  2. Announcements
  3. MySensors 2.0.0 Released
75 Posts 42 Posters 55.6k Views 37 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    not a big deal, but is there something i should do to get the mysensors to show up in my manage library?
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • CrankyCoderC CrankyCoder
      @Jason-Brunk here you can find the official "installation description"!
      It should be that easy ;-)
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        running 1.6.7 and not seeing it. oh well. not a biggy
        www.CrankyCoder.net
        MySensors: 2.3
        • CrankyCoderC
          CrankyCoderC
          CrankyCoder
          updated to 1.6.9 and it's there. oh well. probably needed to update anyway :)
          www.CrankyCoder.net
          MySensors: 2.3
          • G
            G
            gloob
            I did now also update my gateway but I see two messages in the debug panel that I don't understand:
            pm open,type:2 0
            0;255;3;0;9;TSP:SANCHK:OK
            Does anybody have an idea what that means?
            ? 1 Reply Last reply
            • TheoLT
              TheoLT
              TheoL
              I've read the documentation and I'm really impressed with the great work you've guys have done. Developping sensors with MySensors had never been this easy. You guys rock!
              • hugowsH
                hugowsH
                hugows
                I just built my first "sensor network" yesterday and I was lucky to arrive on the 2.0 version - fun times! Congrats hek and contributors.
                • KoreshK
                  KoreshK
                  Koresh
                  Congratulations!
                  I used 2.0dev last month and I'm happy to see this version get stable status. :thumbsup:
                  • YveauxY Yveaux
                    @DavidZH See here:
                    "It should be fully backward compatible with your controller (serial api hasn't been changed since 1.5).
                    We recommend updating both gateway and sensors to the the latest release."
                    DavidZH
                    @Yveaux
                    I have now recompiled my node that was on 2.0DEV to 2.0Stable and it will not fly. So tomorrow I will recompile my gateway to see if that runs better.
                    I really have to get used to the new debug output though. But it give a lot more info!
                    • G gloob
                      pm open,type:2 0
                      A Former User
                      pm open,type:2 0
                      I have this problem too. What does that mean?
                      tbowmoT 1 Reply Last reply
                      • ? A Former User
                        pm open,type:2 0
                        tbowmoT
                        tbowmoT
                        tbowmo
                        @kenci said:
                        pm open,type:2 0
                        The TSP:SANCHK:OK is a sanity check of the radio, this time it's OK. But if we fail in talking with the radio (spi failure etc) it will try to initialize the radio, and also write Fail (I believe)
                        It's @tekka that is the brain behind this part (and has promised to make some documentation on it :))
                        ? mppM 2 Replies Last reply
                        • tbowmoT tbowmo
                          @kenci said:
                          pm open,type:2 0
                          A Former User
                          @tbowmo Thank you for the explanation. But what does that mean pm open,type:2 0
                          • marekdM
                            marekdM
                            marekd
                            Hi there.
                            Good work.
                            I was using dev ver. - should I recompile all nodes and GW to 2.0.0, to use it?
                            YveauxY AWIA 2 Replies Last reply
                            • marekdM marekd
                              Hi there.
                              Good work.
                              @marekd quote from the main site : "We recommend updating both gateway and sensors to the the latest release."
                              • marekdM marekd
                                Hi there.
                                Good work.
                                AWIA
                                AWIA
                                AWI
                                @marekd To add to @Yveaux , if you are using repeaters (or nodes with the repeater functionality switched on) these also should be updated to the latest release.
                                • Tore André RosanderT
                                  Tore André Rosander
                                  Is there any plans to update the Raspberry gateway? The one where the nrf radio is connected directly to RPI gpio.
                                  As far as i know it is version 1.4 at the moment.
                                  D 1 Reply Last reply
                                  • Tore André RosanderT Tore André Rosander
                                    drock1985
                                    @Tore-André-Rosander
                                    I think that was someone who contributed it a while back. I remember going though the thread, and at one time someone was looking for anyone to update the 1.5 base for the signing; IIRC.
                                    Probably best to switch to another Gateway for now.
                                    My Projects
                                    2 Door Chime Sensor
                                    Washing Machine Monitor
                                    Tore André RosanderT 1 Reply Last reply
                                    • D drock1985
                                      Tore André Rosander
                                      @drock1985
                                      Is there any pro/cons when choosing the esp gateway or the serial gateway (connected to Raspberry pi)?
                                        @drock1985
                                        drock1985
                                        Not really; depends on what your controller supports. Personally I have Home-Assistant running the latest MySensors 2.0 Wifi (ESP) gateway no problems.
                                        My Projects
                                        2 Door Chime Sensor
                                          #56
                                          for pros, I think serial gw is more secure. I mean esp is wifi, serial gw is only connected to controller. Of course controller is connected to network, but esp is just one more door directly connected to mysensors. Cons, not as verstatile as esp ;)
