  2. Announcements
  3. MySensors 2.0.0 Released
75 Posts 42 Posters 55.6k Views 37 Watching
  • nielsokkerN nielsokker
    @tekka
    Thank you for your answer! Does this mean that the hardware is failing? I used the repeater example.
    tekkaT
    tekkaT
    tekka
    @nielsokker no, it means that the node was requesting and ID from the controller but didn't get one.
    • L
      L
      Lars65
      What am I doing wrong when I get this when I try to compile?
      I have a new installation of Arduino IDE 1.6.5 (have tried 1.6.7 also, and still the same)and I have put the new files in my arduino sketchbook also deleted all old ones)
      Arduino:1.6.5 (Windows 8.1), Kort:"Arduino Nano, ATmega328"
      DustSensor.ino:49:25: fatal error: MySensors.h: No such file or directory
      compilation terminated.
      Fel vid kompilering.
      nielsokkerN 1 Reply Last reply
      • L Lars65
        nielsokkerN
        nielsokkerN
        nielsokker
        wrote on last edited by nielsokker
        #24
        @Lars65
        I had the same error. You have to(instead of what the 1.5 manual says) keep all the files in the mysensors_master folder. This folder needs to be in the libraries folder that already exists.
        • L
          L
          Lars65
          Thank you!!!!!
          That helped a lot.
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            Guess it's a good thing I am just getting started. I am guessing 2.0 should be the default go to now?
            Home Automation Tinkerer
            www.CrankyCoder.net
            Gateway: MQTTClientGateway
            MySensors: 2.3
            D 1 Reply Last reply
            • CrankyCoderC CrankyCoder
              drock1985
              @Jason-Brunk
              IMHO I would say yes. Keep in mind there are some differences in how the API works. I suggest going through the example scripts from 2.0, and compare that to the ones in 1.5 so you will get an idea of what I mean.
              My Projects
              2 Door Chime Sensor
              Washing Machine Monitor
              • AnticimexA Anticimex
                :mega: We are happy to announce a major release of the MySensors library to 2.0.0!
                For details, see here.
                Doxygen links on the master github frontpage are not working. These are the correct links:
                master development
                tomkxy
                master development
                Thanks a lot for that great piece of work!!!
                • F
                  F
                  Fabien
                  Sensebender sketch is not any more in the example folder. Is it "normal" ?
                    Yes, this in the new normal... we moved all the examples using external library dependencies into https://github.com/mysensors/MySensorsArduinoExamples until we can figure out which ones work with auto-dependency-download using the IDE Library Manager.
                    We would really appreciate some help doing the verification.
                    Mark SwiftM 1 Reply Last reply
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      #31
                      Actually sensebender sketch is moved to the same repository as the hardware files for the SensebenderMicro.
                      Problem is that we do not want to have external dependencies on the examples in the MySensors library, as they are not distributed together anymore. That's why examples with external dependencies have been moved to a new repository. Except the sensebender sketch, which we/I decided to relocate to the SensebenderMicro repository, as it's a bit special, and belongs to that hardware..
                      • Tore André RosanderT
                        Tore André Rosander
                        I have been using the beta for some time now, to use the stable version do i just download the zip from github and replace the mysensors folder in arduino -> libraries ?
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Tore-André-Rosander
                          That should do it, until we get online in the arduino library manager..
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            #34
                            And now we are online in the Arduino Library manager..
                            So people can "easily" update to the latest and greatest MySensors release..
                            • D
                              DavidZH
                              I have just done as said above and works a treat! I was still running on Arduino 1.6.1 but this was enough reason to update!
                              One question: my serial gateway is still running on 1.5, do I have to update that to 2.0?
                              I have one node running on 2.0b and that talks just fine. New nodes will follow soon (PCBs are being printed now...) so they will be on 2.0 as well.
                              • D DavidZH
                                @DavidZH See here:
                                "It should be fully backward compatible with your controller (serial api hasn't been changed since 1.5).
                                We recommend updating both gateway and sensors to the the latest release."
                                • CrankyCoderC
                                  CrankyCoderC
                                  CrankyCoder
                                  not a big deal, but is there something i should do to get the mysensors to show up in my manage library?
                                  www.CrankyCoder.net
                                  MySensors: 2.3
                                    @Jason-Brunk here you can find the official "installation description"!
                                    It should be that easy ;-)
                                    • CrankyCoderC
                                      CrankyCoderC
                                      CrankyCoder
                                      running 1.6.7 and not seeing it. oh well. not a biggy
                                      www.CrankyCoder.net
                                      MySensors: 2.3
                                      • CrankyCoderC
                                        CrankyCoderC
                                        CrankyCoder
                                        updated to 1.6.9 and it's there. oh well. probably needed to update anyway :)
                                        www.CrankyCoder.net
                                        MySensors: 2.3
                                        • G
                                          G
                                          gloob
                                          I did now also update my gateway but I see two messages in the debug panel that I don't understand:
                                          pm open,type:2 0
                                          0;255;3;0;9;TSP:SANCHK:OK
                                          Does anybody have an idea what that means?
                                          ? 1 Reply Last reply
