  2. Announcements
  3. MySensors 2.0.0 Released
75 Posts 42 Posters 55.6k Views 37 Watching
    Yes, this in the new normal... we moved all the examples using external library dependencies into https://github.com/mysensors/MySensorsArduinoExamples until we can figure out which ones work with auto-dependency-download using the IDE Library Manager.
    We would really appreciate some help doing the verification.
    Mark SwiftM 1 Reply Last reply
    • tbowmoT
      tbowmoT
      tbowmo
      #31
      Actually sensebender sketch is moved to the same repository as the hardware files for the SensebenderMicro.
      Problem is that we do not want to have external dependencies on the examples in the MySensors library, as they are not distributed together anymore. That's why examples with external dependencies have been moved to a new repository. Except the sensebender sketch, which we/I decided to relocate to the SensebenderMicro repository, as it's a bit special, and belongs to that hardware..
      • Tore André RosanderT
        Tore André Rosander
        I have been using the beta for some time now, to use the stable version do i just download the zip from github and replace the mysensors folder in arduino -> libraries ?
        • tbowmoT
          tbowmoT
          tbowmo
          @Tore-André-Rosander
          That should do it, until we get online in the arduino library manager..
          • tbowmoT
            tbowmoT
            tbowmo
            #34
            And now we are online in the Arduino Library manager..
            So people can "easily" update to the latest and greatest MySensors release..
            • D
              DavidZH
              I have just done as said above and works a treat! I was still running on Arduino 1.6.1 but this was enough reason to update!
              One question: my serial gateway is still running on 1.5, do I have to update that to 2.0?
              I have one node running on 2.0b and that talks just fine. New nodes will follow soon (PCBs are being printed now...) so they will be on 2.0 as well.
              • D DavidZH
                @DavidZH See here:
                "It should be fully backward compatible with your controller (serial api hasn't been changed since 1.5).
                We recommend updating both gateway and sensors to the the latest release."
                D 1 Reply Last reply
                • CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  not a big deal, but is there something i should do to get the mysensors to show up in my manage library?
                  Home Automation Tinkerer
                  www.CrankyCoder.net
                  Gateway: MQTTClientGateway
                  MySensors: 2.3
                  • CrankyCoderC CrankyCoder
                    @Jason-Brunk here you can find the official "installation description"!
                    It should be that easy ;-)
                    • CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      running 1.6.7 and not seeing it. oh well. not a biggy
                      www.CrankyCoder.net
                      MySensors: 2.3
                      • CrankyCoderC
                        CrankyCoderC
                        CrankyCoder
                        updated to 1.6.9 and it's there. oh well. probably needed to update anyway :)
                        www.CrankyCoder.net
                        MySensors: 2.3
                        • G
                          G
                          gloob
                          I did now also update my gateway but I see two messages in the debug panel that I don't understand:
                          pm open,type:2 0
                          0;255;3;0;9;TSP:SANCHK:OK
                          Does anybody have an idea what that means?
                          ? 1 Reply Last reply
                          • TheoLT
                            TheoLT
                            TheoL
                            I've read the documentation and I'm really impressed with the great work you've guys have done. Developping sensors with MySensors had never been this easy. You guys rock!
                            • hugowsH
                              hugowsH
                              hugows
                              I just built my first "sensor network" yesterday and I was lucky to arrive on the 2.0 version - fun times! Congrats hek and contributors.
                              • KoreshK
                                KoreshK
                                Koresh
                                Congratulations!
                                I used 2.0dev last month and I'm happy to see this version get stable status. :thumbsup:
                                • YveauxY Yveaux
                                  @DavidZH See here:
                                  DavidZH
                                  @Yveaux
                                  I have now recompiled my node that was on 2.0DEV to 2.0Stable and it will not fly. So tomorrow I will recompile my gateway to see if that runs better.
                                  I really have to get used to the new debug output though. But it give a lot more info!
                                  • G gloob
                                    pm open,type:2 0
                                    A Former User
                                    pm open,type:2 0
                                    I have this problem too. What does that mean?
                                    tbowmoT 1 Reply Last reply
                                    • ? A Former User
                                      pm open,type:2 0
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @kenci said:
                                      pm open,type:2 0
                                      The TSP:SANCHK:OK is a sanity check of the radio, this time it's OK. But if we fail in talking with the radio (spi failure etc) it will try to initialize the radio, and also write Fail (I believe)
                                      It's @tekka that is the brain behind this part (and has promised to make some documentation on it :))
                                      ? mppM 2 Replies Last reply
                                      • tbowmoT tbowmo
                                        @kenci said:
                                        pm open,type:2 0
                                        A Former User
                                        @tbowmo Thank you for the explanation. But what does that mean pm open,type:2 0
                                        • marekdM
                                          marekdM
                                          marekd
                                          Hi there.
                                          Good work.
                                          I was using dev ver. - should I recompile all nodes and GW to 2.0.0, to use it?
                                          YveauxY AWIA 2 Replies Last reply
