  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 331.3k Views 52 Watching
  • David MoraD
    David MoraD
    David Mora
    wrote on last edited by David Mora
    #140
    Hi Pete thank you very much, I am using mysensors online editor , not sure if I should edit that code?0_1463751590886_mysensors.jpg
      It's not possible to disable this from codebender. You'll need to install the Arduino IDE onto your computer.
      David MoraD 1 Reply Last reply
        David MoraD
        David MoraD
        David Mora
        #142
        @hek in computer I get this:
        C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
        #include <../Wire/Wire.h>
        compilation terminated.
        exit status 1
        Error compilación en tarjeta Arduino Pro or Pro Mini.
        petewillP 1 Reply Last reply
        • David MoraD David Mora
          exit status 1
          petewillP
          petewillP
          petewill
          @David-Mora Maybe this will help:
          https://www.youtube.com/watch?v=qUey_X9n2KI
          • David MoraD
            David MoraD
            David Mora
            #144
            thank you for your help ! I just reinstaled arduino and now I getthis ( I just downloaded the I.5 and copy and paste all libraries in the libraries folder:
            TENCIÓN: Categoría '' en librería UIPEthernet no es válida. Configurando a 'Uncategorized'
            C:\Users\David\Desktop\IrrigationController\IrrigationController.ino:92:31: fatal error: LiquidCrystal_I2C.h: No such file or directory
            exit status 1
            Error compilación en tarjeta Arduino Pro or Pro Mini.0_1463753883896_liquid.jpg
              exit status 1
              David MoraD
              David MoraD
              David Mora
              @David-Mora quite sad I´ve spent two days now installing and uninstalling arduino and libraries and no luck
                petewillP
                petewillP
                petewill
                @David-Mora Did you close all instances of Arduino and open again after you added the LiquidCrystal library? It looks like it can't find it.
                • petewillP petewill
                  David MoraD
                  David MoraD
                  David Mora
                  @petewill Yes Pete it doesnt work at all
                    David MoraD
                    David MoraD
                    David Mora
                    @David-Mora hope this is the right way to post the code finally the only mistake is
                    Arduino:1.6.9 (Windows 7), Tarjeta:"Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
                    El Sketch usa 30,808 bytes (100%) del espacio de almacenamiento de programa. El máximo es 30,720 bytes.
                    Las variables Globales usan 1,329 bytes (64%) de la memoria dinámica, dejando 719 bytes para las variables locales. El máximo es 2,048 bytes.
                    processing.app.debug.RunnerException: Programa muy grando: visite http://www.arduino.cc/en/Guide/Troubleshooting#size para ver cómo reducirlo.
                    at cc.arduino.Compiler.size(Compiler.java:315)
                    at cc.arduino.Compiler.build(Compiler.java:156)
                    at processing.app.Sketch.build(Sketch.java:1111)
                    at processing.app.Sketch.build(Sketch.java:1081)
                    at processing.app.Editor$BuildHandler.run(Editor.java:1988)
                    at java.lang.Thread.run(Thread.java:745)
                    Tarjeta en COM4 no disponible
                    Este reporte podría tener más información con
                    "Mostrar salida detallada durante la compilación"
                    opción habilitada en Archivo -> Preferencias.
                      petewillP
                      petewillP
                      petewill
                      @David-Mora Looks like you are almost there!
                      Did you disable debug? The sketch looks too big. To disable go to the MySensors library and open the MyConfig.h file in Notepad and change this line:
                      #define DEBUG
                      to
                      //#define DEBUG
                      Also, it looks like the Arduino IDE programmer isn't finding your Pro Mini. Did you select the correct Board and Port from the Tools menu? I don't have an Arduino next to me so my port isn't available to select but it should look similar to this (except you would choose your Port the Arduino is connected to):
                      0_1463835965285_upload-1dd27cba-b4e4-4543-980b-5ac59cc5da52
                      • rechin304R
                        rechin304R
                        rechin304
                        On my controller i use diffren LCD library and i was commented out this line
                        //#include <LiquidCrystal_I2C.h>
                        and
                        //LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                        Sketch uses 27,916 bytes (90%) of program storage space. Maximum is 30,720 bytes.
                        Global variables use 1,295 bytes (63%) of dynamic memory, leaving 753 bytes for local variables. Maximum is 2,048 bytes.
                        • HuczasH
                          HuczasH
                          Huczas
                          wrote on last edited by Huczas
                          #151
                          Is there a way to use domoticz to connect with it and on/off this irrigation system? How to achive this?
                          My domoticz is running on raspberry pi 0.
                          Mark JeffordM 1 Reply Last reply
                          • HuczasH Huczas
                            Mark JeffordM
                            Mark JeffordM
                            Mark Jefford
                            @Huczas
                            Yes, i've had to manually set the valve runtimes on the ardunio code, because its not possible to pass the runtime variable etc, this is from the one i''ve got built. runtime is 1min, but you can edit as required.
                                    int variable1 = 60000; // atoi(message.data);// RUN_ALL_ZONES time
                                    DEBUG_PRINT(i);
                                    DEBUG_PRINT(F(" = "));
                                    DEBUG_PRINTLN(variable1);
                                      allZoneTime[i] = variable1;
                                      zoneTimeUpdate = true;
                                    int variable2 = 60000; //atoi(message.data);// RUN_SINGLE_ZONE time
                                    DEBUG_PRINT(i);
                                    DEBUG_PRINTLN(variable2);
                                      valveSoloTime[i] = variable2;
                            • Sergio RiusS
                              Sergio RiusS
                              Sergio Rius
                              Thanks for posting, Mark. I was getting nuts figuring out what was the problem with my controller that was only activating 1sec each phase. I didn't implement it because that problem.
                              • Sergio RiusS Sergio Rius
                                Mark JeffordM
                                Mark JeffordM
                                Mark Jefford
                                @Sergio-Rius no problem, i had plenty of issues trying to get this to work with openhab before i changed controller :)
                                pr0slyte..P 1 Reply Last reply
                                • dbemowskD
                                  dbemowskD
                                  So I have been thinking of building one of these. I have just ordered an 8 channel relay board from ebay. http://www.ebay.com/itm/5V-8-Channel-Relay-Board-Module-for-Arduino-Raspberry-Pi-ARM-AVR-DSP-PIC-MUC-/262472832393?hash=item3d1c999589:g:sDEAAOSwnFZXVj2p . I have been trying to sift through this thread and am not seeing what I am looking for. Does this project take into account a pump start relay? If not, I am wondering the best way to handle this. I only have 4 zones in my irrigation setup, so I could certainly use one of the relay channels for that if it is written into the sketch. One thought I had to save extra processing on the sketch in dealing with the shift register would be to put a diode on each output that would funnel to a single point, so whenever any relay is turned on the pump start connection point would go active. I would assume that something has already been calculated in for this, but I din't see anything.
                                  Thanks for the great project. The Youtube video for this is actually what got me started with MySensors in the first place.
                                  • Mark JeffordM
                                    Mark JeffordM
                                    Mark Jefford
                                    I'm going down the diodes route... another channel to trigger it is tricky to deal with unless you use normally off relays and use the code earlier in this thread. I tried to use it but use normally on relays so going for diodes.
                                    K.I.S.S - keep it simple stupid ;) no point making it harder for you if you have a workaround on the table :)
                                    • dbemowskD
                                      dbemowskD
                                      @Mark Jefford I can go that route, I just didn't know if someone already had that factored in to the project already. After thinking about it since I posted this, I could also go the route of using another single digital channel and wire it to one of the relays. Going that route would give me a couple things:
                                      • One I could turn on the pump independent of a zone because I have a faucet connected to the setup that I can use. Currently I have to turn on a zone to use the faucet.
                                      • Two, I could poll the state of the pump by checking the state of the one channel.
                                      • Mark JeffordM Mark Jefford
                                        pr0slyte..P
                                        pr0slyte..P
                                        pr0slyte..
                                        wrote on last edited by pr0slyte..
                                        #158
                                        @Mark-Jefford I have the same issue. My system can't pass verifications for clock and valve data when I first plugged in because I don't know how to use this programs (Openhab, domoticz, etc.). Thank you!
                                        • L
                                          L
                                          Lars65
                                          Is it anybody who has this skecht in 24 hour format, instead of AM, PM?
