven't changed the physical pins (or the CE/CSN numbers in my sketch) compared to when the same setup worked with the previous RF24 driver.
        I love the difference in available space the new driver gives, but I'd love it even more if the radio continued to work :-P
        tekkaT 1 Reply Last reply
          Guess we have to call in @tekka here. Wonder if he switched/altered some config when using SoftSPI perhaps.
          • ximinezX ximinez
            tekkaT
            tekkaT
            tekka
            @ximinez can you describe your exact settings, wiring and hardware, I'll see if I can reproduce the same behaviour here.
            • ximinezX
              ximinezX
              ximinez
              wrote on last edited by ximinez
              #define MY_DEBUG_VERBOSE_RF24
              #define MY_GATEWAY_W5100
              #define MY_SIGNING_SOFT
              #define MY_RF24_CE_PIN 5
              #define MY_RF24_CS_PIN 6
              Using an UNO with an ethernet shield, wired up like this: https://www.mysensors.org/build/ethernet_gateway
              A2 MISO
              A1 MOSI
              A0 SCK
              6 CSN
              5 CE
              • ximinezX ximinez
                A2 MISO
                A1 MOSI
                A0 SCK
                6 CSN
                5 CE
                tekkaT
                tekkaT
                tekka
                @ximinez Just tested your setup/settings using an Arduino UNO + W5100 shield and I can confirm, that SOFTSPI (A2=MISO, A1=MOSI, A0=SCK, D6=CSN, D5=CE) and HWSPI (D12=MISO, D11=MOSI, D13=SCK, D6=CSN, D5=CE + #define MY_W5100_SPI_EN 4) work with the refactored RF24 driver.
                Please double check you are using the most recent MySensors 2.0.0-beta lib and GatewayW5100 sketch.
                ximinezX 1 Reply Last reply
                • tekkaT tekka
                  ximinezX
                  ximinezX
                  ximinez
                  I just did (for the second time), and lo and behold it works. Absolutely no clue why, but I'm sorry I've wasted your time.
                  My gateway can finally have DHCP and signing at the same time :)
                  • ximinezX ximinez
                    tekkaT
                    tekkaT
                    tekka
                    wrote on last edited by tekka
                    @ximinez excellent :+1: HWSPI uses even less space and saves some analog pins.
                    @hek, AFAIK the initial issues with shared SPI lines and W5100 seem gone - we can eventually update the ethernet gw build instructions...
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @tekka
                      It depends on the module manufacturer. If they use the correct pin for CE, then it's possible. Otherwise the W5100 chip itself hold MISO line low, when the chip is not selected, effectively blocking the spi for other uses
                      So to keep things safe, I suggest that we keep the soft spi option.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @tekka
                        found this document http://www.i-vis.co.jp/pdf/wiznet/tcpip_chip/w3150a+/W5100_AN_SPI.pdf
                        Look at page 3 "Multiple SPI Slave Usage". It describes the problem with W5100.
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          Some W5100 boards also have a SPI-enable signal which can be used to turn off drivers from W5100 when the bus is used elsewhere. That is, enable it only when the W5100 is addressed. I used this in my sketch when I had a W5100-based ethernet gw but I don't think all modules offer this possibility.
                          • AnticimexA Anticimex
                            tekkaT
                            tekkaT
                            tekka
                            Yeah, I think it's mainly applicable for the "dual" W5100 shield with SD card adapter.
                            • ximinezX
                              ximinezX
                              ximinez
                              Both soft and hard SPI work on my cheap W5100 clone shield (with SD).
                              • bisschopsrB
                                bisschopsrB
                                bisschopsr
                                All,
                                Is the content of this topic still valid? All my wiring is according to the intructions (and this topic). I get the following errors:
                                0;255;3;0;9;TSM:INIT
                                0;255;3;0;9;RF24:write register, reg=0, value=14
                                0;255;3;0;9;RF24:write register, reg=3, value=3
                                0;255;3;0;9;RF24:write register, reg=4, value=95
                                0;255;3;0;9;RF24:write register, reg=5, value=76
                                0;255;3;0;9;RF24:write register, reg=6, value=39
                                0;255;3;0;9;RF24:read register, reg=6, value=255
                                0;255;3;0;9;RF24:read register, reg=5, value=255
                                0;255;3;0;9;RF24:Sanity check failed: configuration mismatch! Check wiring, replace module or non-P version
                                0;255;3;0;9;!TSM:RADIO:FAIL
                                0;255;3;0;9;!TSM:FAILURE
                                0;255;3;0;9;TSM:PDT
                                0;255;3;0;9;RF24:write register, reg=0, value=12
                                0;255;3;0;9;RF24:power down
                                Note: I did fiddle around with the radio channel settings in myconfig.h, reinstalled the original myconfig.h though.
                                Thx
                                Ralph
                                Domoticz, P1 meter interface, MySensors and more to come!
                                • bisschopsrB bisschopsr
                                  All,
                                  0;255;3;0;9;TSM:PDT
                                  Thx
                                  Ralph
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @bisschopsr looks like a SPI issue (return value 255 hints to that).
                                  edit: Is this referring to the same issue: https://forum.mysensors.org/topic/4662/ethernet-gateway-with-w5100-radio-error-solved/3 ?
                                  bisschopsrB 2 Replies Last reply
                                  • ximinezX ximinez
                                    @ximinez I also use a w5100 shield with SD card and I need to initialize the cs line of the SD card to high in the before() method, so before mysensors start (when using hardware spi) .
                                    Otherwise the SD card will also be selected on the spi bus during startup and radio init will fail.
                                    • tekkaT tekka
                                      bisschopsrB
                                      bisschopsrB
                                      bisschopsr
                                      @tekka: More or less. I wanted to know if the beta that was used in this thread still sticks with the content (does this make sense). It is supportive to my other question with the refered link.
                                      Thx
                                      Ralph
                                      • tekkaT tekka
                                        bisschopsrB
                                        bisschopsrB
                                        bisschopsr
                                        @tekka: In addition: the setup is working now, but not flawless. No radio connection between the node and the GW. But of course this is a different topic.
