  3. gw.sleep on battery powered magnet door switch
42 Posts 13 Posters 17.3k Views 16 Watching
  • ChakkieC Chakkie
    @AWI Thanks. By the way would you care to explain the interrupt index number? or may be a link for explanation?
    AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    @Chakkie In a few words.. The ATMEGA has two external interrupts 0 and 1 which are connected to pins 2 and 3. ("-2" translates the pin number to the interrupt number, which is rather confusing as @mfalkvidd meant)
    ChakkieC 1 Reply Last reply
      We should really get rid of the confusing "- 2" stuff in the examples and start using DigtalPinToInterrupt instead.
      I'm annoyed enough to see if I can create a pull request later this week.
      ChakkieC
      ChakkieC
      Chakkie
      @mfalkvidd Thanks for the info. Does DigitalPinTolnterrupt works better?
      Raspberry Pi 2
      Domoticz
      RFXCOM
      ZWAVE Aeon stick
      Coming soon Arduino mysensors GW
      • AWIA AWI
        ChakkieC
        ChakkieC
        Chakkie
        @AWI Thanks this clear thinks up but at the same time also confusing too.
        So "-2" activates both 0 and 1 on pin 2 or pin 3 as you mentioned earlier. I always though it represents a pin number.
        Raspberry Pi 2
        Domoticz
        RFXCOM
        ZWAVE Aeon stick
        AWIA 1 Reply Last reply
        • ChakkieC Chakkie
          AWIA
          AWIA
          AWI
          @Chakkie The function digitalPinToInterrupt(pin) translates the pin number to the attached interrupt like "-2" does but in a reliable and more understandable way.
          • AWIA AWI
            ChakkieC
            ChakkieC
            Chakkie
            @AWI thanks. this looks like more promising.
            Raspberry Pi 2
            Domoticz
            RFXCOM
            ZWAVE Aeon stick
            • mfalkviddM
              Pull request done for the development version: https://github.com/mysensors/Arduino/pull/441
              • siodS
                siodS
                siod
                I would like to build the same but I am still very confused now. Could you upload some pictures so I can make myself an image of how you wirde things together?
                Also I don´t really understand what happens here: gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000);
                still learning...
                • siodS siod
                  AWIA
                  AWIA
                  AWI
                  @siod If you are using a "standard" Atmega328 (pro-mini, etc.) don't make it hard for yourself. This processor has two external interrupts (0 & 1) connected to pins 2 & 3. Taking your line of code gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000); the arguments are respectively:
                  1. Use interrupt "0" (connected to pin 2 is BUTTON_PIN_Deur)
                  2. Have is fired on change (i.e Rising and Falling)
                  3. Use interrupt "1" (connected to pin 3 is BUTTON_PIN_Post)
                  4. Have is fired on change (i.e Rising and Falling)
                  5. Wake after every 86400000 ms (24 hrs) if no interrupt fired. To be safe you should use 86400000UL (the UL indicating that it is an Unsigned long type)
                  siodS 1 Reply Last reply
                  • AWIA AWI
                    siodS
                    siodS
                    siod
                    @AWI
                    Ok thx for explanation, but that means he is using 2 reed switches, right (interrupt at pin2 and int pin3)?
                    still learning...
                    • siodS siod
                      @AWI
                      AWIA
                      AWIA
                      AWI
                      @siod I guess so. But don't ask me why. One should be sufficient to detect if the door is open :smile:
                      In addition (and for what it is worth). If you use a real low power circuit you can save around a factor 3 on battery lifetime when you get rid of the timed wakeup. The arduino sleeps a lot better when it doesn't have to look at the alarm clock every few ms :zzz:
                      siodS ChakkieC 2 Replies Last reply
                      • AWIA AWI
                        siodS
                        siodS
                        siod
                        @AWI
                        yes, makes sense, but how should you do this wihout the wakeup ? I guess this is just the disadvantage one must accept...
                        still learning...
                        • siodS siod
                          @AWI
                          AWIA
                          AWIA
                          AWI
                          @siod The wakeup function can be disabled by setting the timer values to 0 (or omitting it). There is no purpose in the sketch above for what I can see. If you want to have a kind of "hey I am still alive"/heartbeat feature you need to do a little more (e.g. sending battery level)
                          172pilot1 1 Reply Last reply
                          • AWIA AWI
                            172pilot1
                            172pilot1
                            172pilot
                            @AWI I was going to ask about that.. I dont see any reason to wake up every 24 hours just to go back to sleep again.. I assume the radio doesn't have any reason to send a keepalive or anything? So, you can omit that number, and it will sleep until interrupted? That's cool..
                            -Steve
                            • 172pilot1 172pilot
                              -Steve
                              AWIA
                              AWIA
                              AWI
                              @172pilot yes, no reason to wake up. Especially if there is a regular wake-up from interrupt to let the controller know it it is alive
                              • AWIA AWI
                                ChakkieC
                                ChakkieC
                                Chakkie
                                wrote on last edited by Chakkie
                                #27
                                @AWI
                                Thanks for the info. I thought you always have to add the sleep time to the gw.sleep. I will disable the a wake timer by removing the 86400000.
                                @siod I use one switch for the letterbox and one for the door.
                                Raspberry Pi 2
                                Domoticz
                                RFXCOM
                                ZWAVE Aeon stick
                                • siodS
                                  siodS
                                  siod
                                  well, as you can see, if you don´t know the libraries exactly you accept things as they are or as they seem to be. I wasn´t aware that you can just set the wakeup function to 0. So this said I would like to thank you @AWI for your patience and your willingness of explaining also the most obvious things! :thumbsup:
                                  still learning...
                                  • T
                                    treb0r
                                    The sketch works with both reeds switches (2 windows) but how to integreate it with DS18B20 temp sensor? I also power it with battery, so I would like to check the temp eg every 5min and if it is changed then send the new value to the controler. How to wake up arduino only if any window is opened or temp is changed (after 5 min)
                                    treb0r
                                    dynamiteD 172pilot1 2 Replies Last reply
                                    • T treb0r
                                      treb0r
                                      dynamiteD
                                      dynamiteD
                                      dynamite
                                      @treb0r You can either wake up on the interrupt or on a time period:
                                      bool sleep(int interrupt, int mode, unsigned long ms=0);
                                      interrupt - Interrupt that should trigger the wakeup.
                                      mode - RISING, FALLING, CHANGE
                                      ms - Number of milliseconds to sleep (or 0 to sleep forever).
                                      The sleep method returns true if wake up was triggered by pin change and false means timer woke it up.
                                      • T treb0r
                                        treb0r
                                        172pilot1
                                        172pilot1
                                        172pilot
                                        @treb0r the problem is, you need to wake up the arduino to tell the temp sensor to take a new reading, so the best you can do is to trigger on the interrupts for the Windows and then use the timer to wake up and take the temperature reading, and then you'll have to compare to your saved value to decide whether it has been 5 degrees or not, so you can't completely sleep until that happens..
                                        • siodS
                                          siodS
                                          siod
                                          wrote on last edited by siod
                                          #32
                                          Hi guys,
                                          unfortunately I have to answer again to this topic because I don´t get my nodes work longer then up to two weeks. I guess it is still a sleep function problem and the problem persits though I am usin ver 2.0 now. Please have a look at my code, any hint is very appreciated!!
                                          I have attached 2 reed switches which should trigger a wakeup and one Hum/Temp Sensor is attached, too. I would like the device to send temp/hum measurements every 15 minutes, what works, but only for a few days or so. Then I also send battery level, that´s all.
                                          I have 3 devices up and running right now, they all fail once in while...
                                          // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
                                          // Define Node ID
                                          #define MY_NODE_ID 200
                                          //Batterysensor
                                          int oldBatteryPcnt = 0;
                                          #define CHILD_ID_BATT 7
                                          //Kontaktschalter
                                          //#include <Bounce2.h>
                                          int oldValueReed1=-1;
                                          int oldValueReed2=-1;
                                          //Tempsensor
                                          #include <SparkFunHTU21D.h>
                                          #define CHILD_ID_HUM 3
                                          #define CHILD_ID_TEMP 4
                                          //tempsensor
                                          HTU21D myHumidity;
                                          float lastTemp;
                                          float lastHum;
                                          //boolean metric = true;
                                          //Messages
                                          //Battery
                                          // Kontaktschalter
                                          //TempMessage
                                          void presentation(){
                                            sendSketchInfo("Schlafzimmer Messstation", "2.0");
                                            present(CHILD1_ID, S_DOOR);
                                            present(CHILD2_ID, S_DOOR);
                                            //Tempsensor
                                            present(CHILD_ID_HUM, S_HUM);
                                            //Battery
                                          //Setup
                                            //Serial.begin(9600);
                                            Serial.println("Hello!");
                                            //Batterysensor
                                             analogReference(INTERNAL1V1);
                                             analogReference(INTERNAL);
                                          //Tempsensor
                                            myHumidity.begin();
                                            Serial.println("...done!");
                                          // Setup Kontaktschalter 1
                                            pinMode(BUTTON1_PIN,INPUT);
                                              // Activate internal pull-up
                                          // Setup Kontaktschalter 2
                                            pinMode(BUTTON2_PIN,INPUT);
                                          //Starte den Loop
                                            //Batterysensor
                                            // get the battery Voltage
                                            delay(1000);
                                             #ifdef DEBUG
                                             #ifdef DEBUG
                                             Serial.print(batteryV);
                                             Serial.println(" V");
                                             Serial.print(batteryPcnt);
                                             Serial.println(" %");
                                               // Power up radio after sleep
                                               send(msgbatt.set(batteryPcnt));
                                               oldBatteryPcnt = batteryPcnt;
                                            //Kontakstschalter 1
                                            sleep(10);
                                            // Get the update value
                                               // Send in the new value
                                               send(msgReed1.set(valueReed1==HIGH ? 1 : 0));
                                               oldValueReed1 = valueReed1;
                                            //Kontakstschalter 2
                                               send(msgReed2.set(valueReed2==HIGH ? 1 : 0));
                                               oldValueReed2 = valueReed2;
                                           //Tempsensor
                                            if (isnan(temp)) {
                                              lastTemp = temp;
                                              send(msgTemp.set(temp, 1));
                                              Serial.print("T: ");
                                              Serial.println(temp);
                                            if (isnan(humd)) {
                                            } else if (humd != lastHum) {
                                                lastHum = humd;
                                                send(msgHum.set(humd, 1));
                                                Serial.print("H: ");
                                                Serial.println(humd);
                                           Serial.println("Sleep...");
                                          still learning...
                                          12.5k
