  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.4k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @TheoL
    the GW is not the same dimensions as arduino, so Arduino shields would not fit :)
    A mini w5100 board like this would fit..
    Also, see this "old" forum post about the GW device, there is some conceptual pictures of how it would look like with nrf and w5100 attached.
    • tbowmoT
      tbowmoT
      tbowmo
      Received a new prototype from dirtypcbs the other day
      I have only come to the point where the SD Card reader is mounted, as I wanted to try the mechanics out :)
      Currently I'm lacking time for finishing it within the next 2-3 weeks.. If someone knows how to slow down time around you, without being slowed down yourself, please tell me how to achieve it :) (Too many high priority tasks at the moment..)
      G GertSandersG 2 Replies Last reply
      • tbowmoT tbowmo
        G
        G
        gonzalonal
        wrote on last edited by gonzalonal
        #22
        Great design @tbowmo. Very interesting indeed.
        I have some questions and suggestions if you don't mind.
        Will this support the use of the amplified version of the nrf24l01+ (NRF24L01* + PA + LNA). It uses a little more power than the non aplified version so It's even more sensirtive to power supply noise.
        EDIT: In the schematic, upper left corner, in the ATSHA204 module it seems you have forgotten to add the SDA pin conection.
        EDIT2: Haven't you thought in adding a battery charger module such as the TP4056. It would be nice to have this board woarking as its own UPS. Having the battery connected in the battery connector without something keeping the battery charged doesn't have much sense to me.
        Regards!
        • tbowmoT
          tbowmoT
          tbowmo
          #23
          It should have enough juice in the regulator to support an pa/lna enabled nrf24l01. I havent got one myself, so it's not "validated" yet.
          The idea with the battery, is that it is only to keep the rtc alive in the atsam, and if you look at the schematics, then it's only the cpu that can be powered by battery. A coin cell battery should be enough. (I couldn't make room for a battery holder so that's why it just became a 2 pin header
          The atsha204 is validated on the board, so it's working ;) If you look at the schematic, SDA pin on the atsha204 is labeled "SECURITY", pin 20 on the cpu is also labeled SECURITY, so these are connected.
          • G
            G
            gonzalonal
            Thanks @tbowmo. Now it's all clear.
            What tests do you think are remaining in order to have the board fully tested and ready to production environement?
            Regards!
            • tbowmoT
              tbowmoT
              tbowmo
              @gonzalonal
              The only thing missing is the Ethernet module at the moment, it has been working on an earlier board, but can't get it working right now.
              I'm almost at point where I will let our partner in China do their initial prototype spin, to evaluate production.
              • tbowmoT tbowmo
                GertSandersG
                GertSandersG
                GertSanders
                @tbowmo
                In the series 12 Monkeys a scientist developed injections to slow down time at the quantum level, which allows you to be impervious to time shift. Not sure if it slows down time perception itself though.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  #27
                  And ethernet is up!
                  I think this calls for a couple of pictures of the "thing" :)
                  first with ethernet / usb (power) connected.
                  and without ethernet shield
                  G 1 Reply Last reply
                  • tbowmoT tbowmo
                    And ethernet is up!
                    G
                    G
                    gonzalonal
                    Hi @tbowmo. Congratulations.
                    Have you identified what caused the trouble?
                    Regards!
                    • T
                      tomkxy
                      @tbowmo Congrats! That piece of hardware looks cool. I am interested to replace my current gateway with such a puppy.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @gonzalonal
                        It was a software issue.. I had rewritten the hardware definition files almost from scratch, and made a couple of errors that made it fail silently..
                        Peripheral configuration on SAMD21 is a bit more advanced, than on the old atmega328, as you can configure a specific peripheral (a sercom unit for example) to appear on different pins, depending on MUX setting.. I had made some wrong MUX settings for SERCOM4, which is used for the W5100 module.
                        • sundberg84S
                          sundberg84S
                          Great work @tbowmo - cant wait until I can get my hands on one :)
                          tbowmoT 1 Reply Last reply
                          • sundberg84S sundberg84
                            tbowmoT
                            tbowmoT
                            tbowmo
                            #32
                            @sundberg84
                            If you come to the meetup in Malmö, you can see a working prototype :)
                            • tbowmoT tbowmo
                              @sundberg84
                              G
                              G
                              gonzalonal
                              Hi @tbowmo .
                              Would you say that the board is ready for production environement? I am planing in ordering one for my home.
                              Will you share the sketches for the differente gateways configurations?
                              Thanks, regards.
                              • bisschopsrB
                                bisschopsrB
                                bisschopsr
                                Hi @tbowmo: Nice project. I have a small question about the W5100 board. The board has a standard mail header connector. If I add a (standard) female header, I don't have enough height to compensate for the height of the RJ45 connector. How did you resolve that? Did you use a higher female header? I can't make it up from the pictures.
                                Thanks in advance,
                                Ralph
                                Domoticz, P1 meter interface, MySensors and more to come!
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  I @gonzalonal
                                  Sketches would be the standard sketches for different GW options, as distributed with the mysensors core (it's the same sketches for atmega328p based gateways)
                                  @bisschopsr
                                  Actually a really good question :) I haven't been able to find a header with extra height.. But what I did on my sample, is that the female header is not mounted flush to the PCB, rather it's raised as much as possible above the PCB, and then it is working.
                                  I will have to talk with our manufacturing partner in China, and see what they have as options.
                                  • TheoLT
                                    TheoLT
                                    TheoL
                                    Any idea when I'm able to order a couple of those? I'm organizing a MySensors master class for visitors of a Fast Data Event me company is holding in September. Would be great if I'd could show and promote this Gateway. I love it.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @TheoL
                                      Im talking with the manufacturer, and hopefully we can start a prototype evaluation very soon now. My guess is that we could start shipping within a couple of months from now, if we don't find any mistakes :)
                                      TheoLT 1 Reply Last reply
                                      • tbowmoT tbowmo
                                        @TheoL
                                        TheoLT
                                        TheoLT
                                        TheoL
                                        @tbowmo Great news. Also do we have any idea when MySensors 2.0 will be released?
                                          We hope to release 2.0 on the MySensors meetup on Saturday.
