  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.4k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @scalz
    That is cheap.. Perhaps I should buy one, just for the fun of it, and try it out :)
    I have my jtagice3 though, and it's working fine.. (Even though they don't have the correct cortex-m0 debug port pin layout..)
    • nemikN
      nemikN
      nemik
      I've been using those cheap $3 ST-Link adapters for flashing ARM cortex chips with OpenOCD, using SWD pins. They're fantastic and work very well.
      • nick van alstN
        nick van alstN
        nick van alst
        i really like this idea, i'm getting a bit tierd of having the mysensors gateway connected through a breadboard.
        how far is it? i saw your comment that it is almost ready for last prototype, is this board fully functional?
        Plus, will it be able to act as a Serial/Ethernet/MQTT gateway? or only 1 of these?
        And if it is ready, is there a place to order them, or just send the files to a PCB company?
        • tbowmoT
          tbowmoT
          tbowmo
          I'm still waiting for the last prototype pcb's to arrive.
          Depending on the sketch you load it with, it can be a serial, ethernet or MQTT gateway. It has native USB in the atsam, and a connector for a w5100 module.
          Besides that it will have SD card for local storage of sensor data, so it could in theory operate without a controller at all..
          TheoLT 1 Reply Last reply
          • tbowmoT tbowmo
            TheoLT
            TheoLT
            TheoL
            @tbowmo Can you give some details about the final dimensions on the board? I want to start the woodworking on the casing for my current gateway. But I'll make sure your prototype fits in as well.
            I can't wait 'till this one goes to production. Great work, I'm impressed.
            • tbowmoT
              tbowmoT
              tbowmo
              @TheoL
              The base board is 5x5 cm, but if you use nrf modules they will protrude over the edge of the PCB. Rfm69 is soldered to the bottom so they won't add to the dimensions. W5100 will probably make the base a few mm wider and longer (depending on the module..).
              Design files are available at GH, so you can check the dimensions yourself
              • tbowmoT tbowmo
                @TheoL
                TheoLT
                TheoLT
                TheoL
                @tbowmo Thanx for your fast reply. It's a great size. I'll create a mockup of it with cardboard. It'll give me a better visualization when I make the housing. Just a final question. I'm guessing I won't be able to stick an Arduino ethernet shield on it right?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @TheoL
                  the GW is not the same dimensions as arduino, so Arduino shields would not fit :)
                  A mini w5100 board like this would fit..
                  Also, see this "old" forum post about the GW device, there is some conceptual pictures of how it would look like with nrf and w5100 attached.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    Received a new prototype from dirtypcbs the other day
                    I have only come to the point where the SD Card reader is mounted, as I wanted to try the mechanics out :)
                    Currently I'm lacking time for finishing it within the next 2-3 weeks.. If someone knows how to slow down time around you, without being slowed down yourself, please tell me how to achieve it :) (Too many high priority tasks at the moment..)
                    G GertSandersG 2 Replies Last reply
                    • tbowmoT tbowmo
                      G
                      G
                      gonzalonal
                      wrote on last edited by gonzalonal
                      #22
                      Great design @tbowmo. Very interesting indeed.
                      I have some questions and suggestions if you don't mind.
                      Will this support the use of the amplified version of the nrf24l01+ (NRF24L01* + PA + LNA). It uses a little more power than the non aplified version so It's even more sensirtive to power supply noise.
                      EDIT: In the schematic, upper left corner, in the ATSHA204 module it seems you have forgotten to add the SDA pin conection.
                      EDIT2: Haven't you thought in adding a battery charger module such as the TP4056. It would be nice to have this board woarking as its own UPS. Having the battery connected in the battery connector without something keeping the battery charged doesn't have much sense to me.
                      Regards!
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #23
                        It should have enough juice in the regulator to support an pa/lna enabled nrf24l01. I havent got one myself, so it's not "validated" yet.
                        The idea with the battery, is that it is only to keep the rtc alive in the atsam, and if you look at the schematics, then it's only the cpu that can be powered by battery. A coin cell battery should be enough. (I couldn't make room for a battery holder so that's why it just became a 2 pin header
                        The atsha204 is validated on the board, so it's working ;) If you look at the schematic, SDA pin on the atsha204 is labeled "SECURITY", pin 20 on the cpu is also labeled SECURITY, so these are connected.
                        • G
                          G
                          gonzalonal
                          Thanks @tbowmo. Now it's all clear.
                          What tests do you think are remaining in order to have the board fully tested and ready to production environement?
                          Regards!
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @gonzalonal
                            The only thing missing is the Ethernet module at the moment, it has been working on an earlier board, but can't get it working right now.
                            I'm almost at point where I will let our partner in China do their initial prototype spin, to evaluate production.
                            • tbowmoT tbowmo
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @tbowmo
                              In the series 12 Monkeys a scientist developed injections to slow down time at the quantum level, which allows you to be impervious to time shift. Not sure if it slows down time perception itself though.
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                #27
                                And ethernet is up!
                                I think this calls for a couple of pictures of the "thing" :)
                                first with ethernet / usb (power) connected.
                                and without ethernet shield
                                G 1 Reply Last reply
                                • tbowmoT tbowmo
                                  And ethernet is up!
                                  G
                                  G
                                  gonzalonal
                                  Hi @tbowmo. Congratulations.
                                  Have you identified what caused the trouble?
                                  Regards!
                                  • T
                                    tomkxy
                                    @tbowmo Congrats! That piece of hardware looks cool. I am interested to replace my current gateway with such a puppy.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @gonzalonal
                                      It was a software issue.. I had rewritten the hardware definition files almost from scratch, and made a couple of errors that made it fail silently..
                                      Peripheral configuration on SAMD21 is a bit more advanced, than on the old atmega328, as you can configure a specific peripheral (a sercom unit for example) to appear on different pins, depending on MUX setting.. I had made some wrong MUX settings for SERCOM4, which is used for the W5100 module.
                                      • sundberg84S
                                        sundberg84S
                                        Great work @tbowmo - cant wait until I can get my hands on one :)
                                        tbowmoT 1 Reply Last reply
                                        • sundberg84S sundberg84
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          #32
                                          @sundberg84
                                          If you come to the meetup in Malmö, you can see a working prototype :)
