  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.6k Views 35 Watching
  • korttomaK
    korttomaK
    korttoma
    I wanted to get acquainted with the MQ2 AirQuality Sensor so I took a look at the sketch from github.
    One thing I noticed was that there is some sleep-time defined, is this just to make the sensor report the value every 30 seconds?
    I guess it is not for saving power so you can run it on batteries because my understanding is that it needs to be hot in order to function correctly and that will drain the battery fast.
    Does not look like the calibration during setup takes in account the preheating time either, maybe it is a good idea to add a delay before the calibration so the sensor gets hot enough.
    Please correct me if I'm wrong.
    • Tomas
    epierreE 1 Reply Last reply
    • epierreE
      epierreE
      epierre
      #30
      @hek Here is a first list from the most commons:
      • Carbon Monoxide – CO
      • Carbon Dioxide – CO2
      • Oxygen – O2
      • Methane – CH4
      • Hydrogen – H2
      • Ammonia – NH3
      • Isobutane – C4H10
      • Ethanol – CH3CH2OH (aka C2H5OH or C2H60)
      • Toluene – C6H5CH3
      • Hydrogen Sulfide – H2S
      • Nitrogen Dioxide – NO2
      • Ozone – O3
      • Hydrocarbons – VOC
      • Chlorine CL2
      • Ammonium NH4
      • Ethanol CO2H50H
      • Methyl CH3
      • Acetone CH3_2CO
      • LPG (both C3H8 C4H10)
      • korttomaK korttoma
        epierreE
        epierreE
        epierre
        #31
        I see your point, but from experience I don't see a difference on heating... I should have a closer look. This one does not need a special pre-heating as some other (MQ-7).
        Clearly this cannot run on battery on MQ/TGS/MICS series, so surely removing the sleep and adding a wait would do the trick the same way.
        If you want to play and see something, the MQ135 is much better for it reacts to CO2, so having someone in a room or not you could see it easily changing.
        A current weakness on the sketches is to take into accound humidity and temperature to correct the value, that will come too.
        • epierreE
          epierreE
          epierre
          I was looking for some other gas sensor, but these have no shield ready to connect to arduino :
          Sensor	     Operating Voltage  	Heater Power
          MiCS-2710 (NO2)	  2.5 V	           43 mW
          MiCS-5525 (CO)	   5.0 V	           76 mW
          do I need a dedicated 2.5 V linear regulator such as Microchip TC1071VCT713 ?
          • epierreE
            epierreE
            epierre
            • epierreE
              epierreE
              epierre
              • epierreE
                epierreE
                epierre
                @hek about initial calibration, how would I do check if there is a value in the eeprom or not, and if not run an initial calibration ?
                hekH 1 Reply Last reply
                • epierreE epierre
                  @epierre
                  Unwritten eeprom has the value 0xff.
                  • O
                    O
                    Omemanti
                    First of al I'm a novice in all of this. I can read some code but the whole arduino thing is new to me.
                    I tried to get the MQ135 working on my uno with tearing apart the : https://github.com/empierre/arduino/blob/master/1.3/MQ135dgi.ino.
                    I tried to pull out the bits and parts to get a accurate reading on my serial monitor.
                    It sometimes read 1 or 2, but most of the time it is 0.
                    Can it have something to do with it being mounted on its own PCB? (I ordered the one suggested in the store..)
                    Can someone help me out?
                    Groetjes Mark
                    • O Omemanti
                      Groetjes Mark
                      epierreE
                      epierreE
                      epierre
                      #38
                      @Omemanti hello have you plugged it on the right pins, this is an analogic sensor to be plugged on A0, with 5V and GND pins. Don't wire the digital one, useless...
                      My minimal value is 53.. so not 0 or 1 hwich looks more like the digital output ;-)
                      • O
                        O
                        Omemanti
                        should be alright right?
                        • O Omemanti
                          epierreE
                          epierreE
                          epierre
                          @Omemanti cabling is correct
                          • korttomaK
                            korttomaK
                            korttoma
                            #41
                            Where can I find AirQuality1.xml?? (or all files related to this device if there are others then the .xml)
                            01 09/03/14 13:46:53.685 ctrl_chr[31;1mDevice_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
                            02 09/03/14 13:46:53.686 ctrl_chr[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
                            Seems like if this file is missing it brakes the whole MySensors plugin.
                            All devices related to MySensors plugin are blank and nothing seems to update.
                            Deleting the device that use AirQuality.xml will make the rest work again.
                            Help!!
                            • Tomas
                              Help!!
                              @korttoma
                              Unfortunately no one has created it :(
                              korttomaK 1 Reply Last reply
                                @korttoma
                                korttomaK
                                korttomaK
                                korttoma
                                @hek
                                ahh, that's why I cant find it... no pressure from my side to get one done but maybe we should mention this little detail on the MySensors building page just as a heads up for others since there is a sketch published and all...
                                • Tomas
                                • epierreE
                                  epierreE
                                  epierre
                                  I made a template but I'm unable to test it...
                                  • epierreE epierre
                                    • Oxygen – O2
                                    • Methane – CH4
                                    • Hydrogen – H2
                                    • Ammonia – NH3
                                    • Isobutane – C4H10
                                    • Toluene – C6H5CH3
                                    • Ozone – O3
                                    • Chlorine CL2
                                    • Ammonium NH4
                                    • Ethanol CO2H50H
                                    • Methyl CH3
                                    • Acetone CH3_2CO
                                    epierreE
                                    epierreE
                                    epierre
                                    @hek here is an updated list from the Wunder Weather list of reportable gases:
                                    Oxygen – O2
                                    Methane – CH4
                                    Hydrogen – H2
                                    Ammonia – NH3
                                    Isobutane – C4H10
                                    Toluene – C6H5CH3
                                    Ozone – O3
                                    Hydrocarbons – VOC
                                    Chlorine CL2
                                    Ammonium NH4
                                    Ethanol CO2H50H
                                    Methyl CH3
                                    Acetone CH3_2CO
                                    • NO - nitric oxide
                                    • NOX - nitrogen oxides
                                    • NO3 ion (nitrate, not adjusted for ammonium ion) UG/M3
                                    • SO4 ion, sulfate, not adjusted for ammonium ion, UG/M3
                                    • SO2 sulfur dioxide, ppb
                                    • EC (elemental carbon) – PM2.5 UG/M3
                                    • OC (organic carbon, not adjusted for oxygen and hydrogen) – PM2.5 UG/M3
                                    • BC (black carbon at 880 nm) UG/M3
                                    • UV-AETH (second channel of Aethalometer at 370 nm) UG/M3
                                    • PM2.5 mass - UG/M3
                                    • PM10 mass - PM10 mass
                                    • epierreE epierre
                                      Oxygen – O2
                                      Methane – CH4
                                      Hydrogen – H2
                                      Ammonia – NH3
                                      Isobutane – C4H10
                                      Toluene – C6H5CH3
                                      Ozone – O3
                                      Hydrocarbons – VOC
                                      Chlorine CL2
                                      Ammonium NH4
                                      Ethanol CO2H50H
                                      Methyl CH3
                                      Acetone CH3_2CO
                                      • NO - nitric oxide
                                      Still thinking about you gas_type suggestion. It would introduce another level of device types. Hmm..
                                        @hek
                                        epierreE
                                        epierreE
                                        epierre
                                        @korttoma look above to S_CO2Sensor.json D_CO2Sensor.xml D_CO2Sensor.json, if you can test it...
                                        • epierreE
                                          epierreE
                                          epierre
                                          #48
                                          @Yveaux I know you are strong at finding datasheet... can you find one for me ? I can't find the 2SH12 sensor altgough I've asked for it to all suppliers on aliexpress...
                                          Same for theWSP1110
