  2. Announcements
  3. MySensors 2.0.0 Released
75 Posts 42 Posters 55.6k Views 37 Watching
  • nielsokkerN nielsokker
    I've just tried it and it look really great!
    When is the documentation comming? I'm having some trouble understanding the errors i get in the log. It says: !TSM:CHKID:FAIL (ID=255)
    !TSM:FAILURE
    TSM:PDT
    Anyone has an idea?
    Thanks in advance!
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    @nielsokker documentation about the log messages is WIP and will follow soon.
    In brief:
    TSM refers to the transport state machine, (!) to an error.
    Your error !TSM:CHKID:FAIL indicates that the node didn't receive a (valid) ID, hence !TSM:FAILURE (transport not operational) followed by TSM:PDT which means that the radio was powered-down for a while followed by a re-initialisation.
    nielsokkerN 1 Reply Last reply
      Matt
      BOOM! Well done guys =)
      • sinczeS
        sinczeS
        sincze
        MySensors Evangelist
        excellent. let me try to find the updates and see what advantages are in it for me.
        great job guys.
        • gyroG
          gyroG
          gyro
          wrote on last edited by gyro
          I have been using rf24 radios before mysensors, and back then everything didn't worked so good as with mysensors.
          Awesome work, I think it's time for a donation at least for some 🍻 for holidays for developers. They deserve it.
          • tekkaT tekka
            In brief:
            nielsokkerN
            nielsokkerN
            nielsokker
            @tekka
            Thank you for your answer! Does this mean that the hardware is failing? I used the repeater example.
            tekkaT 1 Reply Last reply
              @tekka
              tekkaT
              tekkaT
              tekka
              @nielsokker no, it means that the node was requesting and ID from the controller but didn't get one.
              • L
                L
                Lars65
                What am I doing wrong when I get this when I try to compile?
                I have a new installation of Arduino IDE 1.6.5 (have tried 1.6.7 also, and still the same)and I have put the new files in my arduino sketchbook also deleted all old ones)
                Arduino:1.6.5 (Windows 8.1), Kort:"Arduino Nano, ATmega328"
                DustSensor.ino:49:25: fatal error: MySensors.h: No such file or directory
                compilation terminated.
                Fel vid kompilering.
                • L Lars65
                  nielsokkerN
                  nielsokkerN
                  nielsokker
                  wrote on last edited by nielsokker
                  #24
                  @Lars65
                  I had the same error. You have to(instead of what the 1.5 manual says) keep all the files in the mysensors_master folder. This folder needs to be in the libraries folder that already exists.
                  • L
                    L
                    Lars65
                    Thank you!!!!!
                    That helped a lot.
                    • CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      Guess it's a good thing I am just getting started. I am guessing 2.0 should be the default go to now?
                      Home Automation Tinkerer
                      www.CrankyCoder.net
                      Gateway: MQTTClientGateway
                      MySensors: 2.3
                      D 1 Reply Last reply
                      • CrankyCoderC CrankyCoder
                        drock1985
                        @Jason-Brunk
                        IMHO I would say yes. Keep in mind there are some differences in how the API works. I suggest going through the example scripts from 2.0, and compare that to the ones in 1.5 so you will get an idea of what I mean.
                        My Projects
                        2 Door Chime Sensor
                        Washing Machine Monitor
                        • AnticimexA Anticimex
                          :mega: We are happy to announce a major release of the MySensors library to 2.0.0!
                          For details, see here.
                          Doxygen links on the master github frontpage are not working. These are the correct links:
                          master development
                          tomkxy
                          master development
                          Thanks a lot for that great piece of work!!!
                          • F
                            F
                            Fabien
                            Sensebender sketch is not any more in the example folder. Is it "normal" ?
                              Yes, this in the new normal... we moved all the examples using external library dependencies into https://github.com/mysensors/MySensorsArduinoExamples until we can figure out which ones work with auto-dependency-download using the IDE Library Manager.
                              We would really appreciate some help doing the verification.
                              Mark SwiftM 1 Reply Last reply
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                #31
                                Actually sensebender sketch is moved to the same repository as the hardware files for the SensebenderMicro.
                                Problem is that we do not want to have external dependencies on the examples in the MySensors library, as they are not distributed together anymore. That's why examples with external dependencies have been moved to a new repository. Except the sensebender sketch, which we/I decided to relocate to the SensebenderMicro repository, as it's a bit special, and belongs to that hardware..
                                • Tore André RosanderT
                                  Tore André Rosander
                                  I have been using the beta for some time now, to use the stable version do i just download the zip from github and replace the mysensors folder in arduino -> libraries ?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @Tore-André-Rosander
                                    That should do it, until we get online in the arduino library manager..
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      #34
                                      And now we are online in the Arduino Library manager..
                                      So people can "easily" update to the latest and greatest MySensors release..
                                      • D
                                        DavidZH
                                        I have just done as said above and works a treat! I was still running on Arduino 1.6.1 but this was enough reason to update!
                                        One question: my serial gateway is still running on 1.5, do I have to update that to 2.0?
                                        I have one node running on 2.0b and that talks just fine. New nodes will follow soon (PCBs are being printed now...) so they will be on 2.0 as well.
                                        • D DavidZH
                                          @DavidZH See here:
                                          "It should be fully backward compatible with your controller (serial api hasn't been changed since 1.5).
                                          We recommend updating both gateway and sensors to the the latest release."
