  3. Multisensor PIR based on IKEA Molgan
112 Posts 21 Posters 71.9k Views 37 Watching
  • YveauxY Yveaux
    @dynamite Nice work!
    I'm currently working on the following Molgan hack:
    It is a small PCB (the red board) that overlays the original Molgan PCB.
    The original PIR & electronics stay in place.
    LEDs will remain functional (if you want) or can be partially removed to improve battery life, or completely to turn it into a motion-sensor only.
    It uses an SMD nRF24 module, has a mounting spot for SHA204A, FTDI and ISP connectors.
    The layout is currently at the board house.
    I'll report back when I get the PCBs and build one!
    dynamiteD
    dynamiteD
    dynamite
    @Yveaux NICE! Can I get the files for the board as a sneak preview? Do you get the PIR signal / Light control from the same place as I was indicating?
    • dynamiteD dynamite
      @dynamite Send me your email in a chat and it comes your way.
      I'll probably post it all on openhardware.io when it's finished and proven to work.
      Fun thing is I tried the power usage of the original PIR with and without the regulator, and the power usage was actually less with the regulator than without :yum:
      I'll use two of the three batteries to also power my addon board.
      The trigger is taken from the top led, just below the battery cover screw in the picture.
      I could take it from before the transistor, but this way I needed no extra wire.
      dynamiteD 1 Reply Last reply
      • YveauxY Yveaux
        dynamiteD
        dynamiteD
        dynamite
        @Yveaux Sent you a DM with my email adress. Can't you use the voltage level after the regulator? The regulator is rated up to 30 mA.
          @dynamite Possibly. I just wanted to keep options open.
          One wire is required to power the board; either from the batteries, or from the regulator.
          I'll just see what works best.
            This have to be posted on http://www.ikeahackers.net/ when done also.
              @hek Will do just nice, next to the AK47 Hemma Lamp :flushed:
              • YveauxY Yveaux
                dynamiteD
                dynamiteD
                dynamite
                wrote on last edited by dynamite
                #32
                @Yveaux @hek how do you know of the existance of such a site...?:frowning:
                  @dynamite I didn't. Got it from @hek :bowtie:
                  • D
                    danta
                    Did someone succeed in fitting a pro mini and radio in the Molgan while still using the original pir?
                    It looks to me there isn't enough room for the additional components and I'm not sure what part of the pcb I can saw off while still being able to use the original pir.
                    Does anyone have an idea?
                    • D danta
                      dynamiteD
                      dynamiteD
                      dynamite
                      #35
                      Fits.... Ok i need to attach the wites but it will still fit. The NRF can be placed on the other side
                      • Sander StolkS
                        Sander StolkS
                        Sander Stolk
                        wrote on last edited by Sander Stolk
                        #36
                        Bought 3 pcs. to open / modify / try fitting things in it. The thing is that this housing is really perfect to place it on the ceiling or to fit things in. Better than a black box.
                        What I'm going to try is remove all the plastic inside including the batteryhousing but not the "click"-system to mount it.
                        I'm going to try to make it 230 volt compatible with a HLK-PM01 so that I can use it as a PIR, Temp and door sensor and connect it at the ceiling.
                        Let you know how things are working out!
                        • Sander StolkS Sander Stolk
                          My house has its doors in the walls...
                          Sander StolkS 1 Reply Last reply
                          • YveauxY Yveaux
                            Sander StolkS
                            Sander StolkS
                            Sander Stolk
                            Well... connect a very small white wire in the hallway to the top of the door with a magnet.
                            With white ceilings you can put little cables like out of sight
                              @Sander-Stolk ah, OK. I think you can even run it all on batteries if you want
                              • YveauxY Yveaux
                                Sander StolkS
                                Sander StolkS
                                Sander Stolk
                                #40
                                @Yveaux Yes it can BUT...
                                I have 0 succesfull attempts with a APM with removed regulator on 2 AA batteries. For some reason it draws power and within 3 days my batteries are dead. It's something that I will ask on the forum in a while but for now this works all the time so for it is the easy way :)
                                • T
                                  tomkxy
                                  Here is my a picture of my modded version alt text. I used a Sensebender which is perfect for that use case having already a ATSHA204 and temp/humid sensor on board.
                                  • T
                                    tomkxy
                                    I put a more complete write up of my mod from the previous post on my blog including the link to the sketch.
                                    • T tomkxy
                                      dynamiteD
                                      dynamiteD
                                      dynamite
                                      @tomkxy Nice write up of the "conversion". One remark to save some time... instead of removing R12 to R16 you can just remove R17 ... same result less effort.
                                        tomkxy
                                        Thanks for pointing that out!
                                        • T tomkxy
                                          TimO
                                          @tomkxy Nice write up! Do you have an idea on the accuracy of the humidity sensor within the case?
                                          T dynamiteD 3 Replies Last reply
