  3. 'MySensoring' an Intermatic EH40 (Project Completed!)
water heater cointermatic eh40
13 Posts 4 Posters 9.9k Views 1 Watching
  • DammeD Damme
    A relay actuator would work, I cant help so much with your question. But I want you to think some about safety also. Do not skip over safety components like over temperature and such. This could lead to a disaster. So basically 3 safety-steps:
    Software at controller to regulate and send start / stop and read temperatures.
    Software at relay-node to verify sane operating temperatures
    and third - The absolutely most important - Hardwired safety temperature thermostat in case everything fails. (could be the relay fried stuck on i.e)
    write a principal scheme for better explanation!
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @Damme Thanks for the reply. My control will only be providing on and off functionality.
    All temperature and safety control will remain under the control of the water heater.
    RJ_Make
    • RJ_MakeR
      RJ_MakeR
      RJ_Make
      wrote on last edited by RJ_Make
      Thinking out loud...... , Do I really need to use a transistor or relay to do the switching?
      With only needing a 1.5vdc @ 1.9uA signal to cause the EH40 to turn the relays on, can I do this solely using the Arduino board?
      Example:
      Analog input to sense when the EH40 makes it's own call to turn the water heater on.
      AND IF Vera says OFF then do nothing, otherwise allow ON..... (Not sure how any of that would work)
      Analog output to send the 1.5vdc @ 1.9uA signal to turn the water heater ON.
      Hmmmm......
      RJ_Make
      DammeD 1 Reply Last reply
      • RJ_MakeR RJ_Make
        Example:
        Hmmmm......
        DammeD
        DammeD
        Damme
        Code Contributor
        @ServiceXp Hmm, I don't really know but you might be able to use the out-pin on the arduino and a resistor, but its not really safe in case there are some leakage. I would get isolation with a optocoupler. they are really cheap to buy! Often found in broken electronics too. only to salvage! :)
        • RJ_MakeR
          RJ_MakeR
          RJ_Make
          Ok optocoupler would be pretty cool from what I've learned about them. However, it seems that most will wind up consuming more power (x8) then the 1.9uA for the relay trigger.
          I think to start off I'm going to try a voltage divider (2x 10M ohms resisters) which I believe will take my ~3.3vdc to 1.65vdc with consumption @ 165 nA which seems very low.
          RJ_Make
          • RJ_MakeR
            RJ_MakeR
            RJ_Make
            Ok,
            Working on the code for this Water Heater CNT, and I've run into a problem. I have a temp sensor in the loop which is causing problems with the relays activating. Any time a the temp changes, while I try to activate a relay it fails to activate. (because it's tied up with sending the temps???)
            How do I code around this?
            Here is V1 of the code.
            	// Example sketch showing how to control physical relays.
            	// This example will remember relay state even after power failure.
            	#include <OneWire.h>
            	//Standard
            	#define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
            	#define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            	#define NUMBER_OF_RELAYS 2 // Total number of attached relays
            	//EH40
            	#define BUTTON_RELAY_PIN 5  // Relay Attached to Button Control
            	#define BUTTON_RELAY_LED_PIN 8  // On while in Super Control
            	#define LOCKOUT_RELAY_LED_PIN 7  // On while EH40 Program is locked out
            	#define BUTTON_RELAY_ID 2  // Child Attached to Button Control
            	#define EH40_LOCK_OUT_RELAY_ID 1  // Child Attached to EH40 Lock out relay
            	//Temperature
            	#define ONE_WIRE_BUS 6 // Pin where dallas sensor is connected
            	Bounce debouncer = Bounce();
            	int BATTERY_SENSE_PIN = A0;  // select the input pin for the EH40 battery sense point
            	int oldBatteryPcnt = 0;
            	int oldValue=0;
            	bool state;
            	//Temperature
            	int numSensors=0;
            	boolean receivedConfig = false;
            	boolean metric = false;
            	// Initialize Button message
            	MyMessage msg(BUTTON_RELAY_ID,V_LIGHT);
            	MyMessage msgTEMP(0,V_TEMP);
            		analogReference(INTERNAL);
            		// Startup OneWire
            		 sensors.begin();
            		gw.sendSketchInfo("Water Heater CNT", "1.0");
            		// Setup the button
            		pinMode(BUTTON_PIN,INPUT);
            		// Activate internal pull-up
            		// Then set LED relay pin in output mode
            		pinMode(BUTTON_RELAY_LED_PIN, OUTPUT);
            		// Then set LED Lockout relay pin in output mode
            		pinMode(LOCKOUT_RELAY_LED_PIN, OUTPUT);
            		//Set LED to off
            		digitalWrite(BUTTON_RELAY_LED_PIN,HIGH);
            		digitalWrite(LOCKOUT_RELAY_LED_PIN,HIGH);
            		debouncer.attach(BUTTON_PIN);
            		debouncer.interval(5);
            		// Present all Temperature sensors to controller
            			gw.present(i, S_TEMP);
            		// Fetch relay status
            		gw.present(sensor, S_LIGHT);
            		// Make sure relay is off when starting up
            		digitalWrite(pin, RELAY_OFF);
            		pinMode(pin, OUTPUT);
            		digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
            	  debouncer.update();
            		// Get the update value
            		int value = debouncer.read();
            		if (value != oldValue && value==0) {    //(value != oldValue && value==0) {
            			 gw.send(msg.set(msg.getBool()?false:true), true);
            			// Store state in eeprom
            			gw.saveState(msg.sensor, msg.getBool());
            		oldValue = value;
            	  delay(1);
            		//Send Temperatures to Controller
            	  sendTemperatureToController();
            	  if (message.type==V_LIGHT) {
            		 // Change relay state
            		 //Handle LED's
            		 ledControl(message.sensor);
            		 // Check EH40 Battery, but only when we receive work
            		 runBATTFuntion();
            	void ledControl(int isensor){
            			switch (isensor) {
            				case BUTTON_RELAY_ID:
            					if (gw.loadState(BUTTON_RELAY_ID) == RELAY_ON)
            						digitalWrite(BUTTON_RELAY_LED_PIN,LOW);
            				case EH40_LOCK_OUT_RELAY_ID:
            					if (gw.loadState(EH40_LOCK_OUT_RELAY_ID) == RELAY_ON)
            						digitalWrite(LOCKOUT_RELAY_LED_PIN,LOW);
            						//Set to off
            	void runBATTFuntion(){
            		// get the battery Voltage
            		Serial.println(sensorValue);
            		Serial.print(batteryV);
            		Serial.println(" V");
            		Serial.print(batteryPcnt);
            		Serial.println(" %");
            			// Power up radio after sleep
            			oldBatteryPcnt = batteryPcnt;
            	void sendTemperatureToController(){
            			//float temperature = static_cast<float>(static_cast<int>((sensors.getTempFByIndex(i)) * 10.)) / 10.;
            			float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
            			if (lastTemperature[i] != temperature && temperature != -127.00) {
            				gw.send(msgTEMP.setSensor(i).set(temperature,1));
            RJ_Make
            • RJ_MakeR
              RJ_MakeR
              RJ_Make
              Solved the 'asynchronous' issue thanks Google and a gazillion other having the same question... :-)
              So here is version 2.
              Here is the framework for the code below.
              Current Hardware:
              It incorporates a dual relay , Intermatic EH40 220v Timer, Temperature Sensor, 1 LED for visual indication of power ON state for each of the relays, and a simple momentary push button. (outside of the 5v Mini Pro)
              Waiting on Items:
              Transformer, fused rocker switch
              Need to Decide:
              An appropriate enclosure, and if I'm going to add an enclosure temp sensor. I was thinking since I'm going to have a transformer and relay assm., possibly inside a plastic enclosure It might be a good ideal to protect against heat..
              Schema:
              1. The EH40_LOCK_OUT_RELAY_ID locks out the EH40 relay drive circuit and is wired to the NC contacts of relay 1. (So if there is a Arduino failure, the timer will still run it's schedule)
              2. The BUTTON_RELAY_ID is a Master Control Relay and will allow 1) overriding of the EH40 relay drive circuit and is wired to the NO contacts of relay 2.
              3. Power for the EH40 relay circuit is routed out of the EH40, through the relays and back to the EH40. So all drive power is coming from the EH40 single AA battery. The hardware and code supports monitoring the EH40 battery supply. This will keep the 2 power supplies completely isolated.
              4. Added the DS18B20 temperature sensor to report back tank temp. for controller logic (VERA) I have some idea's on what I may want to do with this.
              5. Push button that controls the Master Control Relay. This allows us to manually turn on the water heater when near the unit.
              I'm sure I've forgot stuff, but I'll follow up on this project as it progresses.
              	//Standard
              	//EH40
              	//Temperature
              	int oldValue=0;
              	//Temperature
              	unsigned long TemperatureTimeing;
              	const unsigned long Temperatureinterval = 30000; //30 sec
              	int numSensors=0;
              		//Initialize Temperature Timer
              		TemperatureTimeing = millis ();
              		// Startup OneWire
              		 sensors.begin();
              		// Setup the button
              		//Set LED to off
              	  debouncer.update();
                    // Did the button get pushed?
              	  ButtonPushed();
              	  if ( (millis () - TemperatureTimeing) >= Temperatureinterval)
              		 //Handle LED's
              		 // Check EH40 Battery, but only when we have received work
              		 runBATTFuntion();
              	void ButtonPushed(){
              		debouncer.update();
              		oldValue = value;
              			switch (isensor) {
              						//Set to off
              		// get the battery Voltage of the EH40
              		// 3.44/1023 = Volts per bit = 0.003363075  1.5v 0.001466276
              		float batteryV  = sensorValue * 0.001466276;
              		//Start time for Temperature readings
              RJ_Make
                mikeones
                So you incorporated a delay between sending your temp values to resolve the issue? Were you spamming the GW with messages without the delay?
                RJ_MakeR 1 Reply Last reply
                • M mikeones
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @mikeones
                  Yes during temperature changes..
                  In the first iteration I was using delays of various times (the one posted in v1 of the code was setting the delay to 1 ms to basically shut it off instead of deleting the function), in an effort to resolve the asynchronous nature of this language.
                  The larger I made the delay the worse the problem became and that made sense because as I understand it, the delay function stops code execution. So in v2 I just incorporated a time component. So now it will only check temps every Temperatureinterval.
                  Not being a C programmer..... this stuff is like trying to pick up a greased watermelon seed while being chased by a hornet.. ;-)
                  but for now this works... for now.....
                  RJ_Make
                  • RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    Project Complete! My EH40 has now been 'MySensored'
                    This was a fun project, and I learned quite a bit during the process and I was able to accomplish all my goals.
                    Goal Recap
                    1. Remotely lockout the EH40's schedule.
                    2. Remotely Activate the EH40 Relay.
                    3. Locally override_to_On, Both Vera and the EH40 schedule (Button)
                    4. Remotely acquire water heater's tank temperature.
                    Final Components Used:
                    1. Arduino mini 5V
                    2. Dual Relay 5V
                    3. Couple of pcb's
                    4. Screw Connectors
                    5. Push Button
                    6. Temperature Sensor
                    7. Radio
                      8.) Step Down Module
                    8. Fused Rocker Switch
                    9. Transformer I wound up going with one of these over the Ebay China option. Just felt more comfortable with this.
                    10. Project Box
                    Misa: Resisters, 47uF cap for the radio, wires and lots of solder and hot glue.
                    **Final EH40 Wire Configuration **
                    1. Red - 1.5vdc directly from EH40 Batt.
                    2. Black (Yellow) GND
                    3. Blue (Blue) Input
                    4. Yellow (Blue) Output
                    Transformer Assm: Board
                    The output seem stable enough (using a volt meter) I didn't use any post filtering.
                    All connection under pcb is covered in a thick layer of hot glue to help prevent any shorts.
                    EH40 Connection Board
                    Main Control Board
                    I forgot to get pictures of the top, but here is the messy bottom..
                    EH40 Connection Board Mounted In Box
                    Using a Dremel; cut a slot out, then hot gluing to bottom of box.
                    Dual Relay Mounted
                    It was a perfect fit.
                    Push Button and LED (Wired Relay Contacts)
                    Top relay is #1 (Lockout); 2nd is #2 (Override)
                    1)Relay #1 -- Blue Wire -- Output to NC
                    2)Relay #1 -- Yellow Wire -- input to COM
                    3)Relay #1 -- Blue Wire -- Output NC JUMPED to COM of Relay #2
                    4)Relay #2 -- 2 Red Wires (One from EH40 and the other for battery monitoring on Main Control Board) -- Output to NO
                    5)Relay #2 -- COM JUMPED to Relay #1 NC
                    Fused Power Switch and Socket
                    500ma Fuse with all exposed connection covered in hot glue.
                    Transformer; Relay; EH40 Connection and Main Board
                    I tried to keep the High Voltage section isolated from any of the low voltage section as best as possible.
                    Completed Project Connected to EH40
                    EH40 Connection
                    115vac Connection
                    EH40 Has Control and running it's schedule
                    Vera (Remote) has EH40 Schedule Locked Out (Water Heater Off)
                    Vera (Remote) has EH40 Schedule Locked Out but Override button is active (Water Heater On)
                    RJ_Make
                      Nice! Thanks for the pictures.
                      • RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        Update:
                        Wind up having to buy a oscilloscope to try and diagnose a problem I was having and wound up reworking the transformer board a little. I installed 5 caps in an attempt to clean up the output.
                        4.7uF/400V Cap between pins 22 and 26 on transformer. electrolytic
                        470uF/50v Between 5vd Output (electrolytic)
                        47uF/50v Between 5vd Output (electrolytic)
                        10uF/50v Between 5vd Output (electrolytic)
                        .1uF/ (ceramic) Installed at the screw connector on the main board (for best results)
                        RJ_Make
                        12.5k
