  3. Microwave Radar Module as PIR replacement.
42 Posts 21 Posters 48.0k Views 26 Watching
  • greglG
    greglG
    gregl
    @danta lol - I too was inspired by this thread and bought a couple of modules which arrived last week. Mine are identical to those in your first ebay link.
    I've not tried to use them yet, but I think you use them identical to a PIR. ie VCC, GND and Signal.
    As @Yveaux mentioned... these use the same IC as the PIR's, but these do seem to lack the ability to tune the sensitivity and timeouts like the PIR's have.
    So in short... try to use them as you would a PIR.
      wrote on last edited by hek
      @danta
      Interesting! Must have missed this topic... Never seen those before.
      • mark_vennM
        mark_vennM
        mark_venn
        There are units that are fitted into light fittings that are being used as fall detectors; a PIR knows someone is in the room but something measuring the height of the person moving around that suddenly notices an increase in the distance can trigger an alarm. An increase in distance can mean that the person is now on the floor and no longer vertical. Something like this could be used maybe?
        • epierreE
          epierreE
          epierre
          I have this one, but did not have time to test it yet 2-16M : Gravity: Digital Microwave Sensor (Motion Detection)
          http://www.dfrobot.com/index.php?route=product/product&product_id=1403#.VzNKlfndWnk
          z-wave - Vera -> Domoticz
          • D
            danta
            I started playing with the first module listed in my previous post:
            The module is really as easy to connect as a normal pir sensor. There are small text on the pcb. The top most connection (indicated with a 'o') is the sensor output (3,3v for a high and 0v for a low). The middle connection is ground and the bottom connection is Vcc (3,3 to 20v according to the ebay listing).
            My setup was really simple, just a chinduino powered via usb. The sensor connected to +5v, ground and the output to analog pin A0 (I could have used a digital pin).
            The first results are really promising. Some characteristics:
            • The sensor is omnidirectional.
            • Output is high (3,3V) for 30s when movement is detected
            • New movement will restart the 30s timer
            • 'low' power consumption. Triggered: 1.5mA; Idle: 1.4mA (measured @5v using a normal multimeter)
            • The sensor doesn't react to temperature/light fluctuations (unlike most pir sensors)
            Some range tests that triggered the output (note that this is probably not the maximum distance, just the stuff I tested):
            • 0-4 meter distance (clear line of sight), moving my arm
            • 5-8 meter distance (clear line of sight), walking around
            • walking around at 5 meter distance with an indoor brick wall between me and the sensor
            Stuff that I still need to test:
            • Can the sensitivity be tweaked
            • How to change the trigger timer to something else than 30s
            • Duration test to see if the module is prone to false positives
            • D
              drock1985
              hi @danta
              Did you have any luck removing the 30 second delay/counter from the radar module?
              My Projects
              2 Door Chime Sensor
              Washing Machine Monitor
              • V
                V
                vil1driver
                wrote on last edited by vil1driver
                @danta, this device can detect you when you are in another room ?
                @drock1985,
                detection delay can be adjusted from 1 second to hundreds of second (two minutes max) by adjusting R6 resistor on the board as explained on this Taobao page (Chinese). By default there’s no resistor and the delay is 30 seconds, and you can adjust the delay by using 1K to 250K resistor.
                • D
                  danta
                  wrote on last edited by danta
                  @drock1985, Didn't test it yet. I was playing with the other module I bought. Too bad that the other module only seems to work stable from 6V and up (I should have known it, as it was listed on ebay as 7-12v). I was just hoping that it would work at lower voltages. So I will probably stick with the first module for now.
                  @vil1driver, Yes, detection works through wall and door. I only tested it at a distance of about 5 meter with a brick indoor wall between me and the sensor. I also had to walk around before the sensor picked me up (just lifting my arm wasn't enough).
                  • korttomaK
                    korttomaK
                    korttoma
                    Seems like these modules are using the BISS0001 so it will probably not be possible to run them on a battery node because the BISS has a 3V minimum voltage demand. The current consumption is anyhow also a bit to high for battery application (3mA).
                    • Tomas
                    Luke CorkillL 1 Reply Last reply
                    • korttomaK korttoma
                      Luke CorkillL
                      Luke CorkillL
                      Luke Corkill
                      I've bought a couple of these and in many ways have been impressed.
                      My only issue is that I find them far too sensitive (e.g. Detecting movement through wallls)
                      Has anyone managed to reduce the sensitivity?
                      • bjacobseB
                        bjacobseB
                        bjacobse
                        To reduce sensitivity workaround - Can you place them high and point them in an angle pointing downwards to ground? will this work?
                        • greglG
                          greglG
                          gregl
                          There has been some chat about these modules over on Pete Scargill's site.
                          Seems that using some aluminium foil you can create a shield so there are at least directional.
                          Here is the thread ( starting at the relevant comment)
                          http://tech.scargill.net/microwave-radar/#comment-16685
                          I have not tested this myself yet...
                          bjacobseB 1 Reply Last reply
                          • greglG gregl
                            bjacobseB
                            bjacobseB
                            bjacobse
                            #25
                            @gregl
                            Thanks for good link :-)
                            Yes offcurse I'm so sloooooow we need a proper waveguide or a hornet antenna, so ensure correct directionality ;-)
                            This might not be needed, but a hint what could be done: http://hforsten.com/horn-antenna-for-radar.html
                            When my doppler radar arrives I will make a trial with a small tinbox I don't know about using alufoil is good for a long periode used outside
                            http://hackaday.com/2014/02/24/guest-post-try-radar-for-your-next-project/#jp-carousel-115578
                            • YveauxY Yveaux
                              @scalz e.g. at http://s.aliexpress.com/AbEBreya
                              0_1459859566297_Microwave-Radar-Module-Body-Sensing-Radar-Switch-DC-5V-10M-Home-Control-.jpg_640x640.jpg
                              0_1459859704122_Microwave-Radar-Module-Body-Sensing-Radar-Switch-DC-5V-10M-Home-Control-.jpg_640x640 (1).jpg
                              cimba007C
                              cimba007C
                              cimba007
                              wrote on last edited by cimba007
                              #26
                              @Yveaux I did some extensive testing on the FC1816 module and I thought I might drop my experience:
                              http://electronics.stackexchange.com/questions/226031/pinout-of-microwave-motion-sensor-fc1816
                              In the end I used an 150ohm Series resistor + ~100µF cap behind this to power the FC1816. This eliminated much of the leftover noise. If this is not enough I presented a way to lower the module amplification. In the end I deactivated the biss-trigger output alltogether and grabbed the raw signal. Doing some manual processing:
                              1. take 100 reads
                              2. get the stddev (statistics library)
                              3. high stddev = high fluctuation in values = movement
                              Take a look at my current working copy of my code for the FC1816:
                              Some notes:
                              I power the VCC of the FC1816 from some arduino pins. Thus I can deactivate the microwave sensor at will. This is still not recommended. If you visit the previous link you can see that the BISS has some kind of "warmup"-Period.
                              I use 3,3Volt to power the NRF24, the arduino and the FC1816 and suffered no strange consequences so far.
                              Get get some insight about the link quality of the NRF24 I made the function RF24_getObserverTX() accessible from user-space:
                              MySensors\drivers\RF24\RF24.cpp
                              uint8_t RF24_getObserveTX(void)
                              	return RF24_readByteRegister(OBSERVE_TX);
                              MySensors\drivers\RF24\RF24.h
                              uint8_t RF24_getObserveTX(void);
                              The Idea behind the OBSERVE_TX register is that the lower byte presents the number of retrys the NRF24 used in the last send.
                              The upper 4 bits present the number of total failed packets. I suggest using (0x0F & RF24_getObserveTX()) to get a usable number 0-15 presenting the retry-count. Anything > 0 suggests a packetloss on your link. 15 most likely will mean you ran into an complete fail as the max number of retrys was exhausted.
                              This number might be capped by
                              // ARD, auto retry count
                              #define RF24_ARC 15
                              from the RF24.h driver-file.
                              TO not run into compiling errors you might need:
                              http://arduiniana.org/libraries/streaming/
                              https://github.com/RobTillaart/Arduino/tree/master/libraries/Statistic
                              MicrowaveRadarSensor.ino
                              #include <Streaming.h>
                              #include "Statistic.h"
                               * Version 1.0 - Henrik EKblad
                               * Example sketch showing how to measue light level using a LM393 photo-resistor
                               * http://www.mysensors.org/build/light
                              #define MY_NODE_ID 10
                              #define MY_BAUD_RATE 57600
                              #define LIGHT_SENSOR_ANALOG_PIN A3
                              #define MICRO_SENSOR_ANALOG_PIN A1
                              unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
                              #define CHILD_ID_LIGHT 0
                              #define CHILD_ID_MICRO 0
                              #define TRIPPED_THRESHOLD 50
                              MyMessage msg_light(CHILD_ID_LIGHT, V_LIGHT_LEVEL); // 23
                              MyMessage msg_micro(CHILD_ID_MICRO, V_TRIPPED);     // 16
                              MyMessage msg_micro_debug(0,V_VAR1);   // 24
                              MyMessage msg_obstx_debug(0,V_VAR2);   // 25
                              void before()
                                // LightSensor
                                pinMode(A3,INPUT_PULLUP);
                                pinMode(A2,OUTPUT);
                                digitalWrite(A2,LOW);
                                // Microwave
                                pinMode(5,OUTPUT);        // VCC BISS0001
                                digitalWrite(5,HIGH);
                                pinMode(6,OUTPUT);        // Enabled
                                digitalWrite(6,LOW);      // Enable
                                pinMode(7,OUTPUT);        // GND
                                digitalWrite(7,LOW);
                                pinMode(8,OUTPUT);        // VCC Radar
                                digitalWrite(8,HIGH);
                                pinMode(A1,INPUT);        // PIR 2nd Amplification Stage
                                // Other
                              void presentation()  {
                                sendSketchInfo("Microwave+Light", "1.0");
                                // https://www.mysensors.org/download/serial_api_20#sensor-type
                                present(CHILD_ID_MICRO, S_MOTION);
                                //present(0, S_ARDUINO_NODE);
                                // Report VCC
                                static long vcc = readVcc();
                                static int vccpercent = map(vcc,1800,3280,0,100);
                                sendBatteryLevel(max(min(vccpercent,100),0),false);
                                Serial << "| vcc: ";
                                p(F("%4d"),vcc);
                                Serial << " ";
                                // Required for ack
                                //wait(100);
                                // Report LightLevel
                                analogRead(LIGHT_SENSOR_ANALOG_PIN);
                                int lightLevel_raw = analogRead(LIGHT_SENSOR_ANALOG_PIN);
                                int lightLevel = (1023-lightLevel_raw)/10.23; // as of 1023 !!
                                Serial << "| light_raw: ";
                                p(F("%4d"),lightLevel_raw);
                                Serial << " ";
                                Serial << "| light: ";
                                p(F("%3d"),lightLevel);
                                Serial << " ";
                                send(msg_light.set(lightLevel),false);
                                // Report WirelessLink Information
                                Serial << "| observe_tx: ";
                                uint8_t obstx = RF24_getObserveTX();
                                p(F("%X"),obstx);
                                Serial << " ";
                                send(msg_obstx_debug.set(0x0F&obstx),false);
                                // Report Microwave
                                Statistic mw_s;
                                mw_s.clear();
                                delay(90);
                                analogRead(MICRO_SENSOR_ANALOG_PIN);
                                delay(10);
                                for(int i = 0; i < 1000; i++)
                                  mw_s.add(analogRead(MICRO_SENSOR_ANALOG_PIN));
                                  delay(1);
                                Serial << "| mw_raw: ";
                                int stddev = mw_s.pop_stdev();
                                p(F("%4d"),stddev);
                                Serial << " ";
                                Serial << "| mw_min: ";
                                int minimum = mw_s.minimum();
                                p(F("%4d"),minimum);
                                Serial << " ";
                                Serial << "| mw_max: ";
                                int maximum = mw_s.maximum();
                                p(F("%4d"),maximum);
                                Serial << " ";
                                Serial << "| mw: " << (stddev > TRIPPED_THRESHOLD ? "1" : "0") << " ";
                                send(msg_micro_debug.set(stddev),false);
                                while(!send(msg_micro.set(stddev > TRIPPED_THRESHOLD ? "1" : "0"),true))
                                  wait(10);
                                if(isTransportOK())
                                  wait(100);
                                  wait(1000);
                                Serial << endl;
                                //mysleep(500);
                              // https://forum.mysensors.org/topic/3463/m_ack_variable-or-m_set_variable/2
                                if (message.isAck()) {
                                    Serial.print("| GW ack");
                              Helper.ino
                              long readVcc() {
                                //result *= 1.0637;
                              #include <stdarg.h>
                              void p(const __FlashStringHelper *fmt, ... ){
                                char buf[128]; // resulting string limited to 128 chars
                                va_list args;
                                va_start (args, fmt);
                              #ifdef __AVR__
                                vsnprintf_P(buf, sizeof(buf), (const char *)fmt, args); // progmem for AVR
                                vsnprintf(buf, sizeof(buf), (const char *)fmt, args); // for the rest of the world
                                va_end(args);
                                Serial.print(buf);
                              void mysleep(int SLEEP_TIME)
                                  if(isTransportOK()){
                                    Serial << "| wait ";
                                    wait(25);
                                    Serial << "| zZz > ";
                                    sleep(SLEEP_TIME);
                                    Serial << "| < zZz " << endl;
                                  else {
                                    wait(1000);
                              • cimba007C cimba007
                                1. take 100 reads
                                Some notes:
                                #define RF24_ARC 15
                                void before()
                                  // LightSensor
                                  pinMode(A2,OUTPUT);
                                  // Microwave
                                  // Other
                                  // Report VCC
                                  p(F("%4d"),vcc);
                                  Serial << " ";
                                  // Required for ack
                                  //wait(100);
                                  Serial << " ";
                                  Serial << " ";
                                  p(F("%X"),obstx);
                                  Serial << " ";
                                  // Report Microwave
                                  Statistic mw_s;
                                  mw_s.clear();
                                  delay(90);
                                  delay(10);
                                    delay(1);
                                  p(F("%4d"),stddev);
                                  Serial << " ";
                                  Serial << " ";
                                  Serial << " ";
                                    wait(10);
                                  if(isTransportOK())
                                    wait(100);
                                    wait(1000);
                                  Serial << endl;
                                  //mysleep(500);
                                Helper.ino
                                long readVcc() {
                                  //result *= 1.0637;
                                #include <stdarg.h>
                                  va_list args;
                                #ifdef __AVR__
                                  va_end(args);
                                  Serial.print(buf);
                                      wait(25);
                                      sleep(SLEEP_TIME);
                                    else {
                                      wait(1000);
                                @cimba007 wow, you did some serious research there! (I see you make good use of the arduino plot function)
                                I'll certainly come back to your research once I start with this sensor (so much to choose from...)
                                Any ideas about current consumption? Is this a viable alternative to battery powered pir sensors?
                                cimba007C 1 Reply Last reply
                                • YveauxY Yveaux
                                  cimba007C
                                  cimba007C
                                  cimba007
                                  #28
                                  @Yveaux From my oppinion the radar modules are not suited for battery usage. Their drain something like 3-5mA and are not easy to put to sleep. Remember the warm-up period of the BISS. It seems to be like 10-15seconds.
                                  The plots are from another sketch, not the one I posted but using them is pretty straight forward.
                                  In my sketch have a look at these parts:
                                    Serial << " ";
                                  To use the arduino plotting all you ahve to do is send a string like this:
                                  0,10,534,123 .. whatever .. beware that no other serial output should happen if you want to use the arduino build-in plotting. Using the streaming library ( http://arduiniana.org/libraries/streaming/ ) it all boils down to a single line:
                                  Serial << mw_s.minimum() << "," << mw_s.maximum() << "," << mw_s.pop_stdev() << endl;
                                  In addition to the power consumption my approach requires sampling the analog input for a whole second .. or the more the better.
                                  This might be improved if you can prevent the FC1816 from retriggering itself. I had some serious problems as during the "inhibitor" period the analogOutput from the 2nd amplification stage was quite high often instantly retrigger the biss-output after the inhibition period ended.
                                  One solution might be this:
                                  Try this if you want to look down this approch:
                                  • Power the FC1816 VCC and UDP through an RC-Section (100Ohm Resistor and after that (on the side of the FC1816) an capacitory ~100-220µF)
                                  • Replace amplification resistor from 105 to eg. 154 (lowering the amplification)
                                  To find the best value I used an variable resistor parallel to the 105-Ohms SMD-Resistor
                                  But .. don't forget the benefits of *he microwave sensor. You can mount it straight to a door and it would detect persons in front of the door without them noticing. For this reason I try to build an "Alarm-node" that can be hidden inside the house. Later I might improve the FC1816 with some aluminium foil for shielding as suggested earlier.
                                  I would suggest using an PIR if you need a battery powered node. Have a look at ( http://kavacky.lv/bypassing-sen-08630-pir-motion-sensors-voltage-regulator-to-work-with-3-3-v ). Some PIRs have a Regulator which might not be suited if you are running on battery using 3,3Volt.
                                      Serial << " ";
                                    @cimba007 I know, I also used serial plotting for some projects. Very handy, very unstable (at that time). Probably improved since then, as I haven't used it recently.
                                    • cimba007C
                                      cimba007C
                                      cimba007
                                      #30
                                      All things from my previous post regarding the wiring are still needed:
                                      Here is a stripped down example on how to use the FC1816 Microwave Sensor. You need the following library:
                                        Serial.begin(57600);
                                        Serial.print("begin");
                                        // Microwave
                                        digitalWrite(6,LOW);      // DISABLE PLEASE!
                                        pinMode(A1,INPUT);        // PIR 2nd amplification stage
                                        pinMode(A0,OUTPUT);       // UPD microwave generator
                                        digitalWrite(A0,HIGH);
                                        // Report Microwave
                                        static Statistic mw_s;
                                        static uint16_t stdev_sum = 0;
                                        //mw_s.clear();
                                        //digitalWrite(8,HIGH);
                                        //delay(100);
                                        uint16_t reading;
                                        for(int i = 0; i < 200; i++)
                                          reading = analogRead(MICRO_SENSOR_ANALOG_PIN);
                                          mw_s.add(reading);
                                          //Serial.println(reading);
                                          //Serial.flush();
                                          //delay(50);
                                          //LowPower.powerDown(SLEEP_60MS, ADC_ON, BOD_OFF);
                                          //delay(1);
                                        Serial.print(mw_s.minimum());   Serial.print(",");
                                        Serial.print(mw_s.average());   Serial.print(",");
                                        Serial.print(mw_s.maximum());   Serial.print(",");
                                        Serial.print(mw_s.pop_stdev()); Serial.print(",");
                                        stdev_sum += mw_s.pop_stdev();
                                        Serial.print(stdev_sum); //Serial.print(",");
                                        Serial.println();
                                        stdev_sum *= 0.9;
                                        mw_s.clear();
                                      I just had the idea to sum up the std-dev and decrease it by 10% every round. Thus the code is less prone to peaks.
                                      0_1471429474464_upload-9c26c9f3-6ccd-4aaf-9bcc-797ad4c03be4
                                      stdev_sum is the lower dark blue line which can now be much easier compared to a threshold.
                                      Some measurement with my µCurrent-Gold:
                                      Unmodified code as above, power LED removed from ProMini @ 8Mhz internal osci with LDO desoldered
                                      4,8mA
                                      I tried to put the FC1816 into sleep by disable the power to the Microwave generator but this doesn't work.
                                      I modified the fuses for 8Mhz with 0ms wakeup delay for stabelizing the oscillator. No risk no phun ;-)
                                      The most practical solution I got to replace a PIR (still nothing as close as a PIR ;-ö)
                                      1530µA
                                      with this code:
                                      Note that the radar generator just can't be disable as it needs 10-15seconds to stabelize after power up
                                      #include <LowPower.h>
                                        // Microwave
                                        // Report Microwave
                                        //mw_s.clear();
                                        //delay(100);
                                        uint16_t reading;
                                        for(int i = 0; i < 10; i++)
                                          LowPower.powerDown(SLEEP_15Ms, ADC_ON, BOD_OFF);
                                          mw_s.add(reading);
                                          //Serial.flush();
                                          //delay(50);
                                          //delay(1);
                                        Serial.println();
                                        Serial.flush();
                                        stdev_sum *= 0.9;
                                        mw_s.clear();
                                          // Microwave
                                          // Report Microwave
                                          //mw_s.clear();
                                          //delay(100);
                                          uint16_t reading;
                                            mw_s.add(reading);
                                            //Serial.flush();
                                            //delay(50);
                                            //delay(1);
                                          Serial.println();
                                          stdev_sum *= 0.9;
                                          mw_s.clear();
                                        4,8mA
                                        1530µA
                                        with this code:
                                          // Microwave
                                          // Report Microwave
                                          //mw_s.clear();
                                          //delay(100);
                                          uint16_t reading;
                                            mw_s.add(reading);
                                            //Serial.flush();
                                            //delay(50);
                                            //delay(1);
                                          Serial.println();
                                          Serial.flush();
                                          stdev_sum *= 0.9;
                                          mw_s.clear();
                                        @cimba007 Thanks for the update :+1: Very interesting numbers!
                                        The 'sleep' current of 1.5mA rules out the microwave module as battery powered PIR replacement for me...
                                        As a mains powered sensor they're still very interesting, though!
                                        • cimba007C
                                          cimba007C
                                          cimba007
                                          #32
                                          After a few more days of testing I noticed these ugly "PEAKS" from my FC1816 readings. I added lots of capacitors and RC and LC sections but still .. nasty little peaks (left side in the beginning)
                                          0_1471879150498_upload-a9d03c1d-941a-4179-9306-7fb6eb708a7b
                                          In my previous post replace this line:
                                          with this:
                                            // Ignore the first 3 peaks within short succession
                                            // Real movement should mean there are more peaks/activity over a long time
                                            static uint8_t peakcount = 0;
                                            if(mw_s.pop_stdev() > 30 && peakcount < 3)
                                              peakcount++;
                                              stdev_sum *= 0.92; //
                                              if (stdev_sum >= 7)
                                                stdev_sum -= 7; // Default background noise
                                              if (stdev_sum > 512)
                                                stdev_sum = 512;
                                              if(peakcount > 0)
                                                peakcount--;
                                          With this code the first 3 peaks are essentially removed .. if there is really some movement it should last for a few seconds and would still be detected.
                                          I have invested like 10-20hours into testing and debugging the FC1816 and I can say .. this thing is .. peculiar ..
                                          I hate it cause of the spikes, the amplification which has to be manually altered with a pot .. but at the same time I love it ..
                                          I can detect my foot beckoning 2-3meters apart in my bed :D
                                          An example of the code snipped in action:
                                          0_1471879619120_upload-a3996be3-43b2-417d-ab69-e2545d288fd3
                                          Here you can see the big spikes in the beginning completely ignored (1)
                                          0_1471879713596_upload-3031e15c-37cb-4799-8b4a-ea6c3193f6bf
