  2. Bug Reports
  3. Radio fails to init on W5100
19 Posts 7 Posters 7.8k Views 5 Watching
  • ximinezX
    ximinezX
    ximinez
    Yes. When I say that I haven't changed the pins, I mean that I haven't changed the physical pins (or the CE/CSN numbers in my sketch) compared to when the same setup worked with the previous RF24 driver.
    I love the difference in available space the new driver gives, but I'd love it even more if the radio continued to work :-P
    tekkaT 1 Reply Last reply
      Guess we have to call in @tekka here. Wonder if he switched/altered some config when using SoftSPI perhaps.
      • ximinezX ximinez
        tekkaT
        tekkaT
        tekka
        @ximinez can you describe your exact settings, wiring and hardware, I'll see if I can reproduce the same behaviour here.
        • ximinezX
          ximinezX
          ximinez
          wrote on last edited by ximinez
          #define MY_DEBUG_VERBOSE_RF24
          #define MY_GATEWAY_W5100
          #define MY_SIGNING_SOFT
          #define MY_RF24_CE_PIN 5
          #define MY_RF24_CS_PIN 6
          Using an UNO with an ethernet shield, wired up like this: https://www.mysensors.org/build/ethernet_gateway
          A2 MISO
          A1 MOSI
          A0 SCK
          6 CSN
          5 CE
          • ximinezX ximinez
            A2 MISO
            A1 MOSI
            A0 SCK
            6 CSN
            5 CE
            tekkaT
            tekkaT
            tekka
            @ximinez Just tested your setup/settings using an Arduino UNO + W5100 shield and I can confirm, that SOFTSPI (A2=MISO, A1=MOSI, A0=SCK, D6=CSN, D5=CE) and HWSPI (D12=MISO, D11=MOSI, D13=SCK, D6=CSN, D5=CE + #define MY_W5100_SPI_EN 4) work with the refactored RF24 driver.
            Please double check you are using the most recent MySensors 2.0.0-beta lib and GatewayW5100 sketch.
            ximinezX 1 Reply Last reply
            • tekkaT tekka
              ximinezX
              ximinezX
              ximinez
              I just did (for the second time), and lo and behold it works. Absolutely no clue why, but I'm sorry I've wasted your time.
              My gateway can finally have DHCP and signing at the same time :)
              • ximinezX ximinez
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                @ximinez excellent :+1: HWSPI uses even less space and saves some analog pins.
                @hek, AFAIK the initial issues with shared SPI lines and W5100 seem gone - we can eventually update the ethernet gw build instructions...
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @tekka
                  It depends on the module manufacturer. If they use the correct pin for CE, then it's possible. Otherwise the W5100 chip itself hold MISO line low, when the chip is not selected, effectively blocking the spi for other uses
                  So to keep things safe, I suggest that we keep the soft spi option.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @tekka
                    found this document http://www.i-vis.co.jp/pdf/wiznet/tcpip_chip/w3150a+/W5100_AN_SPI.pdf
                    Look at page 3 "Multiple SPI Slave Usage". It describes the problem with W5100.
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      Some W5100 boards also have a SPI-enable signal which can be used to turn off drivers from W5100 when the bus is used elsewhere. That is, enable it only when the W5100 is addressed. I used this in my sketch when I had a W5100-based ethernet gw but I don't think all modules offer this possibility.
                      • AnticimexA Anticimex
                        tekkaT
                        tekkaT
                        tekka
                        Yeah, I think it's mainly applicable for the "dual" W5100 shield with SD card adapter.
                        • ximinezX
                          ximinezX
                          ximinez
                          Both soft and hard SPI work on my cheap W5100 clone shield (with SD).
                          • bisschopsrB
                            bisschopsrB
                            bisschopsr
                            All,
                            Is the content of this topic still valid? All my wiring is according to the intructions (and this topic). I get the following errors:
                            0;255;3;0;9;TSM:INIT
                            0;255;3;0;9;RF24:write register, reg=0, value=14
                            0;255;3;0;9;RF24:write register, reg=3, value=3
                            0;255;3;0;9;RF24:write register, reg=4, value=95
                            0;255;3;0;9;RF24:write register, reg=5, value=76
                            0;255;3;0;9;RF24:write register, reg=6, value=39
                            0;255;3;0;9;RF24:read register, reg=6, value=255
                            0;255;3;0;9;RF24:read register, reg=5, value=255
                            0;255;3;0;9;RF24:Sanity check failed: configuration mismatch! Check wiring, replace module or non-P version
                            0;255;3;0;9;!TSM:RADIO:FAIL
                            0;255;3;0;9;!TSM:FAILURE
                            0;255;3;0;9;TSM:PDT
                            0;255;3;0;9;RF24:write register, reg=0, value=12
                            0;255;3;0;9;RF24:power down
                            Note: I did fiddle around with the radio channel settings in myconfig.h, reinstalled the original myconfig.h though.
                            Thx
                            Ralph
                            Domoticz, P1 meter interface, MySensors and more to come!
                            • bisschopsrB bisschopsr
                              All,
                              0;255;3;0;9;TSM:PDT
                              Thx
                              Ralph
                              tekkaT
                              tekkaT
                              tekka
                              @bisschopsr looks like a SPI issue (return value 255 hints to that).
                              edit: Is this referring to the same issue: https://forum.mysensors.org/topic/4662/ethernet-gateway-with-w5100-radio-error-solved/3 ?
                              bisschopsrB 2 Replies Last reply
                              • ximinezX ximinez
                                @ximinez I also use a w5100 shield with SD card and I need to initialize the cs line of the SD card to high in the before() method, so before mysensors start (when using hardware spi) .
                                Otherwise the SD card will also be selected on the spi bus during startup and radio init will fail.
                                • tekkaT tekka
                                  bisschopsrB
                                  bisschopsrB
                                  bisschopsr
                                  @tekka: More or less. I wanted to know if the beta that was used in this thread still sticks with the content (does this make sense). It is supportive to my other question with the refered link.
                                  Thx
                                  Ralph
                                  • tekkaT tekka
                                    bisschopsrB
                                    bisschopsrB
                                    bisschopsr
                                    @tekka: In addition: the setup is working now, but not flawless. No radio connection between the node and the GW. But of course this is a different topic.
