  2. Announcements
  3. MySensors 2.0.0 Released
75 Posts 42 Posters 55.6k Views 37 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    running 1.6.7 and not seeing it. oh well. not a biggy
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • CrankyCoderC
      CrankyCoderC
      CrankyCoder
      updated to 1.6.9 and it's there. oh well. probably needed to update anyway :)
      www.CrankyCoder.net
      MySensors: 2.3
      • G
        G
        gloob
        I did now also update my gateway but I see two messages in the debug panel that I don't understand:
        pm open,type:2 0
        0;255;3;0;9;TSP:SANCHK:OK
        Does anybody have an idea what that means?
        ? 1 Reply Last reply
        • TheoLT
          TheoLT
          TheoL
          I've read the documentation and I'm really impressed with the great work you've guys have done. Developping sensors with MySensors had never been this easy. You guys rock!
          • hugowsH
            hugowsH
            hugows
            I just built my first "sensor network" yesterday and I was lucky to arrive on the 2.0 version - fun times! Congrats hek and contributors.
            • KoreshK
              KoreshK
              Koresh
              Congratulations!
              I used 2.0dev last month and I'm happy to see this version get stable status. :thumbsup:
              • YveauxY Yveaux
                @DavidZH See here:
                "It should be fully backward compatible with your controller (serial api hasn't been changed since 1.5).
                We recommend updating both gateway and sensors to the the latest release."
                DavidZH
                @Yveaux
                I have now recompiled my node that was on 2.0DEV to 2.0Stable and it will not fly. So tomorrow I will recompile my gateway to see if that runs better.
                I really have to get used to the new debug output though. But it give a lot more info!
                • G gloob
                  pm open,type:2 0
                  A Former User
                  pm open,type:2 0
                  I have this problem too. What does that mean?
                  tbowmoT 1 Reply Last reply
                  • ? A Former User
                    pm open,type:2 0
                    tbowmoT
                    tbowmoT
                    tbowmo
                    @kenci said:
                    pm open,type:2 0
                    The TSP:SANCHK:OK is a sanity check of the radio, this time it's OK. But if we fail in talking with the radio (spi failure etc) it will try to initialize the radio, and also write Fail (I believe)
                    It's @tekka that is the brain behind this part (and has promised to make some documentation on it :))
                    ? mppM 2 Replies Last reply
                    • tbowmoT tbowmo
                      @kenci said:
                      pm open,type:2 0
                      A Former User
                      @tbowmo Thank you for the explanation. But what does that mean pm open,type:2 0
                      • marekdM
                        marekdM
                        marekd
                        Hi there.
                        Good work.
                        I was using dev ver. - should I recompile all nodes and GW to 2.0.0, to use it?
                        YveauxY AWIA 2 Replies Last reply
                        • marekdM marekd
                          Hi there.
                          Good work.
                          @marekd quote from the main site : "We recommend updating both gateway and sensors to the the latest release."
                          • marekdM marekd
                            Hi there.
                            Good work.
                            AWIA
                            AWIA
                            AWI
                            @marekd To add to @Yveaux , if you are using repeaters (or nodes with the repeater functionality switched on) these also should be updated to the latest release.
                            • Tore André RosanderT
                              Tore André Rosander
                              Is there any plans to update the Raspberry gateway? The one where the nrf radio is connected directly to RPI gpio.
                              As far as i know it is version 1.4 at the moment.
                              D 1 Reply Last reply
                              • Tore André RosanderT Tore André Rosander
                                drock1985
                                @Tore-André-Rosander
                                I think that was someone who contributed it a while back. I remember going though the thread, and at one time someone was looking for anyone to update the 1.5 base for the signing; IIRC.
                                Probably best to switch to another Gateway for now.
                                My Projects
                                2 Door Chime Sensor
                                Washing Machine Monitor
                                Tore André RosanderT 1 Reply Last reply
                                • D drock1985
                                  Tore André Rosander
                                  @drock1985
                                  Is there any pro/cons when choosing the esp gateway or the serial gateway (connected to Raspberry pi)?
                                    @drock1985
                                    drock1985
                                    Not really; depends on what your controller supports. Personally I have Home-Assistant running the latest MySensors 2.0 Wifi (ESP) gateway no problems.
                                    My Projects
                                    2 Door Chime Sensor
                                      #56
                                      for pros, I think serial gw is more secure. I mean esp is wifi, serial gw is only connected to controller. Of course controller is connected to network, but esp is just one more door directly connected to mysensors. Cons, not as verstatile as esp ;)
                                      • F
                                        F
                                        Fabien
                                        And with RFM69, ESP and MySensors 2.0 doesn't work for me. With serial gateway, it's ok. With Ethernet Gateway W5100 and MYS 1.0, I lost lot of packets (NRF radio).
                                          Tore André Rosander
                                          Thanks for the response, i tested the esp gateway and it looks good. But i think im going for the serial gateway just to eliminate the need for WiFi in my setup. So if the WiFi is messing up during the night the mysensors network still works.
