  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 345.7k Views 37 Watching
  • dougD
    dougD
    doug
    Here is a photo of the module
    parachutesjP 2 Replies Last reply
    • dougD doug
      parachutesjP
      parachutesjP
      parachutesj
      wrote on last edited by parachutesj
      #259
      @doug I do have the same ones bought at alice from the shop link. I also have issues and basically not functioning. I will try your "fix" and see how it goes. Did you do some shielding?
      Cheers,
      SJ
      SparkmanS 1 Reply Last reply
      • dougD doug
        parachutesjP
        parachutesjP
        parachutesj
        @doug I did some quick tests and I can confim that the modules work better with less voltage. I made best experience with 2.5-2.6V. However they are still much much worse than all others I have and not worth the hassle IMHO.
        NeverDieN alexsh1A 2 Replies Last reply
        • parachutesjP parachutesj
          Which other ones do you have that perform better? It would be very useful to know.
          parachutesjP 1 Reply Last reply
            Cheers,
            SJ
            SparkmanS
            SparkmanS
            Sparkman
            Cheers,
            SJ
            FWIW, I use these exact ones and I get very good range with them, without additional shielding.
            Al
              parachutesjP
              parachutesjP
              parachutesj
              I have the shielded ones from IC-Station:
              http://www.icstation.com/22dbm-100mw-nrf24l01ppalna-wireless-transmission-module-p-4677.html
              Back to the ones discussed here:
              When doing the basic test from earlier in this thread I am getting massive packet loss even if the modules are very close together. Ok, maybe it needs to be shielded, power too high etc and tried having them separated with no luck, still massive packet losses. Of course this is no scientific research.
              Without tweaking, modifications, special antenna orientation the shielded IC-Station ones just worked for me. I am not saying the others don't work, they just perform not in my setup very well.
              Also as a comparison, I have some cheep modules from Aliexpress they outperform the ampliefied ones (at least within the house):
              http://www.aliexpress.com/item/10PCS-LOT-NRF24L01-wireless-data-transmission-module-2-4G-the-NRF24L01-upgrade-version/1593276910.html
              Those modules look very poor build to be honest but seem to be ok. They came in one single back, some pins bent but nothing which couldn't be fixed. Minor packet losses and antenna orientation seems to be key.
              In comparison, I also bought some more expensive ones, which claim to be original:
              http://www.aliexpress.com/item/Free-shipping-Original-Genuine-NRF24L01-Wireless-Module-2-4G-wireless-communication-module-2-54mm-Interface-2/1781618813.html
              Those came in a nice protected box and look very well made.
              They work, I even think better than the others - but I already blew two of them. Not sure what went wrong :-(
              Just received some SMD ones which haven't been tested yet.
              • loralgL
                loralgL
                loralg
                Does anyone know if the NRF24L01 and the +PA+LNA modules can be mixed and matched? Will the regular modules and the longer range versions talk to each other? I would like to use one of the long range modules on my gateway in the house and on some sensors around my yard that are a fair distance from my house. But then to save some money I was wondering if I could use the regular modules around the rest of my house. My concern is if I use regular modules on the sensors in my house if they will still be able to communicate with the longer range version module I have on my gateway?
                A 1 Reply Last reply
                • loralgL loralg
                  arraWX
                  wrote on last edited by arraWX
                  #265
                  @loralg I successfully use a nRF24L01+PA+LNA on the gateway and regular nRF24L01+ on the sensors.
                  There is a lot of information and hints available in the forum regarding the nRF24L01+PA+LNA . See e.g. here:
                  https://forum.mysensors.org/topic/3719/nrf24l01-vs-nrf24l01-pa-lna/2
                  In my case, however, the nRF24L01+PA+LNA works fine without any fix or special attention.
                  • afenoA
                    afenoA
                    afeno
                    What is the best way to measure the performance of one module at a given distance? I mean, how can I measure the number of packets lost?
                    Does anybody already created a "performace test sketch" to perofrm a better test?
                    • afenoA afeno
                      I posted a sketch earlier in this thread.
                        alexsh1A
                        alexsh1A
                        alexsh1
                        How did you decrease the voltage on nrf24l01+ PA? I have a voltage regulator providing 3.3V.
                        afenoA parachutesjP 2 Replies Last reply
                        • dougD
                          dougD
                          doug
                          I have also found that the higher the voltage the more capacitance you need. Guess that makes sense. Still can't get them to work reliably at 3.3v though.
                          I am realising the important thing is a good power supply you need to choose the right regulator to ensure the voltage doesn't tank too far when the current spikes (~180mA). caps help to some degree and I have found ceramic are better than the aluminium ones.
                          I am now using a single cell lipo and 2 regulators one at 3.3 and one at 2.7 for the radio. Also easier to get a low IQ with 2 regulators rather than one big one.
                          I am still learning and need to start doing some playing with a greater range of modules. Especially as your experience of these is that they are pretty poor.
                          • alexsh1A alexsh1
                            afenoA
                            afenoA
                            afeno
                            @alexsh1
                            I'm wondering the same as @alexsh1 . How can I get 2.5-2.6V? There is an easy/cheap way to do it?
                            AWIA 1 Reply Last reply
                            • afenoA afeno
                              @alexsh1
                              AWIA
                              AWIA
                              AWI
                              @afeno The cheap way is a diode in the vcc line. The voltage drop over a normal silicon diode (i.e. 1N4001) is around 0.7V. This has proven to be a working solution.
                              • alexsh1A alexsh1
                                parachutesjP
                                parachutesjP
                                parachutesj
                                @alexsh1
                                as it was just a test, I used a table power supply to have the exact voltages.
                                • afenoA
                                  afenoA
                                  afeno
                                  I'm creating a "ping" sketch to measure the % of packet lost using the tmrh20 library. I will post it once it is finished but it is just a modification of the "GettingStarted" sketch.
                                  It is very simple:
                                  • Node 1 send a value to node 2.
                                  • Node 2 receive the message and send it back to node 1.
                                  • Node 1 receive the message.
                                  I'm measuring the number of packets lost and the turnaround time.
                                  But doing some tests, I realised about something very strange that I don't understand...
                                  Based on the sketch described above, both the node 1 and 2 are sending and receiving the same amount of data.
                                  They both use the same commands to send and receive.
                                  I have two hardware sensors/devices (let's call it A and B ) based on arduinos nano.
                                  When I use A as Node 1 it gets 0.2% of packets lost. (B is used as Node 2)
                                  When I use B as Node 1 it gets 15% of packets lost!! (A is used as Node 2)
                                  Remember: Both nodes are sending and receiving the same amount of data.
                                  I understand that the current, radio, noise, etc. might have an impact on the performance and range but why it is working fine on one way? And not in the other way? This is making me crazy. Both sensors are sending and receiving the same data. If one of them is not sending (or receiving) well, the performance still should be the same independent on who is acting as node 1 or 2.
                                  What I am missing?
                                  Thank you!
                                  • afenoA afeno
                                    It is very simple:
                                    What I am missing?
                                    Thank you!
                                    @afeno
                                    Interesting asymmetry.
                                    This sounds basically the same as the sketch I posted earlier. Perhaps post a photo of the two nodes? Maybe something will jump out.
                                    If you really want to solve it, try also
                                    testing the packet loss on the individual links instead of only roundtrip. I suspect it will reveal something.
                                    • afenoA
                                      afenoA
                                      afeno
                                      Sorry for my ignorance... But how can I measure the packets lost on individual links?
                                      Do you mean to check the packets lost in a 1-way trip? Only from node1 to node2?
                                      • cimba007C
                                        cimba007C
                                        cimba007
                                        wrote on last edited by cimba007
                                        #276
                                        I thought it might be best to contribute to this thread rather then making a new one. I have some NRF24L01+ for like 2-3 years. Some of them are the normal ones and a few LNA+PA.
                                        The following explanation requires some "advanced" knowledge about the RF24 library and the test-sketch I added. Please forgive me as I was not able to write a more simple sketch and explanation.
                                        From day one I had problems using the modules at 250kbps with autoack. The Reception (RPD) was very poor and I had very high packet loss.
                                        For a few days now I have been tinkering with mysensors and just recently noticed .. wait what???
                                        250kbps + autoack is default.
                                        As mysensors is not ideal for testing modules I used another well known library:
                                        http://tmrh20.github.io/RF24/
                                        To get access to a very important register to debug autoack issues I modified "RF24.h" to get the low level functions public:
                                        **public:**
                                           * @name Low-level internal interface.
                                           *  Protected methods that address the chip directly.  Regular users cannot
                                           *  ever call these.  They are documented for completeness and for developers who
                                           *  may want to extend this class.
                                        After that I hooked up an single WS2812B-LED to pin 4 and tinkerd together a little test-sketch:
                                        0_1469476423782_getting_started_250kbps_minimum2.zip
                                        Note: You have to write the values 0 and 1 to EEPROM.Address 0 ONCE. 0 is the static pong back node and 1 is the mobile node with the WS2812B LED. This allows moving freely and check reception in your home.
                                        After writing the values to the eeprom you can comment out the code and don't have to worry when uploading the sketch to the "pongback"-node or the mobile "ping" node.
                                        //EEPROM.write(0,0); // 0 = PongBack
                                        If you don't want to use the WS2812B you have to remove some code but that should not be too hard.
                                        The important parts come now:
                                        settings[autoack] = 0;
                                        settings[retry] = 15;
                                        settings[delay_rf] = 15;
                                        Disabling autoack I could get an improved reading of RDP and very little PacketLoss. I now can cover distanced much larger like through 2-3 walls more then before.
                                        My modules are all powered from 3,3V dedicated LDO or 3V (2x AA) Battery and run @ 8MHz
                                        Long story short:
                                        If you have reception problems even after checking your Supply and even after trying the "ugly fix" and still got nowhere .. i suggest your try disabling auto ack. Although this it not intiutive on mysensors and would leave you vulnerable to packetloss I suggest you to test it out with this library (http://tmrh20.github.io/RF24/) and my example sketch.
                                        Sorry for not presenting a whole solution but I thought it might be worth to point people having reception problems into one possible "direction".
                                        PS: Autoack works fine on my modules if I switch to 1MBPS so this might be viable too.
                                          At current date, is there anybody that can suggest a place to buy good NRF24 modules? I live in Italy so probably US shops would be a little expensive on shipping cost.
