  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.5k Views 69 Watching
  • badmannenB
    badmannenB
    badmannen
    can someone tell me if I can find Version 2 on the new site: http://dangerousprototypes.com/store/pcbs
    I never ordered any pcb´s like this before so I don´t want to get it wrong =D.
    thanks for any help
    rPi 3 - UNO R3 - Mini - Nano - custom
    hekH 1 Reply Last reply
    • badmannenB badmannen
      thanks for any help
      @badmannen
      • hugowsH
        hugowsH
        hugows
        Received mine from DirtyPCBs - I just wanted to test the whole system. I guess my first question is: how do you guys break them apart? Since tthey come in 3-circuits-per-board with little holes.
        I don't want to ruin them! :)
        m26872M 1 Reply Last reply
        • hugowsH hugows
          m26872M
          m26872M
          m26872
          @hugows
          https://forum.mysensors.org/topic/2067/my-slim-2aa-battery-node/273
          • hugowsH
            hugowsH
            hugows
            Thanks, it worked!
            • hugowsH
              hugowsH
              hugows
              Are there any guides on how to assemble the 2.0 version?
              Thanks in advance,
              hugo
              thazlett144T 1 Reply Last reply
              • hugowsH hugows
                Thanks in advance,
                hugo
                thazlett144T
                thazlett144T
                thazlett144
                @hugows C4 goes over the ground and VCC of the NRF radio. I'm not sure about but C5, from some pictures I have seen I think it goes in the same place as C4 but I may be wrong. I have left that out without an issue.
                hugowsH 1 Reply Last reply
                • thazlett144T thazlett144
                  hugowsH
                  hugowsH
                  hugows
                  wrote on last edited by hugows
                  #335
                  @thazlett144 Thanks. like this then?
                  • R1
                  • C1
                  • C2
                  • C3
                  • Atmega socket
                  • NRF24 radio
                  • 6 pin angled connector
                  • thazlett144T
                    thazlett144T
                    thazlett144
                    wrote on last edited by thazlett144
                    #336
                    C4 in your picture looks correct to me. You could put C4 up on the edge under where the radio would be as well. You have VCC up on the edge. I think the pins adjacent to that are ground too. EDIT: I think I replied before you edited your picture :-)
                    • m26872M
                      m26872M
                      m26872
                      • m26872M m26872
                        hugowsH
                        hugowsH
                        hugows
                        @m26872 C5 would be in paralllel to C4, right?
                        • hugowsH hugows
                          m26872M
                          m26872M
                          m26872
                          • siodS
                            siodS
                            siod
                            I've set up two sensors with 2 reed switches and 1 HTU21D attached. When I was testing them around 60 cm away from my gateway they worked very fine. Now I moved them to their final destination which is around 8-10 meters away from the gateway and now they don't reach the gateway anymore. Any idea what could cause this? Any way to increase the range?
                            still learning...
                            W 1 Reply Last reply
                            • siodS siod
                              W
                              W
                              wergeld
                              @siod
                              • siodS
                                siodS
                                siod
                                wrote on last edited by siod
                                #342
                                each one goes around a corner and so one wall is partly between the nodes and the gateway and it´s not even concrete. I have one node in my basement attached to an arduino nano and I have no range problems...
                                edit:
                                Node sktech:
                                // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
                                // Define Node ID
                                #define MY_NODE_ID 4
                                //Batterysensor
                                int oldBatteryPcnt = 0;
                                #define CHILD_ID_BATT 7
                                //Kontaktschalter
                                //#include <Bounce2.h>
                                int oldValueReed1=-1;
                                int oldValueReed2=-1;
                                //Tempsensor
                                #include <SparkFunHTU21D.h>
                                #define CHILD_ID_HUM 3
                                #define CHILD_ID_TEMP 4
                                //tempsensor
                                HTU21D myHumidity;
                                float lastTemp;
                                float lastHum;
                                //boolean metric = true;
                                //Messages
                                //Battery
                                // Kontaktschalter
                                //TempMessage
                                void presentation(){
                                  sendSketchInfo("Küche Messstation", "2.0", true);
                                  present(CHILD1_ID, S_DOOR);
                                  present(CHILD2_ID, S_DOOR);
                                  //Tempsensor
                                  present(CHILD_ID_HUM, S_HUM);
                                  //Battery
                                //Setup
                                  //Serial.begin(9600);
                                  Serial.println("Hello!");
                                  //Batterysensor
                                   analogReference(INTERNAL1V1);
                                   analogReference(INTERNAL);
                                //Tempsensor
                                  myHumidity.begin();
                                  Serial.println("...done!");
                                // Setup Kontaktschalter 1
                                  pinMode(BUTTON1_PIN,INPUT);
                                    // Activate internal pull-up
                                // Setup Kontaktschalter 2
                                  pinMode(BUTTON2_PIN,INPUT);
                                //Starte den Loop
                                  //Batterysensor
                                  // get the battery Voltage
                                  delay(1000);
                                   #ifdef DEBUG
                                   #ifdef DEBUG
                                   Serial.print(batteryV);
                                   Serial.println(" V");
                                   Serial.print(batteryPcnt);
                                   Serial.println(" %");
                                     // Power up radio after sleep
                                     oldBatteryPcnt = batteryPcnt;
                                  //Kontakstschalter 1
                                  sleep(10);
                                  // Get the update value
                                     // Send in the new value
                                     oldValueReed1 = valueReed1;
                                  //Kontakstschalter 2
                                     oldValueReed2 = valueReed2;
                                 //Tempsensor
                                  if (isnan(temp)) {
                                    lastTemp = temp;
                                    Serial.print("T: ");
                                    Serial.println(temp);
                                  if (isnan(humd)) {
                                  } else if (humd != lastHum) {
                                      lastHum = humd;
                                      Serial.print("H: ");
                                      Serial.println(humd);
                                 Serial.println("Sleep...");
                                Gateway sketch:
                                // Set MQTT client id
                                //#define MY_W5100_SPI_EN 4
                                // radio on the same spi bus.
                                  #define MY_SOFTSPI
                                #ifndef MY_RF24_CE_PIN
                                  #define MY_RF24_CE_PIN 5
                                #ifndef MY_RF24_CS_PIN
                                  #define MY_RF24_CS_PIN 6
                                #define MY_PORT 1883
                                // Flash leds on rx/tx/err
                                // Set blinking period
                                // Enable inclusion mode
                                #include <Ethernet.h>
                                MyConfig.h
                                 * @file MyConfig.h
                                #ifndef MyConfig_h
                                #define MyConfig_h
                                #include <stdint.h>
                                *  Serial and debug options
                                // I_DEBUG requests are:
                                // V: CPU voltage
                                // F: CPU frequency
                                // M: free memory
                                //#define MY_SPECIAL_DEBUG
                                //#define MY_DISABLED_SERIAL
                                //#define MY_CORE_ONLY
                                #ifdef MY_DISABLED_SERIAL
                                #undef MY_DEBUG
                                 * @def MY_BAUD_RATE
                                #ifndef MY_BAUD_RATE
                                #define MY_BAUD_RATE 115200
                                //#define MY_RADIO_NRF24
                                //#define MY_RS485
                                 * @def MY_NODE_ID
                                #ifndef MY_NODE_ID
                                #define MY_NODE_ID AUTO
                                 * @def MY_PARENT_NODE_ID
                                #ifndef MY_PARENT_NODE_ID
                                 * @def MY_OTA_FLASH_SS
                                #ifndef MY_OTA_FLASH_SS
                                #define MY_OTA_FLASH_SS 8
                                 * @def MY_OTA_FLASH_JDECID
                                 * @brief Flash jdecid.
                                #ifndef MY_OTA_FLASH_JDECID
                                *  Gateway config
                                 * @def MY_GATEWAY_MAX_CLIENTS
                                *  Information LEDs blinking
                                // disabled in the gateway.
                                // off when blinking
                                *  Message Signing Settings
                                 * @def MY_SIGNING_ATSHA204
                                //#define MY_SIGNING_ATSHA204
                                 * @def MY_SIGNING_SOFT
                                //#define MY_SIGNING_SOFT
                                *  RS485 Driver Defaults
                                 * @def MY_RS485_BAUD_RATE
                                 * @brief The RS485 BAUD rate.
                                #ifndef MY_RS485_BAUD_RATE
                                *  NRF24L01P Driver Defaults
                                 * @def MY_DEBUG_VERBOSE_RF24
                                 * @def MY_RF24_SPI_MAX_SPEED
                                 * @def MY_RF24_CE_PIN
                                		#define MY_RF24_CE_PIN 4
                                		#define MY_RF24_CE_PIN 27
                                		#define MY_RF24_CE_PIN 9
                                 * @def MY_RF24_CS_PIN
                                		#define MY_RF24_CS_PIN 15
                                		#define MY_RF24_CS_PIN 3
                                		#define MY_RF24_CS_PIN 10
                                 * @def MY_RF24_PA_LEVEL
                                #ifndef MY_RF24_PA_LEVEL
                                 * @def MY_RF24_CHANNEL
                                #ifndef MY_RF24_CHANNEL
                                #define MY_RF24_CHANNEL	76
                                 * @def MY_RF24_DATARATE
                                #ifndef MY_RF24_DATARATE
                                 * @def MY_RF24_BASE_RADIO_ID
                                #ifndef MY_RF24_BASE_RADIO_ID
                                 * @def MY_RF24_ADDR_WIDTH
                                 * @brief RF24 address width.
                                #ifndef MY_RF24_ADDR_WIDTH
                                #define MY_RF24_ADDR_WIDTH 5
                                 * @def MY_RF24_SANITY_CHECK
                                #define MY_RF24_SANITY_CHECK
                                //#define MY_SOFTSPI
                                 * @def MY_SOFT_SPI_SCK_PIN
                                 * @brief Soft SPI SCK pin.
                                #ifndef MY_SOFT_SPI_SCK_PIN
                                 * @def MY_SOFT_SPI_MISO_PIN
                                 * @brief Soft SPI MISO pin.
                                #ifndef MY_SOFT_SPI_MISO_PIN
                                 * @def MY_SOFT_SPI_MOSI_PIN
                                 * @brief Soft SPI MOSI pin.
                                #ifndef MY_SOFT_SPI_MOSI_PIN
                                *  RFM69 Driver Defaults
                                 * @def MY_RFM69_FREQUENCY
                                #ifndef MY_RFM69_FREQUENCY
                                 * @def MY_IS_RFM69HW
                                //#define MY_IS_RFM69HW
                                 * @def MY_RFM69HW
                                #ifdef MY_IS_RFM69HW
                                	#define MY_RFM69HW true
                                	#define MY_RFM69HW false
                                 * @def MY_RFM69_NETWORKID
                                #ifndef MY_RFM69_NETWORKID
                                 * @def MY_RF69_IRQ_PIN
                                 * @brief RF69 IRQ pin.
                                #ifndef MY_RF69_IRQ_PIN
                                 * @def MY_RF69_SPI_CS
                                #ifndef MY_RF69_SPI_CS
                                 * @def MY_RF69_IRQ_NUM
                                 * @brief RF69 IRQ pin number.
                                #ifndef MY_RF69_IRQ_NUM
                                //#define MY_GATEWAY_W5100
                                //#define MY_GATEWAY_ENC28J60
                                //#define MY_GATEWAY_ESP8266
                                 * @def MY_PORT
                                #ifndef MY_PORT
                                #define MY_PORT 5003
                                //#define MY_USE_UDP
                                 * @def MY_IP_RENEWAL_INTERVAL
                                 * @def MY_MAC_ADDRESS
                                #ifndef MY_MAC_ADDRESS
                                 * @ingroup internals
                                 * under some form of attack.
                                 * - LDB (Locked During Boot)
                                 * @def MY_NODE_LOCK_FEATURE
                                 * @def MY_NODE_UNLOCK_PIN
                                #ifndef MY_NODE_UNLOCK_PIN
                                #define MY_NODE_UNLOCK_PIN 14
                                /** @}*/ // Node lock group
                                #if DOXYGEN
                                edit2:
                                Now I get this this from the node on my gateway´s serial monitor:
                                0;255;3;0;9;TSP:MSG:BC
                                0;255;3;0;9;TSP:CHKUPL:OK
                                0;255;3;0;9;TSP:MSG:GWL OK
                                0;255;3;0;9;TSP:SANCHK:OK
                                and so on...
                                still learning...
                                • carlekiC
                                  carlekiC
                                  carleki
                                  I have ordered the 2.0 boards, they are on their way to my home :)
                                  I'm plannign to use them as :
                                  • temperature node
                                  • door sensor
                                  Am I right ?
                                  • carlekiC carleki
                                    • temperature node
                                    • door sensor
                                    Am I right ?
                                    m26872M
                                    m26872M
                                    m26872
                                    @carmelo42
                                    carlekiC 1 Reply Last reply
                                    • m26872M m26872
                                      @carmelo42
                                      carlekiC
                                      carlekiC
                                      carleki
                                      @m26872 said:
                                      @carmelo42
                                      Thanks to you for providing us theses files :)
                                      Ok, my mistake (I juste received my 10 MOhm resistor ;)
                                      Perfect, I just have to wait now for the little yellow packet ;)
                                      • carlekiC
                                        carlekiC
                                        carleki
                                        I have received yesterday my little packet from DirtyPCB :)
                                        11 PCBs, so 33 sensors :)
                                        I'm just wondering where the C5 capactior will go on the board .. Can't figure out :(
                                        J 1 Reply Last reply
                                        • carlekiC carleki
                                          J
                                          J
                                          jeti
                                          wrote on last edited by jeti
                                          #347
                                          @carmelo42: maybe this helps, all Cs and the R assembled!
