  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.6k Views 35 Watching
  • epierreE
    epierreE
    epierre
    • epierreE
      epierreE
      epierre
      • epierreE
        epierreE
        epierre
        @hek about initial calibration, how would I do check if there is a value in the eeprom or not, and if not run an initial calibration ?
        hekH 1 Reply Last reply
        • epierreE epierre
          @epierre
          Unwritten eeprom has the value 0xff.
          • O
            O
            Omemanti
            First of al I'm a novice in all of this. I can read some code but the whole arduino thing is new to me.
            I tried to get the MQ135 working on my uno with tearing apart the : https://github.com/empierre/arduino/blob/master/1.3/MQ135dgi.ino.
            I tried to pull out the bits and parts to get a accurate reading on my serial monitor.
            It sometimes read 1 or 2, but most of the time it is 0.
            Can it have something to do with it being mounted on its own PCB? (I ordered the one suggested in the store..)
            Can someone help me out?
            Groetjes Mark
            epierreE 1 Reply Last reply
            • O Omemanti
              Groetjes Mark
              epierreE
              epierreE
              epierre
              #38
              @Omemanti hello have you plugged it on the right pins, this is an analogic sensor to be plugged on A0, with 5V and GND pins. Don't wire the digital one, useless...
              My minimal value is 53.. so not 0 or 1 hwich looks more like the digital output ;-)
              • O
                O
                Omemanti
                should be alright right?
                • O Omemanti
                  epierreE
                  epierreE
                  epierre
                  @Omemanti cabling is correct
                  • korttomaK
                    korttomaK
                    korttoma
                    #41
                    Where can I find AirQuality1.xml?? (or all files related to this device if there are others then the .xml)
                    01 09/03/14 13:46:53.685 ctrl_chr[31;1mDevice_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
                    02 09/03/14 13:46:53.686 ctrl_chr[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
                    Seems like if this file is missing it brakes the whole MySensors plugin.
                    All devices related to MySensors plugin are blank and nothing seems to update.
                    Deleting the device that use AirQuality.xml will make the rest work again.
                    Help!!
                    • Tomas
                    • korttomaK korttoma
                      Help!!
                      @korttoma
                      Unfortunately no one has created it :(
                      korttomaK 1 Reply Last reply
                        @korttoma
                        korttomaK
                        korttomaK
                        korttoma
                        @hek
                        ahh, that's why I cant find it... no pressure from my side to get one done but maybe we should mention this little detail on the MySensors building page just as a heads up for others since there is a sketch published and all...
                        • Tomas
                        • epierreE
                          epierreE
                          epierre
                          I made a template but I'm unable to test it...
                          • epierreE epierre
                            @hek Here is a first list from the most commons:
                            • Carbon Monoxide – CO
                            • Carbon Dioxide – CO2
                            • Oxygen – O2
                            • Methane – CH4
                            • Hydrogen – H2
                            • Ammonia – NH3
                            • Isobutane – C4H10
                            • Ethanol – CH3CH2OH (aka C2H5OH or C2H60)
                            • Toluene – C6H5CH3
                            • Hydrogen Sulfide – H2S
                            • Nitrogen Dioxide – NO2
                            • Ozone – O3
                            • Hydrocarbons – VOC
                            • Chlorine CL2
                            • Ammonium NH4
                            • Ethanol CO2H50H
                            • Methyl CH3
                            • Acetone CH3_2CO
                            • LPG (both C3H8 C4H10)
                            epierreE
                            epierreE
                            epierre
                            @hek here is an updated list from the Wunder Weather list of reportable gases:
                            Oxygen – O2
                            Methane – CH4
                            Hydrogen – H2
                            Ammonia – NH3
                            Isobutane – C4H10
                            Toluene – C6H5CH3
                            Ozone – O3
                            Hydrocarbons – VOC
                            Chlorine CL2
                            Ammonium NH4
                            Ethanol CO2H50H
                            Methyl CH3
                            Acetone CH3_2CO
                            • NO - nitric oxide
                            • NOX - nitrogen oxides
                            • NO3 ion (nitrate, not adjusted for ammonium ion) UG/M3
                            • SO4 ion, sulfate, not adjusted for ammonium ion, UG/M3
                            • SO2 sulfur dioxide, ppb
                            • EC (elemental carbon) – PM2.5 UG/M3
                            • OC (organic carbon, not adjusted for oxygen and hydrogen) – PM2.5 UG/M3
                            • BC (black carbon at 880 nm) UG/M3
                            • UV-AETH (second channel of Aethalometer at 370 nm) UG/M3
                            • PM2.5 mass - UG/M3
                            • PM10 mass - PM10 mass
                            • epierreE epierre
                              Oxygen – O2
                              Methane – CH4
                              Hydrogen – H2
                              Ammonia – NH3
                              Isobutane – C4H10
                              Toluene – C6H5CH3
                              Ozone – O3
                              Hydrocarbons – VOC
                              Chlorine CL2
                              Ammonium NH4
                              Ethanol CO2H50H
                              Methyl CH3
                              Acetone CH3_2CO
                              • NO - nitric oxide
                              Still thinking about you gas_type suggestion. It would introduce another level of device types. Hmm..
                                @hek
                                epierreE
                                epierreE
                                epierre
                                @korttoma look above to S_CO2Sensor.json D_CO2Sensor.xml D_CO2Sensor.json, if you can test it...
                                • epierreE
                                  epierreE
                                  epierre
                                  #48
                                  @Yveaux I know you are strong at finding datasheet... can you find one for me ? I can't find the 2SH12 sensor altgough I've asked for it to all suppliers on aliexpress...
                                  Same for theWSP1110
                                  • epierreE epierre
                                    Same for theWSP1110
                                    @epierre Couldn't find it either, sorry...
                                    I wouldn't buy a $52,- component without a datasheet, if I were you...
                                    epierreE 2 Replies Last reply
                                    • YveauxY Yveaux
                                      epierreE
                                      epierreE
                                      epierre
                                      #50
                                      @Yveaux When I asked for the WSP110 they sent me only this (not the same for this one is HCHO and well documented...) :
                                      • epierreE epierre
                                        @epierre
                                        I wonder what the green curve represents :confused:
                                          @epierre
                                          epierreE
                                          epierreE
                                          epierre
                                          @hek that should be the more sensitive, and since it is given mostly for CHCO I guess this is it... (Formaldehyde)
