  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.6k Views 35 Watching
  • O Omemanti
    First of al I'm a novice in all of this. I can read some code but the whole arduino thing is new to me.
    I tried to get the MQ135 working on my uno with tearing apart the : https://github.com/empierre/arduino/blob/master/1.3/MQ135dgi.ino.
    I tried to pull out the bits and parts to get a accurate reading on my serial monitor.
    It sometimes read 1 or 2, but most of the time it is 0.
    Can it have something to do with it being mounted on its own PCB? (I ordered the one suggested in the store..)
    Can someone help me out?
    Groetjes Mark
    epierreE
    epierreE
    epierre
    #38
    @Omemanti hello have you plugged it on the right pins, this is an analogic sensor to be plugged on A0, with 5V and GND pins. Don't wire the digital one, useless...
    My minimal value is 53.. so not 0 or 1 hwich looks more like the digital output ;-)
    z-wave - Vera -> Domoticz
    • O
      O
      Omemanti
      should be alright right?
      epierreE 1 Reply Last reply
      • O Omemanti
        epierreE
        epierreE
        epierre
        @Omemanti cabling is correct
        • korttomaK
          korttomaK
          korttoma
          #41
          Where can I find AirQuality1.xml?? (or all files related to this device if there are others then the .xml)
          01 09/03/14 13:46:53.685 ctrl_chr[31;1mDevice_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
          02 09/03/14 13:46:53.686 ctrl_chr[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
          Seems like if this file is missing it brakes the whole MySensors plugin.
          All devices related to MySensors plugin are blank and nothing seems to update.
          Deleting the device that use AirQuality.xml will make the rest work again.
          Help!!
          • Tomas
          hekH 1 Reply Last reply
          • korttomaK korttoma
            Help!!
            @korttoma
            Unfortunately no one has created it :(
            korttomaK 1 Reply Last reply
              @korttoma
              korttomaK
              korttomaK
              korttoma
              @hek
              ahh, that's why I cant find it... no pressure from my side to get one done but maybe we should mention this little detail on the MySensors building page just as a heads up for others since there is a sketch published and all...
              • Tomas
              • epierreE
                epierreE
                epierre
                I made a template but I'm unable to test it...
                • epierreE epierre
                  @hek Here is a first list from the most commons:
                  • Carbon Monoxide – CO
                  • Carbon Dioxide – CO2
                  • Oxygen – O2
                  • Methane – CH4
                  • Hydrogen – H2
                  • Ammonia – NH3
                  • Isobutane – C4H10
                  • Ethanol – CH3CH2OH (aka C2H5OH or C2H60)
                  • Toluene – C6H5CH3
                  • Hydrogen Sulfide – H2S
                  • Nitrogen Dioxide – NO2
                  • Ozone – O3
                  • Hydrocarbons – VOC
                  • Chlorine CL2
                  • Ammonium NH4
                  • Ethanol CO2H50H
                  • Methyl CH3
                  • Acetone CH3_2CO
                  • LPG (both C3H8 C4H10)
                  epierreE
                  epierreE
                  epierre
                  @hek here is an updated list from the Wunder Weather list of reportable gases:
                  Oxygen – O2
                  Methane – CH4
                  Hydrogen – H2
                  Ammonia – NH3
                  Isobutane – C4H10
                  Toluene – C6H5CH3
                  Ozone – O3
                  Hydrocarbons – VOC
                  Chlorine CL2
                  Ammonium NH4
                  Ethanol CO2H50H
                  Methyl CH3
                  Acetone CH3_2CO
                  • NO - nitric oxide
                  • NOX - nitrogen oxides
                  • NO3 ion (nitrate, not adjusted for ammonium ion) UG/M3
                  • SO4 ion, sulfate, not adjusted for ammonium ion, UG/M3
                  • SO2 sulfur dioxide, ppb
                  • EC (elemental carbon) – PM2.5 UG/M3
                  • OC (organic carbon, not adjusted for oxygen and hydrogen) – PM2.5 UG/M3
                  • BC (black carbon at 880 nm) UG/M3
                  • UV-AETH (second channel of Aethalometer at 370 nm) UG/M3
                  • PM2.5 mass - UG/M3
                  • PM10 mass - PM10 mass
                  • epierreE epierre
                    Oxygen – O2
                    Methane – CH4
                    Hydrogen – H2
                    Ammonia – NH3
                    Isobutane – C4H10
                    Toluene – C6H5CH3
                    Ozone – O3
                    Hydrocarbons – VOC
                    Chlorine CL2
                    Ammonium NH4
                    Ethanol CO2H50H
                    Methyl CH3
                    Acetone CH3_2CO
                    • NO - nitric oxide
                    Still thinking about you gas_type suggestion. It would introduce another level of device types. Hmm..
                      @hek
                      epierreE
                      epierreE
                      epierre
                      @korttoma look above to S_CO2Sensor.json D_CO2Sensor.xml D_CO2Sensor.json, if you can test it...
                      • epierreE
                        epierreE
                        epierre
                        #48
                        @Yveaux I know you are strong at finding datasheet... can you find one for me ? I can't find the 2SH12 sensor altgough I've asked for it to all suppliers on aliexpress...
                        Same for theWSP1110
                        • epierreE epierre
                          Same for theWSP1110
                          @epierre Couldn't find it either, sorry...
                          I wouldn't buy a $52,- component without a datasheet, if I were you...
                          epierreE 2 Replies Last reply
                          • YveauxY Yveaux
                            epierreE
                            epierreE
                            epierre
                            #50
                            @Yveaux When I asked for the WSP110 they sent me only this (not the same for this one is HCHO and well documented...) :
                            • epierreE epierre
                              @epierre
                              I wonder what the green curve represents :confused:
                                @epierre
                                epierreE
                                epierreE
                                epierre
                                @hek that should be the more sensitive, and since it is given mostly for CHCO I guess this is it... (Formaldehyde)
                                  @epierre
                                  epierreE
                                  epierreE
                                  epierre
                                  @hek 甲醛 is formaldehyde, given by google translate so I'm right !
                                  • epierreE epierre
                                    @epierre
                                    Haha :thumbsup:
                                    • epierreE
                                      epierreE
                                      epierre
                                      Davide answered me, lot of things to read but a warning:
                                      Anyway, for consistent CO2 investigaion, you HAVE to chose a NDIR sensor, those chemical sensor can not be used. They decay in a few year, and they differs a little one from each other.
                                      I've asked him back for precision if he speaks of the organic sensor or the ceramic ones (like MQ...).
                                      For the CO2, it is MH-Z14 which is $66+ priced.
                                      • epierreE epierre
                                        @epierre said:
                                        MH-Z14
                                        Like this little puppy?
                                          @epierre said:
                                          MH-Z14
                                          epierreE
                                          epierreE
                                          epierre
                                          @hek exact !
