  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 450.5k Views 35 Watching
  • O
    O
    Omemanti
    should be alright right?
    epierreE 1 Reply Last reply
    • O Omemanti
      epierreE
      epierreE
      epierre
      @Omemanti cabling is correct
      z-wave - Vera -> Domoticz
      • korttomaK
        korttomaK
        korttoma
        #41
        Where can I find AirQuality1.xml?? (or all files related to this device if there are others then the .xml)
        01 09/03/14 13:46:53.685 ctrl_chr[31;1mDevice_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
        02 09/03/14 13:46:53.686 ctrl_chr[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
        Seems like if this file is missing it brakes the whole MySensors plugin.
        All devices related to MySensors plugin are blank and nothing seems to update.
        Deleting the device that use AirQuality.xml will make the rest work again.
        Help!!
        • Tomas
        hekH 1 Reply Last reply
        • korttomaK korttoma
          Help!!
          @korttoma
          Unfortunately no one has created it :(
          korttomaK 1 Reply Last reply
            @korttoma
            korttomaK
            korttomaK
            korttoma
            @hek
            ahh, that's why I cant find it... no pressure from my side to get one done but maybe we should mention this little detail on the MySensors building page just as a heads up for others since there is a sketch published and all...
            • Tomas
            • epierreE
              epierreE
              epierre
              I made a template but I'm unable to test it...
              • epierreE epierre
                @hek Here is a first list from the most commons:
                • Carbon Monoxide – CO
                • Carbon Dioxide – CO2
                • Oxygen – O2
                • Methane – CH4
                • Hydrogen – H2
                • Ammonia – NH3
                • Isobutane – C4H10
                • Ethanol – CH3CH2OH (aka C2H5OH or C2H60)
                • Toluene – C6H5CH3
                • Hydrogen Sulfide – H2S
                • Nitrogen Dioxide – NO2
                • Ozone – O3
                • Hydrocarbons – VOC
                • Chlorine CL2
                • Ammonium NH4
                • Ethanol CO2H50H
                • Methyl CH3
                • Acetone CH3_2CO
                • LPG (both C3H8 C4H10)
                epierreE
                epierreE
                epierre
                @hek here is an updated list from the Wunder Weather list of reportable gases:
                Oxygen – O2
                Methane – CH4
                Hydrogen – H2
                Ammonia – NH3
                Isobutane – C4H10
                Toluene – C6H5CH3
                Ozone – O3
                Hydrocarbons – VOC
                Chlorine CL2
                Ammonium NH4
                Ethanol CO2H50H
                Methyl CH3
                Acetone CH3_2CO
                • NO - nitric oxide
                • NOX - nitrogen oxides
                • NO3 ion (nitrate, not adjusted for ammonium ion) UG/M3
                • SO4 ion, sulfate, not adjusted for ammonium ion, UG/M3
                • SO2 sulfur dioxide, ppb
                • EC (elemental carbon) – PM2.5 UG/M3
                • OC (organic carbon, not adjusted for oxygen and hydrogen) – PM2.5 UG/M3
                • BC (black carbon at 880 nm) UG/M3
                • UV-AETH (second channel of Aethalometer at 370 nm) UG/M3
                • PM2.5 mass - UG/M3
                • PM10 mass - PM10 mass
                • epierreE epierre
                  Oxygen – O2
                  Methane – CH4
                  Hydrogen – H2
                  Ammonia – NH3
                  Isobutane – C4H10
                  Toluene – C6H5CH3
                  Ozone – O3
                  Hydrocarbons – VOC
                  Chlorine CL2
                  Ammonium NH4
                  Ethanol CO2H50H
                  Methyl CH3
                  Acetone CH3_2CO
                  • NO - nitric oxide
                  Still thinking about you gas_type suggestion. It would introduce another level of device types. Hmm..
                    @hek
                    epierreE
                    epierreE
                    epierre
                    @korttoma look above to S_CO2Sensor.json D_CO2Sensor.xml D_CO2Sensor.json, if you can test it...
                    • epierreE
                      epierreE
                      epierre
                      #48
                      @Yveaux I know you are strong at finding datasheet... can you find one for me ? I can't find the 2SH12 sensor altgough I've asked for it to all suppliers on aliexpress...
                      Same for theWSP1110
                      • epierreE epierre
                        Same for theWSP1110
                        @epierre Couldn't find it either, sorry...
                        I wouldn't buy a $52,- component without a datasheet, if I were you...
                        epierreE 2 Replies Last reply
                        • YveauxY Yveaux
                          epierreE
                          epierreE
                          epierre
                          #50
                          @Yveaux When I asked for the WSP110 they sent me only this (not the same for this one is HCHO and well documented...) :
                          • epierreE epierre
                            @epierre
                            I wonder what the green curve represents :confused:
                              @epierre
                              epierreE
                              epierreE
                              epierre
                              @hek that should be the more sensitive, and since it is given mostly for CHCO I guess this is it... (Formaldehyde)
                                @epierre
                                epierreE
                                epierreE
                                epierre
                                @hek 甲醛 is formaldehyde, given by google translate so I'm right !
                                • epierreE epierre
                                  @epierre
                                  Haha :thumbsup:
                                  • epierreE
                                    epierreE
                                    epierre
                                    Davide answered me, lot of things to read but a warning:
                                    Anyway, for consistent CO2 investigaion, you HAVE to chose a NDIR sensor, those chemical sensor can not be used. They decay in a few year, and they differs a little one from each other.
                                    I've asked him back for precision if he speaks of the organic sensor or the ceramic ones (like MQ...).
                                    For the CO2, it is MH-Z14 which is $66+ priced.
                                    • epierreE epierre
                                      @epierre said:
                                      MH-Z14
                                      Like this little puppy?
                                        @epierre said:
                                        MH-Z14
                                        epierreE
                                        epierreE
                                        epierre
                                        @hek exact !
                                        • epierreE epierre
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          Thanks, found the device files and got the device included again.
                                          Seems like my MQ-2 is always reporting 0 or nothing at all. I guess I need to try to calibrate it again.
                                          It will do the calibration every time the sensor is restarted right?
                                          How can I calibrate the sensor if I put it somewhere where the air is not clean enough? (bring clean air in a jar? ;) )
                                          Maybe it would be an idea to add a calibration button to the mix and when run using the button it would save the calibration related data in the RAM so it can then always use this calibrated value and then it would not re-calibrate every time it loses power.
                                          I have the 10k resistor between GND and A0, is this really necessary?
                                          Does the potentiometer on the sensor board affect the analog out at all or is it only for sensitivity on the digital out?
                                          Sorry for all the questions ;)
                                          • Tomas
