  3. Multisensor PIR based on IKEA Molgan
112 Posts 21 Posters 71.9k Views 37 Watching
  • dynamiteD dynamite
    @Yveaux Sent you a DM with my email adress. Can't you use the voltage level after the regulator? The regulator is rated up to 30 mA.
    @dynamite Possibly. I just wanted to keep options open.
    One wire is required to power the board; either from the batteries, or from the regulator.
    I'll just see what works best.
      This have to be posted on http://www.ikeahackers.net/ when done also.
        @hek Will do just nice, next to the AK47 Hemma Lamp :flushed:
        dynamiteD 1 Reply Last reply
        • YveauxY Yveaux
          dynamiteD
          dynamiteD
          dynamite
          wrote on last edited by dynamite
          #32
          @Yveaux @hek how do you know of the existance of such a site...?:frowning:
            @dynamite I didn't. Got it from @hek :bowtie:
            • D
              danta
              Did someone succeed in fitting a pro mini and radio in the Molgan while still using the original pir?
              It looks to me there isn't enough room for the additional components and I'm not sure what part of the pcb I can saw off while still being able to use the original pir.
              Does anyone have an idea?
              • D danta
                dynamiteD
                dynamiteD
                dynamite
                #35
                Fits.... Ok i need to attach the wites but it will still fit. The NRF can be placed on the other side
                • Sander StolkS
                  Sander StolkS
                  Sander Stolk
                  wrote on last edited by Sander Stolk
                  #36
                  Bought 3 pcs. to open / modify / try fitting things in it. The thing is that this housing is really perfect to place it on the ceiling or to fit things in. Better than a black box.
                  What I'm going to try is remove all the plastic inside including the batteryhousing but not the "click"-system to mount it.
                  I'm going to try to make it 230 volt compatible with a HLK-PM01 so that I can use it as a PIR, Temp and door sensor and connect it at the ceiling.
                  Let you know how things are working out!
                  • Sander StolkS Sander Stolk
                    My house has its doors in the walls...
                    Sander StolkS 1 Reply Last reply
                    • YveauxY Yveaux
                      Sander StolkS
                      Sander StolkS
                      Sander Stolk
                      Well... connect a very small white wire in the hallway to the top of the door with a magnet.
                      With white ceilings you can put little cables like out of sight
                        @Sander-Stolk ah, OK. I think you can even run it all on batteries if you want
                        • YveauxY Yveaux
                          Sander StolkS
                          Sander StolkS
                          Sander Stolk
                          #40
                          @Yveaux Yes it can BUT...
                          I have 0 succesfull attempts with a APM with removed regulator on 2 AA batteries. For some reason it draws power and within 3 days my batteries are dead. It's something that I will ask on the forum in a while but for now this works all the time so for it is the easy way :)
                          • T
                            tomkxy
                            Here is my a picture of my modded version alt text. I used a Sensebender which is perfect for that use case having already a ATSHA204 and temp/humid sensor on board.
                            • T
                              tomkxy
                              I put a more complete write up of my mod from the previous post on my blog including the link to the sketch.
                              • T tomkxy
                                dynamiteD
                                dynamiteD
                                dynamite
                                @tomkxy Nice write up of the "conversion". One remark to save some time... instead of removing R12 to R16 you can just remove R17 ... same result less effort.
                                  tomkxy
                                  Thanks for pointing that out!
                                  • T tomkxy
                                    TimO
                                    @tomkxy Nice write up! Do you have an idea on the accuracy of the humidity sensor within the case?
                                    T dynamiteD 3 Replies Last reply
                                    • T
                                      tomkxy
                                      I just put it up in my one of my rooms. It works at least at a distance of about 4m. I will try to do some measure at what distance it is working. I'll post the results.
                                      • T TimO
                                        tomkxy
                                        Sorry, just saw that you asked about the humidity sensor. No, I have no idea yet. Need to make some comparison measures.
                                        • korttomaK
                                          korttomaK
                                          korttoma
                                          @tomkxy did you really need the voltage divider? I think the sensebender does a decent job of measuring battery percentage by default.
                                          • Tomas
