  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.5k Views 69 Watching
  • rollercontainerR rollercontainer
    Thx, Gert. Are you using 1.5 or 2.0.0beta?
    GertSandersG
    GertSandersG
    GertSanders
    @rollercontainer
    I use the 2.0 beta
    • rollercontainerR
      rollercontainerR
      rollercontainer
      Bought another 2 radios from different dealers. The one with the blob on the die is going down to 2mA, but isnt working at all (node does not come up). The next one is working, but again 15mA. This is frustrating. Anyone here with a good source for radio modules?
        GertSandersG
        GertSandersG
        GertSanders
        @rollercontainer
        • BobcatB
          BobcatB
          Bobcat
          @26872, It's my first post here and I had to register so that I could give you my regards for your work and for sharing it with us! Just ordered a batch of your v2 boards.
          • BobcatB Bobcat
            GertSandersG
            GertSandersG
            GertSanders
            @Bobcat
            BobcatB 1 Reply Last reply
            • GertSandersG GertSanders
              @Bobcat
              BobcatB
              BobcatB
              Bobcat
              @GertSanders
              • BobcatB Bobcat
                @GertSanders
                GertSandersG
                GertSandersG
                GertSanders
                @Bobcat
                • badmannenB
                  badmannenB
                  badmannen
                  Hello all
                  I´m Henrik, first post here and sort of beginner at this ( use to do some embedded stuff some 15 years ago and picked it up again recently )
                  I just did a shopping list for this project, Version 2.0 if I got it correct =)
                  straight pins
                  Only thing extra needed I think would be some additional cable and a arduino UNO or some other way to program the single chips. But I assume you already have a UNO if you read this :)
                  //Henrik
                  rPi 3 - UNO R3 - Mini - Nano - custom
                  • badmannenB
                    badmannenB
                    badmannen
                    can someone tell me if I can find Version 2 on the new site: http://dangerousprototypes.com/store/pcbs
                    I never ordered any pcb´s like this before so I don´t want to get it wrong =D.
                    thanks for any help
                    hekH 1 Reply Last reply
                    • badmannenB badmannen
                      thanks for any help
                      @badmannen
                      • hugowsH
                        hugowsH
                        hugows
                        Received mine from DirtyPCBs - I just wanted to test the whole system. I guess my first question is: how do you guys break them apart? Since tthey come in 3-circuits-per-board with little holes.
                        I don't want to ruin them! :)
                        m26872M 1 Reply Last reply
                        • hugowsH hugows
                          m26872M
                          m26872M
                          m26872
                          @hugows
                          https://forum.mysensors.org/topic/2067/my-slim-2aa-battery-node/273
                          • hugowsH
                            hugowsH
                            hugows
                            Thanks, it worked!
                            • hugowsH
                              hugowsH
                              hugows
                              Are there any guides on how to assemble the 2.0 version?
                              Thanks in advance,
                              hugo
                              thazlett144T 1 Reply Last reply
                              • hugowsH hugows
                                Thanks in advance,
                                hugo
                                thazlett144T
                                thazlett144T
                                thazlett144
                                @hugows C4 goes over the ground and VCC of the NRF radio. I'm not sure about but C5, from some pictures I have seen I think it goes in the same place as C4 but I may be wrong. I have left that out without an issue.
                                hugowsH 1 Reply Last reply
                                • thazlett144T thazlett144
                                  hugowsH
                                  hugowsH
                                  hugows
                                  wrote on last edited by hugows
                                  #335
                                  @thazlett144 Thanks. like this then?
                                  • R1
                                  • C1
                                  • C2
                                  • C3
                                  • Atmega socket
                                  • NRF24 radio
                                  • 6 pin angled connector
                                  • thazlett144T
                                    thazlett144T
                                    thazlett144
                                    wrote on last edited by thazlett144
                                    #336
                                    C4 in your picture looks correct to me. You could put C4 up on the edge under where the radio would be as well. You have VCC up on the edge. I think the pins adjacent to that are ground too. EDIT: I think I replied before you edited your picture :-)
                                    • m26872M
                                      m26872M
                                      m26872
                                      • m26872M m26872
                                        hugowsH
                                        hugowsH
                                        hugows
                                        @m26872 C5 would be in paralllel to C4, right?
                                        • hugowsH hugows
                                          m26872M
                                          m26872M
                                          m26872
