  3. Home Assistant
  4. unable to open USB port
23 Posts 4 Posters 6.5k Views 4 Watching
  • chillimanC Offline
    chillimanC Offline
    chilliman
    Hi .
    i am having an issue with getting HA to talk to my serial gateway 0_1468420353578_error-2.txt
    not sure what is going on (newbie) can any one help
    running Debian 8 on pc
    HA is running fine
    i have something now showing on Available services please screen shot0_1468420640419_screen shot.jpg
    hope you can help
    chilliman
    • martinhjelmareM Offline
      martinhjelmare
      Have you tested your setup with just a serial monitor on both ends, gateway and a node? Do you see output in the serial monitor for the same port you've specified in the home assistant config for mysensors? What are the permissions for the port? Do you have anything else running connected to the port?
      chillimanC 1 Reply Last reply
        chillimanC Offline
        chillimanC Offline
        chilliman
        @martinhjelmare
        i will check that out and let you know what i find
        chilliman
          chillimanC Offline
          chilliman
          martinhjelmare
          i had to check the info from the gateway and sensor on a different m/c for some reason the install on Debain 8.5 i was unable to access the desktop .
          for the gateway :-
          for the sensor( motion sensor)
          send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
          send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
          send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,st=ok:Motion Sensor
          send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
          send: 3-3-0-0 s=1,c=0,t=1,pt=0,l=0,sg=0,st=ok:
          send: 3-3-0-0 s=1,c=1,t=16,pt=0,l=1,sg=0,st=ok:0
          send: 3-3-0-0 s=1,c=1,t=16,pt=0,l=1,sg=0,st=ok:1
          add both:-
          0;0;3;0;9;read: 3-3-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
          3;1;1;0;16;0
          0;0;3;0;9;read: 3-3-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
          3;1;1;0;16;1
          3;1;1;0;16;0
          hope you make some sense of this numbers
          if you need any info please let me know so i can get it for you , do you know why i can not open the debian desk ?
          chilliman
            martinhjelmare
            The serial output looks good. Now you should check the permission and ownership information of the usb device on the computer. But of course you need access to that first. Have you had access to the desktop before? How did you install Debian?
              chillimanC Offline
              chilliman
              hi.
              i was not able to access the desktop from the start i reload the OS three time make sure i select the correct option (the one i through i needed), as it boots up it ask me for my password screen clears and comes up with Opp's where was a problem and goes back to the sign in screen
              chilliman
                martinhjelmare
                If it's a fresh install and you don't mind wiping the disk or partition , it might be easiest to just reinstall the complete OS, if you don't know what's wrong. Otherwise try googling the error message.
                I'm using Ubuntu myself which is another distribution but based on Debian. If you don't have a specific reason for choosing Debian, I would recommend Ubuntu. My installs have gone without hiccups for probably more than 90% of times over multiple different systems for more than 10 years that I've been using Ubuntu.
                  chillimanC Offline
                  chilliman
                  martinhjelmare
                  what version of ubuntu do you i should i use 14.04 ,15.10 or 16.04LTS i am more that happy to reinstall the OS i am just trying to get Home Assistant and MySensors working correctly
                  thanks for you help
                  chilliman
                  • D Offline
                    drock1985
                    @chilliman
                    Go with the latest LTS build of Ubuntu. LTS stands for Long Term Support and guarantees security updates to that version for 5 years(?); and can be easily updated to the latest if you wish.
                    Also depending on what you comfort level is with Linux in general. there are several other flavours/distributions of Ubuntu, including a Server edition that is completely text based and uses the least system resources.
                    My Projects
                    2 Door Chime Sensor
                    Washing Machine Monitor
                      chillimanC Offline
                      chilliman
                      wrote on last edited by chilliman
                      Martin.
                      i have purchased a raspberry pi 3 running Debian Jessie loaded Home Assistant which working great i have add MySensors Gateway with a motion sensor node there is no error as regards to not opening the usb port (it says found and has open it) what i am getting error :-
                      16-07-17 16:46:03 mysensors.mysensors: File does not exist or is not readable: path/mysensors.json
                      16-07-17 16:46:03 mysensors.mysensors: Trying backup file: path/mysensors.json.bak
                      16-07-17 16:46:03 mysensors.mysensors: File does not exist or is not readable: path/mysensors.json.bak
                      16-07-17 16:46:03 mysensors.mysensors: Failed to load sensors from file: path/mysensors.json
                      what do i have to do to get this working correctly any ideas
                      chilliman
                      • D Offline
                        drock1985
                        The error says it. You have persistence turned on, but the file location is invalid or you do not have read/write access to it.
                        What user are you using to turn on hass and what does the MySensors entry of configuration.yaml look like?
                        My Projects
                        2 Door Chime Sensor
                          chillimanC Offline
                          chilliman
                          drock1985
                          do you have to have the persistence turned on , i turn on hass with pi (user)
                          mysensors:
                          gateways:
                          - device: '/dev/ttyUSB0'
                          persistence_file: 'path/mysensors2.json'
                          baud_rate: 115200
                          if i turn the persistence off i get a different error
                          16-07-17 21:42:41 mysensors.mysensors: File does not exist or is not readable: /home/pi/.homeassistant/mysensors1.pickle
                          16-07-17 21:42:41 mysensors.mysensors: Trying backup file: /home/pi/.homeassistant/mysensors1.pickle.bak
                          16-07-17 21:42:41 mysensors.mysensors: File does not exist or is not readable: /home/pi/.homeassistant/mysensors1.pickle.bak
                          16-07-17 21:42:41 mysensors.mysensors: Failed to load sensors from file: /home/pi/.homeassistant/mysensors1.pickle
                          any ideas?
                          chilliman
                          • D Offline
                            drock1985
                            Your path to the persistence file is wrong. You need to choose a directory that your user (in this case pi) has access to. I would recommend using /home/pi/.homeassistant so that your configuration.yaml flie would look like this:
                            mysensors:
                              gateways:
                                  persistence_file: 'home/pi/.homeassistant'
                                  baud_rate: 115200
                              debug: false
                              persistence: true
                            The entry in your configuration.yaml file is a direct copy/paste of the example; you have to change it to meet your setup. The one I posted above should work fine for your install, and you can enable debug and launch hass manually from a terminal if you need to debug any MySensors related issues.
                            My Projects
                            2 Door Chime Sensor
                              chillimanC Offline
                              chilliman
                              drock1985.
                              i cut and paste the example you posted but a get a error
                              16-07-17 23:07:10 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant
                              16-07-17 23:07:10 mysensors.mysensors: Trying backup file: home/pi/.homeassistant.bak
                              16-07-17 23:07:10 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant.bak
                              16-07-17 23:07:10 mysensors.mysensors: Failed to load sensors from file: home/pi/.homeassistant
                              not sure what is going on hopefully you can help me
                              chilliman
                              D 1 Reply Last reply
                              • chillimanC chilliman
                                drock1985.
                                chilliman
                                drock1985
                                wrote on last edited by drock1985
                                @chilliman said:
                                mysensors:
                                gateways:
                                baud_rate: 115200
                                debug: false
                                persistence: true
                                My bad, forgot to add the file at the end of the directory.
                                mysensors:
                                  gateways:
                                      persistence_file: 'home/pi/.homeassistant/mysensors.json'
                                      baud_rate: 115200
                                  debug: false
                                  persistence: true
                                My Projects
                                2 Door Chime Sensor
                                  chillimanC Offline
                                  chilliman
                                  drock1985
                                  i just changed the conf file to with the latest and i get this error massage
                                  16-07-17 23:16:27 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant/mysensors.json
                                  16-07-17 23:16:27 mysensors.mysensors: Trying backup file: home/pi/.homeassistant/mysensors.json.bak
                                  16-07-17 23:16:27 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant/mysensors.json.bak
                                  16-07-17 23:16:27 mysensors.mysensors: Failed to load sensors from file: home/pi/.homeassistant/mysensors.json
                                  chilliman
                                    chillimanC Offline
                                    chilliman
                                    Drock1985
                                    please find attached HA start up file
                                    0_1468799007226_HA-startup.txt
                                    thanks
                                    chilliman
                                      Drock1985
                                      thanks
                                      chilliman
                                      martinhjelmare
                                      @chilliman
                                      The first time you start home assistant, the persistence file will not have been created, so you will get the warning message even if you have set the correct path. Only after a sensor has reported a value will the persistence file be written. You should always include a sending of initial value in your setup/presentation function for a node, so once you have started the node, it will be added as a device to home assistant and the persistence file will be populated.
                                        chillimanC Offline
                                        chilliman
                                        martin.
                                        i am sorry i having a newbie moment i just need to understand what is happening so the way it is setup is good.
                                        if so i have few more question , i have the gateway and all have a node with a motion sensor attached so how do i get the motion sensor to show up on HA .
                                        sorry for not understanding its a very steep learning curve.
                                        chilliman
                                          martin.
                                          chilliman
                                          drock1985
                                          @chilliman
                                          Not sure what else to tell you. Like Martin said, for a node to appear at all in HA; it must do two things. 1) send the full presentation on the node start. Easiest way to do that is to start HA, and after HA is fully started put power to your motion sensor. 2) It must send a valid sensor status. In the case of a motion sensor, I believe it is either 1 or 0 (1 being motion detected, 0 being none).
                                          The only thing I can see is maybe the / needs to be in front of home. Can't see it causing this many issues though.
                                          mysensors:
                                            gateways:
                                                persistence_file: '/home/pi/.homeassistant/mysensors.json'
                                                baud_rate: 115200
                                            debug: false
                                            persistence: true
                                          Other than that i'm not sure what else to suggest. If everything is configured right, it should see it. You may also want to check out the debug part of MySensors config and HA to better determine your issue. @martinhjelmare help me with that issue some time ago.
                                          My Projects
                                          2 Door Chime Sensor
                                          SebexS 1 Reply Last reply
                                          11.8k
                                          113.2k
