  3. Parking Sensor
Parking Sensor
74 Posts 28 Posters 56.5k Views 18 Watching
  • msevM
    msevM
    msev
    This sketch doesn't support MQTT right? Has anyone maybe a version of this sketch which outputs MQTT? Or could you guys maybe guide me on how I would do it?
    • TD22057T
      TD22057T
      TD22057
      MySensors uses radios to communicate with a gateway over RF. The gateway can be set up to convert those messages to/from MQTT (or use software to convert the serial messages to/from MQTT). So there aren't going to be any sensor sketches with MQTT in them. If you use an ESP, then you could send MQTT directly but then you're on WIFI and don't need MySensors.
      msevM 1 Reply Last reply
      • TD22057T TD22057
        msevM
        msevM
        msev
        I meant for the esp8266.
          Should work, start with the MQTT ESP gateway (in development branch) and copy the relevant parts from the parking sensor example.
            msevM
            msevM
            msev
            wrote on last edited by msev
            #62
            @hek I'll try, then I'll show the sketch for fixing mistakes :D...Also Newping library doesn't work on ESP, so I'll have to use Ultrasonic library. :/
            • C chilump
              @Dan-S. Can a single 5v 2a adapter be used? In that case would everything be wired to the single power adapter?
              mjbokM
              mjbokM
              mjbok
              @chilump Do you have a picture of your final product (or a wiring schematic)? I just discovered this project and don't want to reinvent the wheel.
              • korttomaK
                korttomaK
                korttoma
                #64
                The wiring should be quite strait forward and mentioned in form of comments in the sketch:
                #define NEO_PIN      4 // NeoPixels input pin
                #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
                #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
                Basically pin 4 on the arduino goes to the input pin on the NeoPixel LED ring
                The distance sensor is also described here -> https://www.mysensors.org/build/distance
                Is there something else that is not clear how it should be connected?
                • Tomas
                mjbokM 1 Reply Last reply
                • korttomaK korttoma
                  mjbokM
                  mjbokM
                  mjbok
                  @korttoma This is a total newb question, but it is all about the power. I've done stuff with Pi's before, but this is my first foray into the arudino world. Everything I've read says to power the ring apart from the Arduino (don't use the 5v pin). I am going to use an Uno and I thought I could get a 9v 2a wart and power the board through the barrel connector, using a regulator jumpered off the wart before the board to step down to 5v. However this is all guess work on my part. I figured people have done this, if I saw a finished product I could figure out the rest myself. Thanks for the help.
                  korttomaK 1 Reply Last reply
                  • mjbokM mjbok
                    korttomaK
                    korttomaK
                    korttoma
                    @mjbok yeah, there is some discussion earlier in this tread about the current consumption of the LED ring and there is no way any 5V pin on the Arduino can deliver the current needed so yes a separate voltage regulator from a 9V wart sounds like a good plan. Just make sure you have common GROUND and some capacitors to filter out disturbance.
                    btw, I found an article about powering NeoPixels here -> https://learn.adafruit.com/adafruit-neopixel-uberguide/power
                    • Tomas
                      mjbokM
                      mjbokM
                      mjbok
                      @korttoma I plan to do something like this (quick and dirty with MSpaint). I've ordered all my parts, now just wait.
                      • korttomaK
                        korttomaK
                        korttoma
                        Yeah, that's how I would do it also, just make sure your 5V regulator can handle enough current.
                        • Tomas
                        • samjaynesS
                          samjaynesS
                          samjaynes
                          Has anyone done this project without the neopixel? I am looking to use one or more LEDs to simulate... maybe green yellow red.
                          I tried to start peeling off the neopixel sections, but ended up ruining the sketch.
                          Care to share the code for the non-nepixel model?
                          • rchampR
                            rchampR
                            rchamp
                            wrote on last edited by rchamp
                            #70
                            Hey There, I'm getting ready to play around with this once a few more parts arrive to give me ideas on other potential uses for distance sensor and LEDs, but one thing i'm confused about.
                            The sketch mentioned using pins 4, 5 and 6.
                            Adafruit and all docs i've seen and played around with mention that neopixels need a PWM pin to operate.
                            Pin 4 doesn't appear to be PWM (on pro mini)
                            I see that trig and echo are typically wired to 5 & 6 in most cases which are PWM.
                            so in short, not enough PWM pins .
                            Are the neopixels still working because the signal is being sent at "full" brightness?
                            • Boots33B
                              Boots33B
                              Boots33
                              Unlike the dumb rgb strips neopixels don't need a pwm pin to dim and mix colours. Each rgb led has its own controller chip.
                              • sinczeS
                                sinczeS
                                sincze
                                MySensors Evangelist
                                Received all the parts let's see if we can build a working 2.0.0 solution ;-)
                                • Sander StolkS
                                  Sander StolkS
                                  Sander Stolk
                                  Here a working example with a 16-Bit ring with radio because the misses hit the fence for the second time this year with the car.
                                  Sensor in action <--Video
                                    Wooo, cool to see it live!
