  2. Announcements
  3. MySensors 2.0.0 Released
75 Posts 42 Posters 55.6k Views 37 Watching
  • gyroG
    gyroG
    gyro
    wrote on last edited by gyro
    I have been using rf24 radios before mysensors, and back then everything didn't worked so good as with mysensors.
    Awesome work, I think it's time for a donation at least for some 🍻 for holidays for developers. They deserve it.
    • tekkaT tekka
      @nielsokker documentation about the log messages is WIP and will follow soon.
      In brief:
      TSM refers to the transport state machine, (!) to an error.
      Your error !TSM:CHKID:FAIL indicates that the node didn't receive a (valid) ID, hence !TSM:FAILURE (transport not operational) followed by TSM:PDT which means that the radio was powered-down for a while followed by a re-initialisation.
      nielsokkerN
      nielsokkerN
      nielsokker
      @tekka
      Thank you for your answer! Does this mean that the hardware is failing? I used the repeater example.
      tekkaT 1 Reply Last reply
      • nielsokkerN nielsokker
        @tekka
        tekkaT
        tekkaT
        tekka
        @nielsokker no, it means that the node was requesting and ID from the controller but didn't get one.
        • L
          L
          Lars65
          What am I doing wrong when I get this when I try to compile?
          I have a new installation of Arduino IDE 1.6.5 (have tried 1.6.7 also, and still the same)and I have put the new files in my arduino sketchbook also deleted all old ones)
          Arduino:1.6.5 (Windows 8.1), Kort:"Arduino Nano, ATmega328"
          DustSensor.ino:49:25: fatal error: MySensors.h: No such file or directory
          compilation terminated.
          Fel vid kompilering.
          nielsokkerN 1 Reply Last reply
          • L Lars65
            nielsokkerN
            nielsokkerN
            nielsokker
            wrote on last edited by nielsokker
            #24
            @Lars65
            I had the same error. You have to(instead of what the 1.5 manual says) keep all the files in the mysensors_master folder. This folder needs to be in the libraries folder that already exists.
            • L
              L
              Lars65
              Thank you!!!!!
              That helped a lot.
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                Guess it's a good thing I am just getting started. I am guessing 2.0 should be the default go to now?
                Home Automation Tinkerer
                www.CrankyCoder.net
                Gateway: MQTTClientGateway
                MySensors: 2.3
                D 1 Reply Last reply
                • CrankyCoderC CrankyCoder
                  drock1985
                  @Jason-Brunk
                  IMHO I would say yes. Keep in mind there are some differences in how the API works. I suggest going through the example scripts from 2.0, and compare that to the ones in 1.5 so you will get an idea of what I mean.
                  My Projects
                  2 Door Chime Sensor
                  Washing Machine Monitor
                  • AnticimexA Anticimex
                    :mega: We are happy to announce a major release of the MySensors library to 2.0.0!
                    For details, see here.
                    Doxygen links on the master github frontpage are not working. These are the correct links:
                    master development
                    tomkxy
                    master development
                    Thanks a lot for that great piece of work!!!
                    • F
                      F
                      Fabien
                      Sensebender sketch is not any more in the example folder. Is it "normal" ?
                        Yes, this in the new normal... we moved all the examples using external library dependencies into https://github.com/mysensors/MySensorsArduinoExamples until we can figure out which ones work with auto-dependency-download using the IDE Library Manager.
                        We would really appreciate some help doing the verification.
                        Mark SwiftM 1 Reply Last reply
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          #31
                          Actually sensebender sketch is moved to the same repository as the hardware files for the SensebenderMicro.
                          Problem is that we do not want to have external dependencies on the examples in the MySensors library, as they are not distributed together anymore. That's why examples with external dependencies have been moved to a new repository. Except the sensebender sketch, which we/I decided to relocate to the SensebenderMicro repository, as it's a bit special, and belongs to that hardware..
                          • Tore André RosanderT
                            Tore André Rosander
                            I have been using the beta for some time now, to use the stable version do i just download the zip from github and replace the mysensors folder in arduino -> libraries ?
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @Tore-André-Rosander
                              That should do it, until we get online in the arduino library manager..
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                #34
                                And now we are online in the Arduino Library manager..
                                So people can "easily" update to the latest and greatest MySensors release..
                                • D
                                  DavidZH
                                  I have just done as said above and works a treat! I was still running on Arduino 1.6.1 but this was enough reason to update!
                                  One question: my serial gateway is still running on 1.5, do I have to update that to 2.0?
                                  I have one node running on 2.0b and that talks just fine. New nodes will follow soon (PCBs are being printed now...) so they will be on 2.0 as well.
                                  • D DavidZH
                                    @DavidZH See here:
                                    "It should be fully backward compatible with your controller (serial api hasn't been changed since 1.5).
                                    We recommend updating both gateway and sensors to the the latest release."
                                    • CrankyCoderC
                                      CrankyCoderC
                                      CrankyCoder
                                      not a big deal, but is there something i should do to get the mysensors to show up in my manage library?
                                      www.CrankyCoder.net
                                      MySensors: 2.3
                                        @Jason-Brunk here you can find the official "installation description"!
                                        It should be that easy ;-)
                                        • CrankyCoderC
                                          CrankyCoderC
                                          CrankyCoder
                                          running 1.6.7 and not seeing it. oh well. not a biggy
                                          www.CrankyCoder.net
                                          MySensors: 2.3
