  3. ๐Ÿ’ฌ Easy/Newbie PCB for MySensors
716 Posts 111 Posters 703.1k Views 93 Watching
  • Nca78N
    @sundberg84 sorry to bother you but maybe you have an idea.
    I soldered components as in the picture below (looking so much cleaner than with all the cables...), I am using a 3.3V pro mini.
    Before soldering I tested the pro mini and the nrf24 together, connected with cables, and simulated the reed switch with some wires: everything was fine and I was receiving the open/close messages in domoticz.
    I soldered the components as below but I only got some "radio init failed" when connected to my PC, power coming to the GND/VCC on top of the arduino.
    As I put the jumper on "reg" to bypass the regulator, my understanding is that in this case the raw/power/vcc are all connected together, am I wrong ?
    Another subject, I suffered to cut the right part of the PCB with a cutter, would it be possible to add some slots along the black line to reduce a bit the length we have to cut ?
    S sundberg84S 2 Replies Last reply
    • Nca78N Nca78
      Samuel235
      @Nca78, do you have power on the radio, do you have power present everywhere it should be? Arduino included. If this is all present i would then go into diode mode with a multimeter to make sure all of your pins on the radio are connected to those of the ATMega328 on the arduino.
      This would be just a basic starting point at troubleshooting this.
      MySensors 2.1.1
      • Nca78N Nca78
        sundberg84S
        sundberg84S
        #146
        @Nca78 - Hi, nice to see your white boards ! :)
        I see your image, and you have choosen a REG jumper (regulated power supply). How do you power it? Through RAW?
        You have missed the voltage regulator with caps for the radio, so at this point it does not get any power at all?
        If you are using a 3.3v arudino with RAW you can bypass it with a wire.
        If you are using a 5v with RAW or Regulated power (PWR) you need a 5 to 3.3v voltage regulator.
        • B BastienVH
          @sundberg84 said:
          If you use the FTDI connector, make sure its the 3.3v and connect it to Gnd/Pwr on the PCB and not Arduino FDTI connector.
          You could just exclude those pins and connect a battery directly and use that as power and the FDTI as programmer/serial debug only
          Bat or Reg is nessecary!
          See this picture for battery use: https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors
          https://www.openhardware.io/uploads/568ed84b60aa3f8965fbf095/image/3.jpg
          All components in the image is needed (except battery measurment).
          If you dont want to use booster you need to bypass that one with a wire/jumper (or set the jumper on REG instead of BAT but that kills the logic).
          The battery doesnt "need" the 0,1uF but see here:https://www.mysensors.org/build/battery
          "The tap point could be bypassed with a 0.1 uF capacitor to keep the noise level low, at this otherwise high impedance point. "
          C
          C
          chuckconnors
          @sundberg84
          Hi. I've been using this board with 5V power from cell chargers and it works great. I'm trying to make my first battery sensor and am a bit confused (again) as to what is necessary. I'm powering using 2 AA batteries. I've cut the right side off the board so I'm obviously not using the measuring portion, but the above bit about the booster leaves me confused. Can someone answer:
          • I connect via the PWR and GND pads right?
          • Do I jumper BAT or REG?
          • Do I need to do anything else to get this to work?
          I tried to program using battery in but was using the ground from the ftdi connector. I could not get this to work. I'm thinking that this was a major problem and that I should have used the battery ground. That's the right approach right?
          • sundberg84S
            sundberg84S
            @chuckconnors - assuming you are using a Arduino Pro Mini 3.3v it will die when the voltage drops below 3v (about) so it leaves alot of power left in your batteries and also it will die rather quickly.
            Thats why I have designed the PCB with a booster for battery operations, and then its not possible to cut the right side of the PCB since the booster is located there. Check the image out: https://www.openhardware.io//uploads/568ed84b60aa3f8965fbf095/image/Rev8 Bat.jpg and you see the booster on the top right corner.
            • Nca78N
              Thank you for the tip @sundberg84, it just needed the bypassing of the regulator, and then I can connect my cell battery to the GND and PWR and it runs fine.
              @Samuel235 yes you are right I did it and it didn't have Vcc power that's why I asked that question to sundberg84, next time I'll precise it as it could have ended in wasted time...
              @chuckconnors this is how you have to connect the jumpers to use directly on battery power (on GND and PWR pins). But as sundberg84 says you will not have a long battery life with AA batteries and without a booster. Even if you update the fuses and bootloader to run at 1MHz and have the BOD at 1.8V there will still be power left (I guess not far from 25% of capacity with 2 batteries) that is wasted. If you keep the defaults settings of the arduino at 8MHz it will run down to 2.4V and around half of the energy in your batteries will be wasted.
              Nca78N 1 Reply Last reply
              • Lior RubinL
                Lior RubinL
                Lior Rubin
                @sundberg84 is the board ready for Ver 2.0.0 ?
                the final version announced yesterday at HERE, anyhow can you share an example of Node sketch ?
                • sundberg84S
                  sundberg84S
                  @Lior-Rubin - the PCB or the hardware has nothing to do with 2.0
                  It will work fine - 2.0 is only software (what you program it with).
                  I have been running 2.0 beta (dev) for a long time now without any problems.
                  Lior RubinL 1 Reply Last reply
                  • sundberg84S sundberg84
                    Lior RubinL
                    Lior RubinL
                    Lior Rubin
                    @sundberg84 I'm aware of it. I just ask to be sure.
                    Can you upload here an example sketch (v2.0) with battery reporting ?
                    Nca78N sundberg84S 2 Replies Last reply
                    • Lior RubinL Lior Rubin
                      You can just check the examples included in the library, I've been using the beta version of MySensors 2 for a long time and started from supplied examples, never had a problem.
                      This is some code I use to report battery level, it's harder to make it more simple, juste keep your existing code to read the battery level and replace the line sending the value with the sendBatteryLevel() :
                          int currentBatteryPercent = SystemStatus().getVCCPercent(VccMin, VccMax);
                          if (currentBatteryPercent != LastBatteryPercent) {
                              LastBatteryPercent = currentBatteryPercent;
                              sendBatteryLevel(currentBatteryPercent);
                        sundberg84S
                        sundberg84S
                        #154
                        @Lior-Rubin - If you use a voltage divider and 2xAA use this:
                        Defines:
                           delay(500);
                           // Battery monitoring reading
                           delay(500);
                           // Calculate the battery in %
                           if (batLoop > 2) {
                           if (batteryPcnt > 100) {
                             batteryPcnt=100;
                               batLoop = 0;
                             batLoop++;
                        Add batM(); in the loop where you want to measure.
                        This calculates an avarage and sends it every 3rd time. So i sleep my sensors for 20 min, and battery is reported every 1hour.
                        If you want to measure incoming VCC agains ref use @Nca78 but this does not work if you are using a booster (since it will always be 3.3v on incoming).
                        • Nca78N Nca78
                          wrote on last edited by Nca78
                          #155
                          Hello @sundberg84 I have a request for update for your board :)
                          Can you remove the trace from the INT pin of the NRF24 to the D2 pin of the pro mini ? As interrupt is not used in MySensors for the NRF24, it's not useful while it creates some side effects.
                          I explain you my problem:
                          I made a door sensor using a reed switch with both normally open and normally closed pins, and connected them to D2 and D3 (+ ground on the other side connected, as on my last picture above).
                          In the code I switch the status of the pins in the loop between HIGH/LOW values and set the interrupt on the unconnected pin so the pin is connected to ground only during a very short time (just the time to get out of the sleep mode). I'm supposed to have a very low consumption during deep sleep mode (few microamps). But I have that only when D2 is not connected to ground. If it's connected then it seems I have some current leaking from the INT pin of the NRF24 to the ground through the reed switch, as the board is using 6.5mA.
                          Without any other change, I made a barbaric cut of the trace near the NRF24 and now the current consumption is around 1.5 ยตA for both states of the reed switch. For the next boards I will just remove the INT pin of the NRF24, but it would be more simple to have nothing to do :P
                          Just in case this is my sketch (not final, please be tolerant) but I don't think it's really relevant
                          // Enable debug prints
                          #include <MyConfig.h>
                          #include <SystemStatus.h>
                          #define SKETCH_NAME "NCA Door Sensor"
                          #define SKETCH_MAJOR_VER "0"
                          #define SKETCH_MINOR_VER "7"
                          #define PRIMARY_CHILD_ID 30
                          #define SECONDARY_CHILD_ID 4
                          #define MY_NODE_ID 2
                          #define MY_PARENT_NODE_ID 0
                          //MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
                          // Parameters for VCC measurement
                          const int VccMin        = 2400;  // Minimum expected Vcc level, in Volts. If you have updated bootloader&BOD you can change to 1.8V here
                          const int VccMax        = 3000;  // Maximum expected Vcc level, in Volts.
                          SystemStatus vcc();
                          int LastBatteryPercent = 200; // so we are sure to send the battery level at first check
                          bool isEven = false; // to check+send battery level only for each open+close cycles
                          // This is the activated pin, on which the interrupt is set
                          byte connectedPin = PRIMARY_BUTTON_PIN;
                          byte connectedPinAtLastSending = 0; // Initialized at 0 so we will always send the first time
                            // First thing to do: change clock prescaling to 8 to change from 8MHz to 1MHz
                            //  of course not necessary if you already have updated fuses and bootloader...
                            #ifndef MY_DEBUG           // only if we are not in debug mode, so we can keep the fast baudrate in debug
                              clock_prescale_set (clock_div_8);
                            sleep(5);
                            deActivatePin(PRIMARY_BUTTON_PIN);
                            deActivatePin(SECONDARY_BUTTON_PIN);
                            // Check if the previously connected pin is now connected. We do that because it's the most likely to be unconnected now
                            //  so it's the best way not to lose any current
                            byte newConnectedPin = GetNonConnectedPin();
                            if (checkPinIsConnected(connectedPin)) {
                              // If pin is still connected we set back the value to connected pin
                              newConnectedPin = connectedPin;
                              #ifdef MY_DEBUG
                                Serial.println("Connected pin is connected !");
                            connectedPin = newConnectedPin;
                            // If connected pin is different that the one during the last sending of status, we send again
                            #ifdef MY_DEBUG
                              Serial.print("Connected pin = ");
                              Serial.println(connectedPin);
                              Serial.print("New Connected pin = ");
                              Serial.println(newConnectedPin);
                            if (connectedPin != connectedPinAtLastSending) {
                               send(msg.set(connectedPin==PRIMARY_BUTTON_PIN ? 1 : 0));
                               connectedPinAtLastSending = connectedPin;
                               isEven = !isEven;
                            if (isEven) {  // send only every two changes for a full open + close cycle
                            #ifdef MY_DEBUG
                              Serial.print("Preparing to sleep, pin ");
                              Serial.println(GetNonConnectedPin());
                              wait(50);
                            // Activate the non connected pin before setting up interrupt
                            activatePin(GetNonConnectedPin());
                            // Sleep until something happens with the door sensor
                            sleep(GetNonConnectedPin()-2, CHANGE);
                          void activatePin(byte pin) {
                            // Set pin as input
                            pinMode(pin, INPUT);
                            // Activate internal pull up
                            digitalWrite(pin, HIGH);
                          void deActivatePin(byte pin) {
                            // Set back pin as output, low
                            pinMode(pin, OUTPUT);
                            digitalWrite(pin, LOW);
                          // Will check if pin is grounded (returns true) or not
                          boolean checkPinIsConnected(byte pin) {
                            activatePin(pin);
                            // Read value
                            byte valPin = digitalRead(pin);
                            deActivatePin(pin);
                            #ifdef MY_DEBUG
                              Serial.print("checkPinIsConnected pin = ");
                              Serial.print(pin);
                              Serial.print(", value = ");
                              Serial.println(valPin);
                            return valPin != HIGH;
                          // Returns the pin that is not connected
                          byte GetNonConnectedPin() {
                            return (connectedPin == PRIMARY_BUTTON_PIN) ? SECONDARY_BUTTON_PIN : PRIMARY_BUTTON_PIN;
                          • Nca78N Nca78
                            SystemStatus vcc();
                              sleep(5);
                                #ifdef MY_DEBUG
                              #ifdef MY_DEBUG
                                 isEven = !isEven;
                              #ifdef MY_DEBUG
                                wait(50);
                              // Set pin as input
                              activatePin(pin);
                              // Read value
                              deActivatePin(pin);
                              #ifdef MY_DEBUG
                                Serial.print(pin);
                            sundberg84S
                            sundberg84S
                            @Nca78 Thanks. Someone else posted this as well. I will update this Inow rev 9 with some jumper or something.
                            • C
                              C
                              chuckconnors
                              Another real quick question. I have a simple sensor using a DHT11. I have this connected to D3 for signal and power and ground from the right holes. I'm getting an error saying it can't read temp/hum from the DHT. That set up should be right though? I also have a 4.7k ohm resistor in the board for D3 (that's the pin, right?).
                              • sundberg84S
                                sundberg84S
                                @chuckconnors - that right, see my post at 110 (https://forum.mysensors.org/topic/2740/easy-newbie-pcb-for-mysensors/110)
                                I have the dht22 in the prototyping area but have made alot of dht22 attached directly to power/gnd and d3 pin on the mysx connector. Works great.
                                C 1 Reply Last reply
                                  C
                                  C
                                  chuckconnors
                                  @sundberg84 Thanks. Another dumb question: What is the difference between the RAW ad the PWR pads and when should I use one rather than the other?
                                  • sundberg84S
                                    sundberg84S
                                    If you have unregulated power (RAW) within pro minis on board voltage regulater you can instead of using 5v regulated power use this and the arduino will convert it to 5v. I think the specs are 6-12v (with a varning on that clones can not handle 12v!). So for example if you have a 9v battery you can power everything with connecting this to RAW and GND instead of PWR and GND and the voltage regulater on the pro mini will output 5v for the rest of the PCB. @chuckconnors
                                    • rchampR
                                      rchampR
                                      rchamp
                                      what is the size of the mounting holes? i don't have a caliper yet to measure this small of a size (ordering on amazon)
                                      • rchampR
                                        rchampR
                                        rchamp
                                        Just wanted to say great work on this board. I have the first one wired up w/ batteries, 3.3v APM w/led and regulations removed, voltage regulator, dht11 and motion w 3v mod and works wonderfully. Once I get my caliper in, I'll get the right mounting screws, finish my enclosure and post the pics.
                                        • rchampR rchamp
                                          sundberg84S
                                          sundberg84S
                                          I dont have eagles at this computer, so I have to answer you tonight (8 hours) or so...
                                          Thanks for the nice feedback!
                                          With your input, this post could be even better ๐Ÿ’—
