716 Posts 111 Posters 703.1k Views 93 Watching
  • Lior RubinL Lior Rubin
    @sundberg84 I'm aware of it. I just ask to be sure.
    Can you upload here an example sketch (v2.0) with battery reporting ?
    sundberg84S
    sundberg84S
    #154
    @Lior-Rubin - If you use a voltage divider and 2xAA use this:
    Defines:
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       if (batLoop > 2) {
       if (batteryPcnt > 100) {
         batteryPcnt=100;
           batLoop = 0;
         batLoop++;
    Add batM(); in the loop where you want to measure.
    This calculates an avarage and sends it every 3rd time. So i sleep my sensors for 20 min, and battery is reported every 1hour.
    If you want to measure incoming VCC agains ref use @Nca78 but this does not work if you are using a booster (since it will always be 3.3v on incoming).
    • Nca78N Nca78
      Thank you for the tip @sundberg84, it just needed the bypassing of the regulator, and then I can connect my cell battery to the GND and PWR and it runs fine.
      @Samuel235 yes you are right I did it and it didn't have Vcc power that's why I asked that question to sundberg84, next time I'll precise it as it could have ended in wasted time...
      @chuckconnors this is how you have to connect the jumpers to use directly on battery power (on GND and PWR pins). But as sundberg84 says you will not have a long battery life with AA batteries and without a booster. Even if you update the fuses and bootloader to run at 1MHz and have the BOD at 1.8V there will still be power left (I guess not far from 25% of capacity with 2 batteries) that is wasted. If you keep the defaults settings of the arduino at 8MHz it will run down to 2.4V and around half of the energy in your batteries will be wasted.
      wrote on last edited by Nca78
      #155
      Hello @sundberg84 I have a request for update for your board :)
      Can you remove the trace from the INT pin of the NRF24 to the D2 pin of the pro mini ? As interrupt is not used in MySensors for the NRF24, it's not useful while it creates some side effects.
      I explain you my problem:
      I made a door sensor using a reed switch with both normally open and normally closed pins, and connected them to D2 and D3 (+ ground on the other side connected, as on my last picture above).
      In the code I switch the status of the pins in the loop between HIGH/LOW values and set the interrupt on the unconnected pin so the pin is connected to ground only during a very short time (just the time to get out of the sleep mode). I'm supposed to have a very low consumption during deep sleep mode (few microamps). But I have that only when D2 is not connected to ground. If it's connected then it seems I have some current leaking from the INT pin of the NRF24 to the ground through the reed switch, as the board is using 6.5mA.
      Without any other change, I made a barbaric cut of the trace near the NRF24 and now the current consumption is around 1.5 µA for both states of the reed switch. For the next boards I will just remove the INT pin of the NRF24, but it would be more simple to have nothing to do :P
      Just in case this is my sketch (not final, please be tolerant) but I don't think it's really relevant
      // Enable debug prints
      #include <MyConfig.h>
      #include <SystemStatus.h>
      #define SKETCH_NAME "NCA Door Sensor"
      #define SKETCH_MAJOR_VER "0"
      #define SKETCH_MINOR_VER "7"
      #define PRIMARY_CHILD_ID 30
      #define SECONDARY_CHILD_ID 4
      #define MY_NODE_ID 2
      #define MY_PARENT_NODE_ID 0
      //MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
      // Parameters for VCC measurement
      const int VccMin        = 2400;  // Minimum expected Vcc level, in Volts. If you have updated bootloader&BOD you can change to 1.8V here
      const int VccMax        = 3000;  // Maximum expected Vcc level, in Volts.
      SystemStatus vcc();
      int LastBatteryPercent = 200; // so we are sure to send the battery level at first check
      bool isEven = false; // to check+send battery level only for each open+close cycles
      // This is the activated pin, on which the interrupt is set
      byte connectedPin = PRIMARY_BUTTON_PIN;
      byte connectedPinAtLastSending = 0; // Initialized at 0 so we will always send the first time
        // First thing to do: change clock prescaling to 8 to change from 8MHz to 1MHz
        //  of course not necessary if you already have updated fuses and bootloader...
        #ifndef MY_DEBUG           // only if we are not in debug mode, so we can keep the fast baudrate in debug
          clock_prescale_set (clock_div_8);
        sleep(5);
        deActivatePin(PRIMARY_BUTTON_PIN);
        deActivatePin(SECONDARY_BUTTON_PIN);
        // Check if the previously connected pin is now connected. We do that because it's the most likely to be unconnected now
        //  so it's the best way not to lose any current
        byte newConnectedPin = GetNonConnectedPin();
        if (checkPinIsConnected(connectedPin)) {
          // If pin is still connected we set back the value to connected pin
          newConnectedPin = connectedPin;
          #ifdef MY_DEBUG
            Serial.println("Connected pin is connected !");
        connectedPin = newConnectedPin;
        // If connected pin is different that the one during the last sending of status, we send again
        #ifdef MY_DEBUG
          Serial.print("Connected pin = ");
          Serial.println(connectedPin);
          Serial.print("New Connected pin = ");
          Serial.println(newConnectedPin);
        if (connectedPin != connectedPinAtLastSending) {
           send(msg.set(connectedPin==PRIMARY_BUTTON_PIN ? 1 : 0));
           connectedPinAtLastSending = connectedPin;
           isEven = !isEven;
        if (isEven) {  // send only every two changes for a full open + close cycle
          int currentBatteryPercent = SystemStatus().getVCCPercent(VccMin, VccMax);
          if (currentBatteryPercent != LastBatteryPercent) {
              LastBatteryPercent = currentBatteryPercent;
              sendBatteryLevel(currentBatteryPercent);
        #ifdef MY_DEBUG
          Serial.print("Preparing to sleep, pin ");
          Serial.println(GetNonConnectedPin());
          wait(50);
        // Activate the non connected pin before setting up interrupt
        activatePin(GetNonConnectedPin());
        // Sleep until something happens with the door sensor
        sleep(GetNonConnectedPin()-2, CHANGE);
      void activatePin(byte pin) {
        // Set pin as input
        pinMode(pin, INPUT);
        // Activate internal pull up
        digitalWrite(pin, HIGH);
      void deActivatePin(byte pin) {
        // Set back pin as output, low
        pinMode(pin, OUTPUT);
        digitalWrite(pin, LOW);
      // Will check if pin is grounded (returns true) or not
      boolean checkPinIsConnected(byte pin) {
        activatePin(pin);
        // Read value
        byte valPin = digitalRead(pin);
        deActivatePin(pin);
        #ifdef MY_DEBUG
          Serial.print("checkPinIsConnected pin = ");
          Serial.print(pin);
          Serial.print(", value = ");
          Serial.println(valPin);
        return valPin != HIGH;
      // Returns the pin that is not connected
      byte GetNonConnectedPin() {
        return (connectedPin == PRIMARY_BUTTON_PIN) ? SECONDARY_BUTTON_PIN : PRIMARY_BUTTON_PIN;
      • Nca78N Nca78
        SystemStatus vcc();
          sleep(5);
            #ifdef MY_DEBUG
          #ifdef MY_DEBUG
             isEven = !isEven;
          #ifdef MY_DEBUG
            wait(50);
          // Set pin as input
          activatePin(pin);
          // Read value
          deActivatePin(pin);
          #ifdef MY_DEBUG
            Serial.print(pin);
        sundberg84S
        sundberg84S
        @Nca78 Thanks. Someone else posted this as well. I will update this Inow rev 9 with some jumper or something.
        • C
          C
          chuckconnors
          Another real quick question. I have a simple sensor using a DHT11. I have this connected to D3 for signal and power and ground from the right holes. I'm getting an error saying it can't read temp/hum from the DHT. That set up should be right though? I also have a 4.7k ohm resistor in the board for D3 (that's the pin, right?).
          • sundberg84S
            sundberg84S
            @chuckconnors - that right, see my post at 110 (https://forum.mysensors.org/topic/2740/easy-newbie-pcb-for-mysensors/110)
            I have the dht22 in the prototyping area but have made alot of dht22 attached directly to power/gnd and d3 pin on the mysx connector. Works great.
            C 1 Reply Last reply
            • sundberg84S sundberg84
              C
              C
              chuckconnors
              @sundberg84 Thanks. Another dumb question: What is the difference between the RAW ad the PWR pads and when should I use one rather than the other?
              • sundberg84S
                sundberg84S
                If you have unregulated power (RAW) within pro minis on board voltage regulater you can instead of using 5v regulated power use this and the arduino will convert it to 5v. I think the specs are 6-12v (with a varning on that clones can not handle 12v!). So for example if you have a 9v battery you can power everything with connecting this to RAW and GND instead of PWR and GND and the voltage regulater on the pro mini will output 5v for the rest of the PCB. @chuckconnors
                • rchampR
                  rchampR
                  rchamp
                  what is the size of the mounting holes? i don't have a caliper yet to measure this small of a size (ordering on amazon)
                  sundberg84S 2 Replies Last reply
                  • rchampR
                    rchampR
                    rchamp
                    Just wanted to say great work on this board. I have the first one wired up w/ batteries, 3.3v APM w/led and regulations removed, voltage regulator, dht11 and motion w 3v mod and works wonderfully. Once I get my caliper in, I'll get the right mounting screws, finish my enclosure and post the pics.
                    • rchampR rchamp
                      sundberg84S
                      sundberg84S
                      I dont have eagles at this computer, so I have to answer you tonight (8 hours) or so...
                      Thanks for the nice feedback!
                      • rchampR rchamp
                        sundberg84S
                        sundberg84S
                        @rchamp - sorry for later reply, the mounting holes are 2mm or 78.7mil.
                        rchampR 1 Reply Last reply
                          rchampR
                          rchampR
                          rchamp
                          @sundberg84
                          awesome thanks!
                          • Nca78N
                            Hello, I ordered a second batch from PCBWay, it's ok except some components have a frame on the silkscreen, not very beautiful.
                            Just wanted to say that it was a pain to cut the 1.6mm PCB so this time I ordered in 0.8mm and it is sooooo easy to cut with regular cissors: no efforts and very clean cut ! So if you plan to cut the right part, order at 1mm or below, you will enjoy the cutting phase :D
                            • Nca78N Nca78
                              sundberg84S
                              sundberg84S
                              Sorry, I dont understand what you mean - can you give me a closeup photo? It should be functional AND beautiful :) If the silkscreen overlaps the copper parts this could interfer as well...
                              I also learned it the hard way - and since there isnt any high power ciciut it should be ok to order very thin pcbs.
                              I used a metallic saw for one :persevere: and for some i cut a trace with a knife and bended it until it cracked.
                              Nca78N 1 Reply Last reply
                              • Martin TellblomM
                                Martin TellblomM
                                Martin Tellblom
                                Just ordered 10 white bords, they look so great :)
                                MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
                                  #169
                                  I fact it's the case only for the "Rev B" and licence text at the top left. No big deal but it was looking better without the frame from DirtyPCB
                                  I used the knife too (don't have a metal saw) with the 1.6mm PCBs and it was long and messy. Now it's just like a strong cardboard.
                                  • Q
                                    Q
                                    Qu3Uk
                                    I ordered some via DirtyPCB - Ordering via OpenHardware it seems to suggest you are buying Rev4. Says Rev4 under the order button at least.
                                    • Q Qu3Uk
                                      sundberg84S
                                      sundberg84S
                                      #171
                                      @Qu3Uk - Yes, and its missleading. Its rev 9 you are ordering but the fourth update on openhardware.io Its no problem ordering from there, I always update those gerber files first.
                                      • dbemowskD
                                        dbemowskD
                                        #172
                                        I just wanted to make some suggestions for this board for the possible next revision. I recently ordered a 10 pack (which when I got it ended up being an 11 pack... BONUS BOARD).
                                        When I put together my first board there were some things that I noticed. First, the boards that I got are labeled as rev 8 boards, but there is one small difference from the one shown on the openhardware.io website.
                                        board differences
                                        The placement of the 4.7uf capacitor and the raw power connection holes next to the nRF24L01+ socket are reversed. The spot that you have for the 4.7uf capacitor for the nRF24L01+ radio module is just a bit too close to the nRF24 connector. It appears that the capacitor that you chose in your design software was for a ceramic type cap that has a wider hole spacing and is narrower. Choose one for an electrolytic cap and move it away from the nRF24 connector a bit more. This should give the closer hole spacing designed for a small electrolytic cap and leave enough room for it.
                                        Similarly the spot you have for the 10uf cap above the regulator appears to also be a design for a ceramic cap with the wider hole spacing. Selecting electrolytics for these should not only give you the correct hole spacing for the electrolytic, but it should also better mark where the negative lead of the cap needs to go on your silkscreen layer.
                                        The other thing that I wish this had was pads for a SMT AMS1117 regulator. This could be placed in the space under the nRF24 radio or just under the pro mini. You could do this in conjunction with the TO92 style that you have currently placed. It would give the board a bit more flexibility for users. In my parts box, I only had the AMS1117 regulators and not the TO92 style. I have since ordered some of the TO92 style, but having the flexibility for either would have been nice.
                                        Last but not least, it would be nice to have slightly larger corner mounting holes. I don't have many small screws that fit those holes, and I have none that would work with the standoffs that I use.
                                        Other than those few things, it seems like a rock solid board. Thanks for the hard work.
                                        • dbemowskD dbemowsk
                                          board differences
                                          sundberg84S
                                          sundberg84S
                                          #173
                                          @dbemowsk - Hi!
                                          Thank you for great input!
                                          Why the difference, is because I released rev 8 but made some last minute changes and forgot to update to rev 8.1.
                                          You pretty much found the difference. It was a couple of days so I didnt think anybody would notice.
                                          Did you order from DirtyPCB? I see not it got the old rev 8 version. I will update openhardware.io!
                                          Your suggestions about the 4,7uF cap is exactly what I did in the correct Rev 8 version.
                                          I use electrolytic caps on both 4,7 0,1 and 10 uF without any problems. The G marks ground.
                                          I also like the AMS1117 but since its another design than LE33 and MySensors site wuggest LE33 i went with this.
                                          Its a balance between flexibility and easy to use. To many components (like dual voltage regulators) will confuse some new users.
                                          I will try to fit in some bigger holes in rev 9 (currently working on it) and see what I can do about the AMS1117 .
                                          Thank you for great input - ill keep it in mind!
                                          Br
                                          Andreas
